    PIR-Sensor - put your mirror to sleep if not used
    126 Posts 37 Posters 235.0k Views 20 Watching
      murattyilmaz
      Hello,
      I’ve installed this module and sensor to my pi but I’m facing an issue.
      When I start the app, its loading as expected and show everything normally.
      After 5 sec. my monitor goes to sleep and says me “no signal” even if I shake may hand front of it.
      Then monitor blink a few times and seems like open but nothing to show or said.
      After this situation, never comes to live back and can’t close or shut down the app (can’t go back to OS screen). I have to shut the power to reset my pi.
      Do you have any idea why this happens?
        McSorley
        Any ETA on when the update will occur for removing the wiring-pi dependency? I wouldn’t like going down to a lower version of Node.js for this to work encase I break the whole thing.
        • paviroP Offline
          paviro
          Sorry no :/ I just started a new job/school and I do not currently have a mirror setup :( but it should really not be that hard to do so feel free to just try! You can use onoff there is an example which would not need to be changed much to replace wiring Pi in my code :)
          If you succeed please send a pull request!
          Edit: If I find some time this evening I will try to do it but you will have to test as again I don’t have a mirror currently.
          We're all stories in the end. Just make it a good one, eh?
          – The Doctor
          • paviroP Offline
            paviro
            Double post so you get notified: Done feel free to try :) don’t forget to reinstall the module with npm install!
            – The Doctor
            MitchfarinoM 1 Reply Last reply Reply Quote 0
            • MitchfarinoM Offline
              Mitchfarino Module Developer @paviro
              @paviro So it works with node 6 now?
              paviroP 1 Reply Last reply Reply Quote 0
              • paviroP Offline
                paviro @Mitchfarino
                @Mitchfarino if it still works at all yes :)
                – The Doctor
                • paviroP Offline
                  paviro
                  Now it should definitely work :)
                  – The Doctor
                    shgmongohh @murattyilmaz
                    @murattyilmaz
                    I have the same issue. Does anybody have a solution for this problem?
                    • C Offline
                      cpramhofer
                      I´m playing around with PIR and after reinstalling npm it seems to work.
                      the only problem is that my monitor is switching on and off every couple of seconds.
                      do you guys have a picture of how your sensor is setup (Poti, Trigger Jumper)?
                      thanks a lot!
                      E 1 Reply Last reply Reply Quote 1
                        DirkS
                        i have some issue with the PIR Module. It worked for testing a couple of month but now under productive operation it doesn’t :(
                        The Screen is switched off and on correctly but after a unspecified time it doesn’t switch it on anymore, it stays black. Sometimes after an hour sometimes after a couple of minutes.
                        The PIR itself is working correctly as i discovered, i’m also getting it’s state under FHEM and there i can see the relaible functionality of it. I connected it to the GPIO 21.
                        As i can see on the screen it doesn’t get any video input anymore. Only rebooting the PI2 will fix it.
                        I’m not sure where to search :(
                        Some startup log entrie doesn’t show anything.
                        > magicmirror@2.0.0 start /home/pi/MagicMirror
                        > electron js/electron.js
                        Loading config ...
                        Loading module helpers ...
                        All module helpers loaded.
                        Starting server op port 8080 ...
                        Server started ...
                        Connecting socket for: MMM-FHEM
                        Connecting socket for: MMM-PIR-Sensor
                        Starting module: newsfeed
                        Launching application.
                        AlessandroRaA 1 Reply Last reply Reply Quote 0
                        • 9
                        • 10
                        • 11
                        • 12
                        • 13
                        • 11 / 13
