    Super nooby question- How to configure the downloaded modules and weather wont show up
    20 Posts 5 Posters 9.6k Views 4 Watching
      Mykle1 Project Sponsor Module Developer @ghaal
      @ghaal said in Super nooby question- How to configure the downloaded modules and weather wont show up:
      When I went to the config folder none of the previous edits were there.
      It sounds like you didn’t save the config.js after you edited it. Copy and paste your config.js here so we can take a look at it.
        Is it an app or an online thing, or something integrated into this forum?
        https://forum.magicmirror.builders/topic/2147/teamspeak-magic-mirror-help-desk
        I don’t know if anyone is there right now but i’ll be there 3 hours from now. If you can make it then I’ll try to help you
        • G Offline
          ghaal @Mykle1
          @Mykle1 I will, but I can’t do that until an hour or two
          • brobergB Offline
            broberg Project Sponsor @ghaal
            @ghaal this line cp config.js.sample config.js
            Copys the sample config to the config.js file and should only be done once. If you do this everytime you start your mirror you will keep replacing your config.j s file with the sample config.
            G 1 Reply Last reply Reply Quote 2
            • G Offline
              ghaal @broberg
              @broberg I don’t get it. I have not copied any file into another one (does it automatically happen?) Should I copy this file? How? I have tried editing the regular config, and haven’t touched the sample one. Should I?
              • brobergB Offline
                @ghaal you copy the sample file ONCE after you have installed the mirror software.
                But it looked like you where repeating the copy command ( cp = copy ) before you started the mirror (npm start ) and IF you do this each time, it doesn’t matter what you have saved in the config.js file since it will be overwritten each time you type in : cp config.js.sample config.js
                • G Offline
                  ghaal
                  module: “currentweather”,
                  position: “top_right”, .
                  locationID: "(my id) ",
                  appid: “my appid”
                  • G Offline
                    ghaal @ghaal
                    @ghaal that’s my weather module, but it doesn’t show up
                    • G Offline
                      ghaal @ghaal
                      @ghaal {
                      		module: "currentweather",
                      			locationID: "5359777",
                      			appid: "ee6dbcc4823bb3f9a7f26c49fa64729c"
                      		module: "weatherforecast",
                      		header: "Weather Forecast",
                      			locationID: "####",
                      			appid: "blahblahblah"
                      that’s a more accurate of focast and current, both don’t show on the magicmirror page. I made sure not to add extra spaces when removing my appid and location.
                        Here it is! You can copy and paste right from here into your config
                        			appid: "YOUR API KEY"
                        		}, // end of weatherforecast entry needs a comma
