    PIR-Sensor - put your mirror to sleep if not used
    126 Posts 37 Posters 244.6k Views 20 Watching
    • paviroP Offline
      paviro @Bangee
      @Bangee Wait! That’s just all modules logging they received the notification, thats probably the same message over and over again logged by different modules.
      We're all stories in the end. Just make it a good one, eh?
      – The Doctor
      • BangeeB Offline
        Bangee Module Developer
        @paviro will there be any chance to log what information the sensor is returning?
        I’m not sure why my screen is alway going on and off, but i’ll get nervous…
        paviroP 1 Reply Last reply Reply Quote 0
        • paviroP Offline
          paviro @Bangee
          @Bangee Sure in the node_helper.js find the comment Detected movement and add console.log() so that it looks like the following:
          gpio.wiringPiISR(this.config.sensorPIN, gpio.INT_EDGE_BOTH, function(delta) {
                  console.log(gpio.digitalRead(self.config.sensorPIN))
          – The Doctor
          BangeeB 1 Reply Last reply Reply Quote 0
            jrleeman @paviro
            @paviro I dug out a junk-box PIR sensor. Everything is installed and no white-screen problems, but this sensor only puts out an “on” signal for about a second after motion is detected. Any way to make the mirror stay awake for some time (say 2-5 minutes) with that timer being reset on any motion signal? Then if nobody is in front of the mirror for awhile it goes off. Currently mine flickers off and on, not the ideal behavior.
            • paviroP Offline
              paviro @jrleeman
              @jrleeman you should be able to change that by modifying the PIR-Sensor mine has the possibility to exactly adjust that :)
              – The Doctor
              • MichMichM Offline
                MichMich
                For the record: node 6.1.0 is supported.
                • paviroP Offline
                  paviro @MichMich
                  @MichMich is it? Not sure I think one dependencies of THIS plugin does not support it, yet :/
                  – The Doctor
                  MichMichM 1 Reply Last reply Reply Quote 0
                  • MichMichM Offline
                    MichMich @paviro
                    @paviro ah sorry. Throught you were talking about mm2 in general.
                    • BangeeB Offline
                      Bangee Module Developer @paviro
                      @paviro i’ve added the console.log as you described, but there is no log output in firebug. where can I check this log elsewhere?
                      • paviroP Offline
                        paviro @Bangee
                        @Bangee it is node output! You have to check the log of the backend :)
                        – The Doctor
                        • BangeeB Offline
                          @paviro sorry, i’m still a node noob… how can I check this? ;-)
                          • paviroP Offline
                            paviro @Bangee
                            @Bangee how do you start your mirror?
                            – The Doctor
                            • BangeeB Offline
                              @paviro
                              pm2 start mm
                              • paviroP Offline
                                paviro @Bangee
                                @Bangee in that case read the wiki ;)
                                – The Doctor
                                • BangeeB Offline
                                  Funny…
                                  pi@raspberrypi:~ $ tail -f /home/pi/.pm2/logs/mm-out-0.log
                                  GIPO Status:1
                                  GIPO Status:0
                                  GIPO Status:1
                                  GIPO Status:0
                                  GIPO Status:1
                                  GIPO Status:0
                                  GIPO Status:1
                                  GIPO Status:0
                                  GIPO Status:1
                                  GIPO Status:0
                                    jrleeman @paviro
                                    @paviro The sensor I’ve got doesn’t have any adjustments on it. I suppose I can make little timed latch in hardware to add on, but it could be nice to do in software too.
                                    • paviroP Offline
                                      paviro @jrleeman
                                      @jrleeman feel free to send a pull request! :) the sensor I use cost 3€ do I don’t really see a reason to do it in software of the sensors are that cheap :smiley:
                                      – The Doctor
                                        jrleeman @paviro
                                        @paviro Fair enough. I’ll see which I find easier, code or hardware. :smiley:
                                          sjuulbosmans
                                          @paviro
                                          Thanks for making this module. I am experiencing the same issue as @incubik as my screen turns white when I start the MM. My PIR sensor works as I tested it on the R Pi and with some LEDs and my breadboard. I have reinstalled the MM and this module but I can’t seem to get it working. I have also no idea what causes this. Do you have any thought on this?
                                          • paviroP Offline
                                            paviro @sjuulbosmans
                                            @sjuulbosmans white and black screens are mostly caused by wrong configuration. Check your web inspector!
                                            – The Doctor
                                            • 6
                                            • 7
                                            • 2 / 7
