    • Search
    MagicMirror² v2.20.0 is available! For more information about this release, check out this topic.
    Problem with ip whitelist
    Troubleshooting
    5180
    • O
      ottobot last edited by
      I picked up a new SD card today, and did a clean install from scratch on my wife’s mirror. Now all of the sudden I am having problems connecting via port 8080 from any other device. I downloaded all of the modules that were on the old SD and literally copy/pasted the config.js so I’m not sure what got broken in the transition. Here is the whitelist rule:
      var config = {
      	port: 8080,
      	ipWhitelist: ["127.0.0.1", "::ffff:192.168.1.1/120", "::ffff:127.0.0.1", "::1"],
      	language: 'en',
      	timeFormat: 24,
      	units: 'imperial',
      Mykle1 1 Reply Last reply Reply Quote 0
      • Mykle1
        Mykle1 Project Sponsor Module Developer @ottobot last edited by
        @ottobot
        Here’s mine. It works, if you care to give it a try
        var config = {
        	port: 8080,
        	ipWhitelist: ["::fff:0.0.0.0/1", "::fff:128.0.0.0/2", "::fff:192.0.0.0/3",
        			"::fff:224.0.0.0/4", "127.0.0.1", "::ffff:127.0.0.1", "::1"],
        • O
          Still no dice. It’s weird. Literally nothing changed config wise. Just the SD card. The mirror works, and I can get to it via ssh. For some reason though I can’t get to it in a browser from any other computer on my network.
            A Former User last edited by
            It may have been setup as a new device on your network with a different IP address due to the clean install.
            For example, if you were previously previewing the mirror at 192.168.1.2:8080, it could have been reassigned to something like 192.168.1.7:8080.
            Check your router LAN settings to see what IP address has been assigned to it.
            • Cato
              Cato Module Developer last edited by
              I’ve noticed that if there is an error in the config.js, I’ll get the an access denied error.
              Have you checked the logs? Try connecting using SSH and run something like pm2 restart mm | pm2 logs mm and watch the log carefully. If it really is an access error, the log will tell you.
              My mirror: Blog
              My modules: MMM-MotionEye | MMM-YrMeteogram | MMM-Ruter | MMM-SpotifyConnectUI
              • O
                ottobot @Guest last edited by
                @leadfarmer router has the address reserved
                • O
                  ottobot @Cato last edited by
                  @Cato I’m running it on a zero, so no pm2 sadly. I’m going to try another fresh install on another SD card on another zero when I get home from work today and see if I can reproduce it or if it’s just a weird hiccup.
                  • R
                    roramirez Core Contributors @ottobot last edited by
                    If you have troubles with range, IP, etc… Can set ipWhitelist: [] to allow all IP addresses.
                    Warning, this enables from everywhere (on your net) have access.
                    Easy module development with MagicMirror Module Template
                    Cato O Mykle1 3 Replies Last reply Reply Quote 3
                    • Cato
                      Cato Module Developer @roramirez last edited by
                      @roramirez Cool, didn’t know that! 🙂
                      My mirror: Blog
                      • O
                        ottobot @roramirez last edited by
                        @roramirez Nice! Worked perfect. Thank you.
