    Black screen + access Denied trough web
    11 Posts 4 Posters 6.5k Views 3 Watching
      reddevel75
      Hello ,
      Im complete new to magicmirror so maybe im seeing something not right.
      First installed everything and after npm start magicmirror Launch and its Black.screen.
      Then intro to acces it trough the web but then i get acces denied.
      I try to delete modules and to charge the config file with different ip adres. But nothing works. Does anybody have a sollotion for me.
      Thnak you !
      • brobergB Offline
        broberg Project Sponsor @reddevel75
        @reddevel75 use this guide for ip whitelist to access the mirror from another computer :
        https://forum.magicmirror.builders/topic/1326/ipwhitelist-howto
        OR change the config to ipWhitelist: [ ], To allow every ip to access the mirror
        Please post you config file content so we can see if there is any issues with it (but remove any personal api-keys before you post)
          reddevel75
          Thank you for you reaction.
          First off thanks for helping out with the connecting that problem is solved now.
          Still I have the problem that nothing seems to work because it’s still black screen…
          here is my config.js
          /* Magic Mirror Config Sample
           * MIT Licensed.
          var config = {
                  port: 8080,
                  ipWhitelist: [ ],
                  language: "nl",
                  timeFormat: 24,
                  units: "metric",
                                  module: "alert",
                                  module: "updatenotification",
                                  position: "top_bar"
                                  module: "clock",
                                  position: "top_left"
                                  header: "US Holidays",
                                                          symbol: "calendar-check-o ",
                                                          url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics"
                                  module: "compliments",
                                  position: "lower_third"
                                  module: "currentweather",
                                          locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
                                          appid: "YOUR_OPENWEATHER_API_KEY"
                                  module: "weatherforecast",
                                  header: "Weather Forecast",
                                          locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
                                  module: "newsfeed",
                                  position: "bottom_bar",
                                          feeds: [
                                                          title: "New York Times",
                                          showSourceTitle: true,
                                          showPublishDate: true
          hopefully you can find the problem…
            reddevel75
            when just programming one module i get this error: 0_1492796484347_Schermafbeelding 2017-04-21 om 19.39.56.png
            brobergB Mykle1M 2 Replies Last reply Reply Quote 0
            • brobergB Offline
              @reddevel75
              could you please try this config?
               * MIT Licensed.
              var config = {
              	port: 8080,
              	ipWhitelist: [], // Set [] to allow all IP addresses.
              	language: "en",
              	timeFormat: 24,
              	units: "metric",
              			module: "clock",
              But it seems you have other issues, it tries to load a module that doesn’t exist (alarm module).
                Mykle1 Project Sponsor Module Developer @reddevel75
                @reddevel75
                What module are your programming? Do you mean you are trying to add a module to the default config. I just loaded your config from above, adding my API key, and it works correctly. Can you explain a little better what you are trying to do, please?
                  Mykle1 Project Sponsor Module Developer @broberg
                  @broberg said in Black screen + access Denied trough web:
                  Ah, you beat me! :thumbsup:
                    reddevel75
                    Just trying to get it running for the first time nothing custom stuff.
                    when i upload you code i get this problem.
                    Maybe a fresh install will do the trick ?
                    • brobergB Offline
                      @reddevel75 did you do the npm install in the magicmirror folder after you cloned the magicmirror?
                        reddevel75
                        just did a fresh install, now everything seems to work :)
                        • N Offline
                          n8ms
                          I am getting the same issue with the black screen. When I access via localhost:8080, I get the default screen that tells you to create a config file. I was using a config.js file from an old build I did that worked, but I replaced it with the config file posted above and I get the same issue.
                          pi@n8MM:~/MagicMirror $ npm start
                          > magicmirror@2.1.1 start /home/pi/MagicMirror
                          > sh run-start.sh
                          Starting MagicMirror: v2.1.1
                          Loading config ...
                          Loading module helpers ...
                          All module helpers loaded.
                          Starting server op port 8080 ...
                          You're using a full whitelist configuration to allow for all IPs
                          Server started ...
                          Launching application.
                          ^C
                          pi@n8MM:~/MagicMirror $ node -v
                          v7.9.0
                          pi@n8MM:~/MagicMirror $ electron -v
                          v1.3.15
