    PIR-Sensor - put your mirror to sleep if not used
    126 Posts 37 Posters 235.0k Views 20 Watching
      joerod @paviro
      @paviro
          9 verbose stack Error: magicmirror@2.0.0 start: `electron js/electron.js`
          9 verbose stack Exit status 1
          9 verbose stack     at EventEmitter.<anonymous> (/usr/local/lib/node_modules/npm/lib/utils/lifecycle.js:214$
          9 verbose stack     at emitTwo (events.js:87:13)
          9 verbose stack     at EventEmitter.emit (events.js:172:7)
          9 verbose stack     at ChildProcess.<anonymous> (/usr/local/lib/node_modules/npm/lib/utils/spawn.js:24:14)
          9 verbose stack     at ChildProcess.emit (events.js:172:7)
          9 verbose stack     at maybeClose (internal/child_process.js:817:16)
          9 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:211:5)
      I’ve tested my PIR sensor with a Python script to make sure I’m using the proper GPIO and its functioning as it should. I do see 1 & 0 when I move near the sensor so I don’t think its the hardware.
      I’d love to use this module, I was going to do it in python but since you have it in JS I figured why not use that.
      paviroP 1 Reply Last reply Reply Quote 0
      • paviroP Offline
        paviro @joerod
        @joerod please use Markdown on code snippets so it is easier to read! :) have you installed all the dependencies (also for the mirror itself?)
        @MichMich any idea?
        We're all stories in the end. Just make it a good one, eh?
        – The Doctor
        • MichMichM Offline
          MichMich
          Sorry, no clue. :(
            joerod @paviro
            @paviro I had to downgrade to node 5.0.0, I confirmed its that version of node. After the downgrade I removed the PIR module and did a git clone and then npm install in the folder. Still the same thing, is there a specific version of node 5 I should be using or a specific version of npm?
            I’m running it from
            /home/pi/MagicMirror/modules/MMM-PIR-Sensor
            • MichMichM Offline
              MichMich
              Could you try it with node serveronly ?
              • paviroP Offline
                paviro @joerod
                @joerod also do npm install on the mm folder or install the whole thing from scratch :)
                – The Doctor
                  DirkS @paviro
                  @paviro as a feedback: i used the latest MMM branch and yours and it is working fine with my PIR sensor on a rpi2. I didn’t had to downgrade anything to node 5 (and i also don’t know what it is :D ) Thanks for your work. It is so great that the mirror is starting if a presence is detected!!
                  • paviroP Offline
                    paviro @DirkS
                    @DirkS glad to hear! :)
                    – The Doctor
                      MechMatt
                      Hey Everyone!
                      I am trying to use this module to turn off/on a tv and im having a bit of trouble on the physical end of things… I got the module working perfectly (tested it with PIR and hdmi on/off). Now I am trying to use a relay with the PIR sensor to have the TV screen itself turn on and off. I was planning on wiring this to the TV power button (so it is essentially the same as pressing the on/off button).
                      I got the relay working… and I was about to take apart my tv when i thought…will even work for the on/off button? When it senses movement it will send the signal and then … turn off the tv I guess. As soon as the movement is undetected it stops sending the signal (or really pulse in this case)… just stopping wouldn’t turn the tv back on either. I guess it needs to send a pulse when it stops detecting movement, and then another one when it does again. Am I thinking about this wrong? Should I wire it to something else? Thanks in advance
                        MechMatt @MechMatt
                        @MechMatt On second thought, im having trouble with the relay as well… could you post a wiring diagram for the pi, relay, and tv? I’m not the best at electronics
                        • 6
                        • 7
                        • 8
                        • 9
                        • 10
                        • 11
                        • 12
                        • 13
                        • 8 / 13
