    PIR-Sensor - put your mirror to sleep if not used
    126 Posts 37 Posters 235.0k Views 20 Watching
    • AlessandroRaA Offline
      AlessandroRa @yawns
      @yawns thank you, that solved it! Now I need to understand why nothing happens even if I wave in front of the sensor…
      I’m starting to think that the PIR sensor doesn’t work
      • T Offline
        Them Russians
        Hey all,
        I am a relative novice when it comes to the Pi, and have been trying to identify why I am unable to install the dependencies via “npm install”.
        I cloned the repository into my “modules” folder via the “git clone…” command (Step 1).
        I then navigated into the new “MMM-PIR-Sensor” folder and ran “npm install”.
        However, I got an error during the install suggesting I have an issue with electron-rebuild. Is anyone familiar with what could cause this error to be thrown, and what I could do to resolve it?
        Here is the error:
        Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall /home/pi/MagicMirror/modules/MMM-PIR-Sensor
        electron-rebuild -e …/…/node_modules/electron-prebuilt
        An unhandled error occurred inside electron-rebuild
        Unable to find electron-prebuilt’s version number, either install it or specify an explicit version
        Error: Unable to find electron-prebuilt’s version number, either install it or specify an explicit version
        at _callee$ (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/cli.js:74:17)
        at tryCatch (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/regenerator-runtime/runtime.js:63:40)
        at GeneratorFunctionPrototype.invoke [as _invoke] (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/regenerator-runtime/runtime.js:337:22)
        at GeneratorFunctionPrototype.prototype.(anonymous function) [as next] (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/regenerator-runtime/runtime.js:96:21)
        at GeneratorFunctionPrototype.tryCatcher (/home/pi/node_modules/bluebird/js/release/util.js:16:23)
        at PromiseSpawn._promiseFulfilled (/home/pi/node_modules/bluebird/js/release/generators.js:97:49)
        at /home/pi/node_modules/bluebird/js/release/generators.js:201:15
        at Object. (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/cli.js:197:4)
        at Module._compile (module.js:570:32)
        at Object.Module._extensions…js (module.js:579:10)
        at Module.load (module.js:487:32)
        at tryModuleLoad (module.js:446:12)
        at Function.Module._load (module.js:438:3)
        at Module.runMain (module.js:604:10)
        at run (bootstrap_node.js:394:7)
        at startup (bootstrap_node.js:149:9)
        npm ERR! Linux 4.4.38-v7+
        npm ERR! argv “/usr/bin/nodejs” “/usr/bin/npm” “install”
        npm ERR! node v6.9.2
        npm ERR! npm v3.10.9
        npm ERR! code ELIFECYCLE
        npm ERR! Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall: electron-rebuild -e ../../node_modules/electron-prebuilt
        npm ERR! Exit status 255
        npm ERR!
        npm ERR! Failed at the Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall script ‘electron-rebuild -e …/…/node_modules/electron-prebuilt’.
        npm ERR! If you do, this is most likely a problem with the Magic-Mirror-Module-PIR-Sensor package,
        npm ERR! not with npm itself.
        npm ERR! electron-rebuild -e …/…/node_modules/electron-prebuilt
        npm ERR! npm bugs Magic-Mirror-Module-PIR-Sensor
        npm ERR! Or if that isn’t available, you can get their info via:
        npm ERR! npm owner ls Magic-Mirror-Module-PIR-Sensor
        npm ERR! /home/pi/MagicMirror/modules/MMM-PIR-Sensor/npm-debug.log
        • E Offline
          elmerito25 @cpramhofer
          @cpramhofer Were you able to fix your problem?
          • N Offline
            Nususu @jrleeman
            @jrleeman Hi I have the same issue that you do with the on signal only being put out for about a second after motion detection. Did you ever find a way to make the mirror stay awake for longer with the timer being reset by any motion signal?
            • T Offline
              Them Russians @Nususu
              @Nususu Did you have any issues with the npm install of this module? I am still unable to install the module :(
                Jopyth Moderator
                Please continue discussion about install issues here. There is already info on how it can be solved. For other problems with the PIR-Sensor Module please open a new thread in the troubleshooting section.
                Helpful sticky: How to troubleshoot
                • 9
                • 10
                • 11
                • 12
                • 13
                • 13 / 13
