    Blackscreen after install MMM-PIR-Sensor
    15 Posts 5 Posters 9.3k Views 4 Watching
      Blackmirror
      Hello,
      it’s my first entry here.
      I will start to build a MagicMirror and I have a Problem with the MMM-PIR_Sensor Modul.
      I have installed and have no problems at the install, but will the Mirror start I see only a black screen. When I move the mouse at the raspberry I can see the mouse arrow.
      When I unmarker the PIR-Module lines in the config.js . I can see the normal Mirror.
      • cowboysdudeC Offline
        cowboysdude Module Developer
        post your config.js minus any keys so we can take a peek…
          Blackmirror
          Here, but I think it is not a problem with the config.js, because when I have the module in the config.js include and deinstall the module in Magicmirror/modules I can see the Mirror:
          var config = {
                  port: 8080,
                  ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],
                  language: 'de',
                  timeFormat: 24,
                  units: 'metric',
                                  module: 'alert',
          //              module: 'MMM-PIR-Sensor',
          //              config: {
          //              relayGpio: '26',
          //              relayOnState: '0',
          //              powerSaving: false,
          //                      // See 'Configuration options' for more information.
                      module: 'MMM-Carousel',
                          transitionInterval: 10000,
                          ignoreModules: [],
                          mode: 'positional',
                          top_right: {enabled: true, ignoreModules: [], overrideTransitionInterval: 15000}
                                  module: "updatenotification",
                                  position: "top_bar"
                          module: 'MMM-FRITZ-Box-Callmonitor',
                          //position: 'top_bar',  // This can be any of the regions. Best results in left or right regions.
                          //header: "Recent calls", // This is optional
                          config: { password: 'xxx'
                          module: 'MMM-Callmonitor-Current-Call',
                          //header: "Active Calls", // This is optional
                                  module: 'clock',
                                  position: 'top_left'
                              module: 'MMM-DHT22',
                                  position: 'top_left',
                                sensorPIN: 22,
                                 updateInterval: 0.5, // Minutes
                                  module: 'currentweather',
                                          locationID: 'xxx',  //ID from http://www.openweathermap.org
                                          appid: 'xxx'
                  module: 'MMM-Traffic',
                  classes: 'dimmed medium', //optional, default is 'bright medium', only applies to commute info not route_name
                          api_key: 'xxx',
                          mode: 'driving',
                          origin: 'xxx',
                          destination: 'xxx',
                          //arrival_time: '0800', //optional, but needs to be in 24 hour time if used.
                          route_name: 'xxx',
                          changeColor: true,
                          showGreen: false,
                          limitYellow: 5, //Greater than 5% of journey time due to traffic
                          limitRed: 20, //Greater than 20% of journey time due to traffic
                          traffic_model: 'pessimistic',
                          interval: 120000, //2 minutes
                          showWeekend: true,
                          allTime: true,
                                  module: 'calendar',
                                  header: 'Termine',
                                  position: 'top_right',
                                                          symbol: 'calendar-check-o ',
                                                          url: 'xxxs',
                                                          maximumEntries: '5'
                              module: "MMM-Fuel",
                                  api_key: "xxx",
                          lat: xxx,
                                  lng: xxx,
                                   types: ["diesel"],
                                  max: 2,
                                  rotate: false,
                                  colored: true,
                                  open: true
          //                               module: 'MMM-Wunderlist',
          //                      position: 'top_right',  // This can be any of the regions. Best results in left or right regions.
          //                      header: 'Wunderlist', // This is optional
          //                      config: {
                                  module: 'weatherforecast',
                                  header: 'Weather Forecast',
                                          appid: 'xxx'
          //                      module: 'newsfeed',
          //                      position: 'bottom_bar',
          //                      config: {
          //                              feeds: [
          //                                              title: "xxx",
          //                                              url: "xxxl"
          //                              showSourceTitle: true,
          //                              showPublishDate: true
            @Blackmirror said in Blackscreen after install MMM-PIR-Sensor:
            // module: ‘MMM-PIR-Sensor’,
            // config: {
            // relayGpio: ‘26’,
            // relayOnState: ‘0’,
            // // See ‘Configuration options’ for more information.
            Right off the top here is an issue :) should only have one }, :) Like this below…
            It has too many }, so it’s stopping at the first one then errors out because it goes to the next }, as a new line and that creates your problem. :)
            relayGpio: ‘26’,
            relayOnState: ‘0’,
            powerSaving: false,
              Blackmirror @cowboysdude
              @cowboysdude
              No, this is not the problem, I have unlined this, because I can not use the Mirror, when I delete the // I see the black screen.
              It’s my fault to show the config.js this the //.
                Blackmirror
                I have it remove and make a new installation, after this it comes errors:
                pi@Mirror:~/MagicMirror/modules/MMM-PIR-Sensor $ sudo npm install -g
                epoll@0.1.21 install /usr/lib/node_modules/Magic-Mirror-Module-PIR-Sensor/node_modules/epoll
                node-gyp rebuild
                gyp WARN EACCES user “root” does not have permission to access the dev dir “/root/.node-gyp/6.10.0”
                gyp WARN EACCES attempting to reinstall using temporary dev dir “/usr/lib/node_modules/Magic-Mirror-Module-PIR-Sensor/node_modules/epoll/.node-gyp”
                make: Entering directory ‘/usr/lib/node_modules/Magic-Mirror-Module-PIR-Sensor/node_modules/epoll/build’
                CXX(target) Release/obj.target/epoll/src/epoll.o
                SOLINK_MODULE(target) Release/obj.target/epoll.node
                COPY Release/epoll.node
                make: Leaving directory ‘/usr/lib/node_modules/Magic-Mirror-Module-PIR-Sensor/node_modules/epoll/build’
                Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall /usr/lib/node_modules/Magic-Mirror-Module-PIR-Sensor
                electron-rebuild -e …/…/node_modules/electron
                sh: 1: electron-rebuild: not found
                npm ERR! Linux 4.4.50-v7+
                npm ERR! argv “/usr/bin/nodejs” “/usr/bin/npm” “install” “-g”
                npm ERR! node v6.10.0
                npm ERR! npm v3.10.10
                npm ERR! file sh
                npm ERR! code ELIFECYCLE
                npm ERR! errno ENOENT
                npm ERR! syscall spawn
                npm ERR! Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall: electron-rebuild -e ../../node_modules/electron
                npm ERR! spawn ENOENT
                npm ERR!
                npm ERR! Failed at the Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall script ‘electron-rebuild -e …/…/node_modules/electron’.
                npm ERR! If you do, this is most likely a problem with the Magic-Mirror-Module-PIR-Sensor package,
                npm ERR! not with npm itself.
                npm ERR! electron-rebuild -e …/…/node_modules/electron
                npm ERR! npm bugs Magic-Mirror-Module-PIR-Sensor
                npm ERR! Or if that isn’t available, you can get their info via:
                npm ERR! npm owner ls Magic-Mirror-Module-PIR-Sensor
                npm ERR! /home/pi/MagicMirror/modules/MMM-PIR-Sensor/npm-debug.log
                  Did you go to the module directory that the pir module is in and run ‘npm install’?
                  If not try that first.
                    Blackmirror
                    Hello,
                    I have delete the ‘,’ but I have still this problem. In the past failure in the config.js make a white screen at me.
                    And I have run ‘sudo npm install -g’ in the MMM-PIR-Sensor directory,
                    and I see this Error messages. And I have still a black screen.
                    • brobergB Offline
                      broberg Project Sponsor
                      I don’t think you are supposed to be using sudo when doing npm install just the other parts,
                      Using sudo will probably give access issues for the module.
                        Blackmirror
                        So I Have rm -rf MMM-PIR-Sensor and new install. after this I run npm install -g, is give the follow error messages
                        pi@Mirror:~/MagicMirror/modules/MMM-PIR-Sensor $ npm install -g
                        npm WARN checkPermissions Missing write access to /usr/lib/node_modules
                        /usr/lib
                        └─┬ Magic-Mirror-Module-PIR-Sensor@1.1.0
                        └─┬ onoff@1.1.2
                        └─┬ epoll@0.1.21
                        ├── bindings@1.2.1
                        └── nan@2.5.1
                        npm ERR! path /usr/lib/node_modules
                        npm ERR! code EACCES
                        npm ERR! errno -13
                        npm ERR! syscall access
                        npm ERR! Error: EACCES: permission denied, access ‘/usr/lib/node_modules’
                        npm ERR! at Error (native)
                        npm ERR! { Error: EACCES: permission denied, access ‘/usr/lib/node_modules’
                        npm ERR! errno: -13,
                        npm ERR! code: ‘EACCES’,
                        npm ERR! syscall: ‘access’,
                        npm ERR! path: ‘/usr/lib/node_modules’ }
                        npm ERR!
                        npm ERR! Please try running this command again as root/Administrator.
                        And a black screen at the mirror
