    Super nooby question- How to configure the downloaded modules and weather wont show up
    20 Posts 5 Posters 11.1k Views 4 Watching
      Mykle1 Project Sponsor Module Developer @hartattack
      @hartattack said in Super nooby question- How to configure the downloaded modules and weather wont show up:
      should be fairly simple as pointing in the right direction
      Riiiiiggghtt! ;-)
      At least he’s up and running.
      • G Offline
        ghaal
        Sorry, I haven’t replied in like two weeks, but I ran into some major problems. My brother broke my HDMI cable while it was plugged into my monitor and I take to take off half the plastic to take the head out of the monitor. Then I had to put the plastic back on so it would fit in my frame again. I also had to order a new cable. But I’m here and ready to work on it thank you.
        • cowboysdudeC Offline
          cowboysdude Module Developer @ghaal
          @ghaal Don’t feel bad so far I’ve broken a 32" tv and a 24" monitor… that’s some of the stuff I’ve broken LOL
          • G Offline
            ghaal @hartattack
            @hartattack Okay, I got to the config folder. I saw all my modules there and I edited the weather modules so they have the location ID an appid and clock module so it has the 12 hour format, saved, and restarted my Pi. I turned on the Pi using:
            pi@magicpi:~ $ cd MagicMirror/config
            pi@magicpi:~/MagicMirror/config $ cp config.js.sample config.js
            You can now try to start MagicMirror².
            pi@magicpi:~/MagicMirror/config $ cd $HOME/MagicMirror
            pi@magicpi:~/MagicMirror $ npm start
            I got that code from: https://forum.magicmirror.builders/topic/236/complete-setup-tutorial/6
            When I turned it on though, none of the edits I made were showing. The weather wasn’t showing and the clock was still in 24 hour format. When I went to the config folder none of the previous edits were there.
            • G Offline
              ghaal @Mykle1
              @Mykle1 I don’t have it and I don’t know what it is TBH. Is it an app or an online thing, or something integrated into this forum?
                Mykle1 Project Sponsor Module Developer @ghaal
                @ghaal said in Super nooby question- How to configure the downloaded modules and weather wont show up:
                It sounds like you didn’t save the config.js after you edited it. Copy and paste your config.js here so we can take a look at it.
                  https://forum.magicmirror.builders/topic/2147/teamspeak-magic-mirror-help-desk
                  I don’t know if anyone is there right now but i’ll be there 3 hours from now. If you can make it then I’ll try to help you
                  • G Offline
                    ghaal @Mykle1
                    @Mykle1 I will, but I can’t do that until an hour or two
                      broberg Project Sponsor @ghaal
                      @ghaal this line cp config.js.sample config.js
                      Copys the sample config to the config.js file and should only be done once. If you do this everytime you start your mirror you will keep replacing your config.j s file with the sample config.
                      G 1 Reply Last reply Reply Quote 2
                      • G Offline
                        ghaal @broberg
                        @broberg I don’t get it. I have not copied any file into another one (does it automatically happen?) Should I copy this file? How? I have tried editing the regular config, and haven’t touched the sample one. Should I?
                          @ghaal you copy the sample file ONCE after you have installed the mirror software.
                          But it looked like you where repeating the copy command ( cp = copy ) before you started the mirror (npm start ) and IF you do this each time, it doesn’t matter what you have saved in the config.js file since it will be overwritten each time you type in : cp config.js.sample config.js
                          • G Offline
                            ghaal
                            module: “currentweather”,
                            position: “top_right”, .
                            locationID: "(my id) ",
                            appid: “my appid”
                            • G Offline
                              ghaal @ghaal
                              @ghaal that’s my weather module, but it doesn’t show up
                              • G Offline
                                ghaal @ghaal
                                @ghaal {
                                		module: "currentweather",
                                			locationID: "5359777",
                                			appid: "ee6dbcc4823bb3f9a7f26c49fa64729c"
                                		module: "weatherforecast",
                                		header: "Weather Forecast",
                                			locationID: "####",
                                			appid: "blahblahblah"
                                that’s a more accurate of focast and current, both don’t show on the magicmirror page. I made sure not to add extra spaces when removing my appid and location.
                                  Here it is! You can copy and paste right from here into your config
                                  			appid: "YOUR API KEY"
                                  		}, // end of weatherforecast entry needs a comma
