    Modules won't appear when I insert MMM-Facial-Recognition module
    7 Posts 3 Posters 3.7k Views 3 Watching
      angie2601
      Hello everyone I finally managed to solve problems regarding facial recognition. It detects ppl’s face very well.
      However, the problem is when I insert this module, other modules(default modules) dissapear but weather forecast.
      like this picture below. Every modules worked perfectly without MMM-Facial-Recognition.
      This is what happens when I do npm start without MMM-Facial-Recognition module, but ( default modules and mm-music-player, mm-hide-all,calendar_monthly module) in the MagicMirror.
      > magicmirror@2.1.0 start /home/pi/MagicMirror
      > electron js/electron.js
      Starting MagicMirror: v2.1.0
      Loading config ...
      Loading module helpers ...
      Initializing mm-music-player module helper ...
      No helper found for module: calendar_monthly.
      No helper found for module: mm-hide-all.
      All module helpers loaded.
      Starting server op port 8080 ...
      Server started ...
      Connecting socket for: mm-music-player
      Starting module: newsfeed
      Launching application.
      Create new calendar fetcher for url: http://www.calendarlabs.com/templates/ical/SouthKorea-Holidays.ics - Interval: 300000
      Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
      and this is what happens when I add MMM-Facial-Reconition module with above modules
      Loading config ...
      Server started ...
      Connecting socket for: MMM-Facial-Recognition
      Staring module helper: MMM-Facial-Recognition
      [MMM-Facial-Recognition] Facerecognition started...
      [MMM-Facial-Recognition] Loading training data...
      [MMM-Facial-Recognition] ALGORITHM: LBPH
      [MMM-Facial-Recognition] Training data loaded!
      [MMM-Facial-Recognition] --------------------
      [MMM-Facial-Recognition] PiCam ausgew채hlt...
      [MMM-Facial-Recognition] User undefined with confidence null logged in.
      [MMM-Facial-Recognition] User undefined logged out.
      ^C[MMM-Facial-Recognition] Shutdown: Cleaning up camera...
      How can I make the other modules be displayed well regardless of the MMM-Facial-Recognition added or not?
      Thanks for reading this!
      • yawnsY Offline
        yawns Moderator
        If you launch the browser, press F12 and look for any errors in console, what do you see?
        A H 3 Replies Last reply Reply Quote 0
          angie2601 @yawns
          @yawns tnx alot! I launched it with Chromium and it says there are 4 errors.
          Here is my Console.
            angie2601 @yawns
            This post is deleted!
            • H Offline
              HC @yawns
              @yawns I’m having a same problem like @angie2601’s
              If you have any idea of solving it , plz let me know :)
              This is my console
              yawnsY 1 Reply Last reply Reply Quote 0
              • H Offline
                HC
                @Jopyth @paviro Thanks for your help last time! I’m having a problem with emerging MMM-Facial-Reconition module and other modules, detailed are like the above. Thanks alot!!
                • yawnsY Offline
                  yawns Moderator @HC
                  @HC
                  Why are you opening the html file? You should start magicmirror with node serveronly and direct your browser to http://localhost:8080 or you should run npm start which will launch the browser on its own
