    Problem with ip whitelist
    13 Posts 5 Posters 10.3k Views 5 Watching
    • O Offline
      ottobot
      Still no dice. It’s weird. Literally nothing changed config wise. Just the SD card. The mirror works, and I can get to it via ssh. For some reason though I can’t get to it in a browser from any other computer on my network.
        [[global:former-user]]
        It may have been setup as a new device on your network with a different IP address due to the clean install.
        For example, if you were previously previewing the mirror at 192.168.1.2:8080, it could have been reassigned to something like 192.168.1.7:8080.
        Check your router LAN settings to see what IP address has been assigned to it.
          Cato Module Developer
          I’ve noticed that if there is an error in the config.js, I’ll get the an access denied error.
          Have you checked the logs? Try connecting using SSH and run something like pm2 restart mm | pm2 logs mm and watch the log carefully. If it really is an access error, the log will tell you.
          • O Offline
            ottobot @Guest
            @leadfarmer router has the address reserved
            • O Offline
              ottobot @Cato
              @Cato I’m running it on a zero, so no pm2 sadly. I’m going to try another fresh install on another SD card on another zero when I get home from work today and see if I can reproduce it or if it’s just a weird hiccup.
                roramirez Core Contributors @ottobot
                If you have troubles with range, IP, etc… Can set ipWhitelist: [] to allow all IP addresses.
                Warning, this enables from everywhere (on your net) have access.
                C O Mykle1M 3 Replies Last reply Reply Quote 3
                  Cato Module Developer @roramirez
                  @roramirez Cool, didn’t know that! :)
                  • O Offline
                    ottobot @roramirez
                    @roramirez Nice! Worked perfect. Thank you.
                      Mykle1 Project Sponsor Module Developer @roramirez
                      @roramirez said in Problem with ip whitelist:
                      For a novice like myself, that’s a whole lot easier than trying to figure this out:
                      ipWhitelist: ["::fff:0.0.0.0/1", "::fff:128.0.0.0/2", "::fff:192.0.0.0/3",
                      			"::fff:224.0.0.0/4", "127.0.0.1", "::ffff:127.0.0.1", "::1"],
                      :clap_tone1:
                        roramirez Core Contributors @Mykle1
                        @Mykle1 Yes, It’s a problem I can see from a time ago. It’s difficult for some users understood rules /24 /32 /etc . I’m not saying “you go to hell because you not understand it” … generally to myself is hard identified what it is one or other. Every time I see https://en.wikipedia.org/wiki/IPv4_subnetting_reference ;)
                        I have proposed add a note
                        https://github.com/MichMich/MagicMirror/pull/759
                        In a future it should be by default.
                          Good idea! BTW, you all do an excellent job here and I am very grateful. Thank you. :thumbsup_tone1:
