    PIR-Sensor - put your mirror to sleep if not used
    126 Posts 37 Posters 233.6k Views 20 Watching
    • cowboysdudeC Offline
      cowboysdude Module Developer @desq
      @desq No I don’t. Sorry I went in another direction… I have a pir.py and monitor_on, monitor_off.py… it works! If you’d like the setup I’d be happy to share…
      You just start the pir.py using crontab -e then enter @reboot [point to where your pir.py is]…
      That’s it… simple and it works!
        desq @cowboysdude
        @cowboysdude
        I got it. I installed the latest node. (6.2.1) Pull MMM-PIR from the git Repository und did all the steps Paviro explains on the module page.
        And suddenly no more the white screen and the “USER_PRESENCE” notification is send every 5-6 sec.
        @paviro
        could implement a parameter to set the duration for a monitor shutdown as no USER_PRESENCE is detected?
        cowboysdudeC 1 Reply Last reply Reply Quote 1
          Jaghova
          A stupid question, where “USER_PRESENCE” notification must appear? in ‘PM2 logs mm’ ??
          If so, It doesn’t appear in my logs, which means I don’t have the module correctly installed right?
          But if i check on ‘GPIO readall’ I can see how the IN is activated and also the OUT relay when it detects presence
            @desq I’m not using the mmm-PIR I’m using something else… BUT I do know from reading that it wasn’t working with node V6… you had to roll back to V5.
            I still had trouble with v5 so I went with something else…
              desq @cowboysdude
              @cowboysdude mh… I really would like to stick with paviros module.
              “USER_PRESENCE” (PIR Sensor) seems to work, but my Relay does not change it´s state.
              @paviro can you confirm, that your PIR module doesn´t work with node 6.22?
              If so I must switch to that python-script-hell.
              • paviroP Offline
                paviro
                @desq sorry no idea :D haven’t touched it in a while since I am pretty busy at the moment (finished school, now moving to a new city at the other side of the country). Could be possible that my dependencies work with v6 now but I still need to update it and change some stuff once I have the time :)
                What exactly do you mean by duration? A delay? My PIR-Sensor can do that in hardware thats why I haven’t implemented it.
                We're all stories in the end. Just make it a good one, eh?
                – The Doctor
                Wilco89W 1 Reply Last reply Reply Quote 0
                • X Offline
                  xdker
                  This post is deleted!
                  • Wilco89W Offline
                    Wilco89 @paviro
                    @paviro got a complete White screen and no posibility to use vnc. Got there the Same White screen and no option to open terminal anybody a solution so i can disable the module?
                    KirAsh4K 1 Reply Last reply Reply Quote 0
                    • KirAsh4K Offline
                      KirAsh4 Moderator @Wilco89
                      @Wilco89, use SSH to log into it, user 'pi', password 'raspberry' unless you changed it to something else. Edit the config file, reboot the rpi.
                      • Wilco89W Offline
                        Wilco89 @KirAsh4
                        @KirAsh4 didn’t think about that. Oops
                        • 8
                        • 9
                        • 10
                        • 11
                        • 12
                        • 13
                        • 10 / 13
