    Problem with ip whitelist
    13 Posts 5 Posters 8.8k Views 5 Watching
    • O Offline
      ottobot
      I picked up a new SD card today, and did a clean install from scratch on my wife’s mirror. Now all of the sudden I am having problems connecting via port 8080 from any other device. I downloaded all of the modules that were on the old SD and literally copy/pasted the config.js so I’m not sure what got broken in the transition. Here is the whitelist rule:
      var config = {
      	port: 8080,
      	ipWhitelist: ["127.0.0.1", "::ffff:192.168.1.1/120", "::ffff:127.0.0.1", "::1"],
      	language: 'en',
      	timeFormat: 24,
      	units: 'imperial',
        Mykle1 Project Sponsor Module Developer @ottobot
        @ottobot
        Here’s mine. It works, if you care to give it a try
        var config = {
        	port: 8080,
        	ipWhitelist: ["::fff:0.0.0.0/1", "::fff:128.0.0.0/2", "::fff:192.0.0.0/3",
        			"::fff:224.0.0.0/4", "127.0.0.1", "::ffff:127.0.0.1", "::1"],
        • O Offline
          ottobot
          Still no dice. It’s weird. Literally nothing changed config wise. Just the SD card. The mirror works, and I can get to it via ssh. For some reason though I can’t get to it in a browser from any other computer on my network.
            A Former User
            It may have been setup as a new device on your network with a different IP address due to the clean install.
            For example, if you were previously previewing the mirror at 192.168.1.2:8080, it could have been reassigned to something like 192.168.1.7:8080.
            Check your router LAN settings to see what IP address has been assigned to it.
            • CatoC Offline
              Cato Module Developer
              I’ve noticed that if there is an error in the config.js, I’ll get the an access denied error.
              Have you checked the logs? Try connecting using SSH and run something like pm2 restart mm | pm2 logs mm and watch the log carefully. If it really is an access error, the log will tell you.
              • O Offline
                ottobot @Guest
                @leadfarmer router has the address reserved
                • O Offline
                  ottobot @Cato
                  @Cato I’m running it on a zero, so no pm2 sadly. I’m going to try another fresh install on another SD card on another zero when I get home from work today and see if I can reproduce it or if it’s just a weird hiccup.
                    roramirez Core Contributors @ottobot
                    If you have troubles with range, IP, etc… Can set ipWhitelist: [] to allow all IP addresses.
                    Warning, this enables from everywhere (on your net) have access.
                    CatoC O Mykle1M 3 Replies Last reply Reply Quote 3
                    • CatoC Offline
                      Cato Module Developer @roramirez
                      @roramirez Cool, didn’t know that! :)
                      • O Offline
                        ottobot @roramirez
                        @roramirez Nice! Worked perfect. Thank you.
