    PIR-Sensor - put your mirror to sleep if not used
    126 Posts 37 Posters 252.3k Views 20 Watching
      murattyilmaz
      Hello,
      I’ve installed this module and sensor to my pi but I’m facing an issue.
      When I start the app, its loading as expected and show everything normally.
      After 5 sec. my monitor goes to sleep and says me “no signal” even if I shake may hand front of it.
      Then monitor blink a few times and seems like open but nothing to show or said.
      After this situation, never comes to live back and can’t close or shut down the app (can’t go back to OS screen). I have to shut the power to reset my pi.
      Do you have any idea why this happens?
        McSorley
        Any ETA on when the update will occur for removing the wiring-pi dependency? I wouldn’t like going down to a lower version of Node.js for this to work encase I break the whole thing.
        • P Offline
          paviro
          Sorry no :/ I just started a new job/school and I do not currently have a mirror setup :( but it should really not be that hard to do so feel free to just try! You can use onoff there is an example which would not need to be changed much to replace wiring Pi in my code :)
          If you succeed please send a pull request!
          Edit: If I find some time this evening I will try to do it but you will have to test as again I don’t have a mirror currently.
          – The Doctor
          • P Offline
            paviro
            Double post so you get notified: Done feel free to try :) don’t forget to reinstall the module with npm install!
            – The Doctor
              Mitchfarino Module Developer @paviro
              @paviro So it works with node 6 now?
              • P Offline
                paviro @Mitchfarino
                @Mitchfarino if it still works at all yes :)
                – The Doctor
                • P Offline
                  paviro
                  Now it should definitely work :)
                  – The Doctor
                    shgmongohh @murattyilmaz
                    @murattyilmaz
                    I have the same issue. Does anybody have a solution for this problem?
                    • C Offline
                      cpramhofer
                      I´m playing around with PIR and after reinstalling npm it seems to work.
                      the only problem is that my monitor is switching on and off every couple of seconds.
                      do you guys have a picture of how your sensor is setup (Poti, Trigger Jumper)?
                      thanks a lot!
                      E 1 Reply Last reply Reply Quote 1
                        DirkS
                        i have some issue with the PIR Module. It worked for testing a couple of month but now under productive operation it doesn’t :(
                        The Screen is switched off and on correctly but after a unspecified time it doesn’t switch it on anymore, it stays black. Sometimes after an hour sometimes after a couple of minutes.
                        The PIR itself is working correctly as i discovered, i’m also getting it’s state under FHEM and there i can see the relaible functionality of it. I connected it to the GPIO 21.
                        As i can see on the screen it doesn’t get any video input anymore. Only rebooting the PI2 will fix it.
                        I’m not sure where to search :(
                        Some startup log entrie doesn’t show anything.
                        > magicmirror@2.0.0 start /home/pi/MagicMirror
                        > electron js/electron.js
                        Loading config ...
                        Loading module helpers ...
                        All module helpers loaded.
                        Starting server op port 8080 ...
                        Server started ...
                        Connecting socket for: MMM-FHEM
                        Connecting socket for: MMM-PIR-Sensor
                        Starting module: newsfeed
                        Launching application.
                        • P Offline
                          phrazelle
                          Thanks for the module - this is fantastic!
                          I have a PIR sensor attached and it works as desired, but when the HDMI signal is cut to the TV, I get a “No Signal” message on the screen from the TV itself because the RPi isn’t sending signal anymore.
                          I’m wondering what the best solution would be. My head goes to hiding all modules instead of turning the monitor off so MM is still on but a completely black screen, or somehow send the RPi into a sleep state but keep the HDMI active.
                          Has anyone else tackled this issue?
                            McSorley @phrazelle
                            @phrazelle The idea behind it is so that when the HDMI is disabled you would get the no signal. You then set up the TV/Monitor to go to sleep if no signal is found.
                            Check your TV manual for power saving settings.
                            • P Offline
                              phrazelle @McSorley
                              @McSorley Thanks for the response!
                              Unfortunately my TV doesn’t have a sleep mode option. It automatically displays the No Signal message and turns off after a few minutes of no signal. To make that more difficult, if the TV is turned back on with the remote, it loses the resolution settings and blows everything up until the RPi is rebooted.
                              I’m not sure how to address this, but I think it would be ideal in my circumstance to have this module, but triggered by the PIR sensor. Idk if I can finagle that, but I suppose I can give it a shot.
                              • N Offline
                                nem1
                                Do we still have this problem with the node version? (v5 works, 6 not)
                                  bibi
                                  @phrazelle hi! did you find a way to disable this message? i have the same annoying one :)
                                  • P Offline
                                    phrazelle @bibi
                                    @bibi Yes! Here is the post I submitted around the new module. Remember that you still need the MMM-PIR-Sensor module by paviro installed for this to work.
                                      bibi @phrazelle
                                      @phrazelle interesting! thx a lot will check this :)
                                        AlessandroRa @DirkS
                                        Yay! I’ve finally solved my blank screen issue, now I’ve the same problem as @DirkS… After a while the screensaver activates, the screen becomes dark and even if I wave in front of the sensor the mirror doesn’t go on again…
                                        @paviro any idea why?
                                          AlessandroRa
                                          Nevermind, I’m back on the white page problem… It keeps saying “Error: Module version mismatch. Expected 50, got 51”
                                          I tried either: npm rebuild --runtime=electron --target=1.4.0 --disturl=https://atom.io/download/atom-shell --build-from-source
                                          and: npm rebuild --runtime=electron --target=1.4.5 --disturl=https://atom.io/download/atom-shell --abi=50
                                          but it doesn’t change…
                                          • Y Offline
                                            yawns Moderator @AlessandroRa
                                            @AlessandroRa
                                            Please run npm list and check for your electron version. Then rerun the command you already tried with the right version number
                                            • 6
                                            • 7
                                            • 6 / 7
