    Weather
    28 Posts 7 Posters 19.0k Views 6 Watching
    • G
      Gamble
      /* Magic Mirror Config Sample
      • By Michael Teeuw http://michaelteeuw.nl
      • MIT Licensed.
      • For more information how you can configurate this file
      • See https://github.com/MichMich/MagicMirror#configuration
      var config = {
      port: 8080,
      ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
      // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
      // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
      language: "en",
      timeFormat: 12,
      units: "metric",
      		module: "alert",
      		module: "updatenotification",
      		position: "top_bar"
      		module: "clock",
      		position: "top_left"
      		header: "US Holidays",
      					symbol: "calendar-check-o ",
      					url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics"
      		module: "MMM-Trello",
      		position: "lower_third"
      			api_key: "**************",
      			token: "https://trello.com/1/authorize?expiration=never&scope=read&response_type=token&name=Server%20Token&key=**********",
      			list: "************"
      		module: "currentweather",
      			locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
      			appid: "YOUR_OPENWEATHER_API_KEY"
      		module: "weatherforecast",
      		header: "Weather Forecast",
      			locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
      		module: "newsfeed",
      		position: "bottom_bar",
      			feeds: [
      					title: "Chicago",
      			showSourceTitle: true,
      			showPublishDate: true
      if (typeof module !== “undefined”) {module.exports = config;}
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @Gamble
        @Gamble you have two mistakes
        1. position: "lower_third" has to be ````position: “lower_third”,``` (comma at the end)
        has to be
        missing closing curly bracket at the end
        • G
          Gamble
          Thanks.
          One step closer!
          Weather doesn’t load and neither does trello. So how would I start to figure out why they don’t show up? All the text looks corrrect
          • Mykle1M
            Mykle1 Project Sponsor Module Developer @Gamble
            @Gamble
            In the time it takes to read these, you could be up and running. Or, you could continue the way you have been.
            https://forum.magicmirror.builders/topic/4528/how-to-create-a-working-config-for-absolute-beginners
            https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners
            • G
              Gamble
              I’ve read them a few times. My understanding of them is pretty limited.
              Could this be the reason? Although it says no helper module for clock but that still works.
              Starting MagicMirror: v2.1.2
              Loading config …
              Loading module helpers …
              Initializing new module helper …
              No helper found for module: MMM-Trello.
              All module helpers loaded.
              Starting server on port 8080 …
              Server started …
              Starting module: newsfeed
              Sockets connected & modules started …
              Launching application.
              Create new calendar fetcher for url: http://www.calendarlabs.com/templates/ical/US-Holidays.ics - Interval: 300000
              Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
              • cowboysdudeC
                cowboysdude Module Developer @Gamble
                @Gamble Well that’s because the clock doesn’t have a node_helper… nor do the weather modules… not sure about Trello…
                • G
                  Gamble
                  what really blows my mind is that the weather will work then the only thing i do is change the name from New York to chicago then it literally shits the bed. I read the tutorials and still can’t get the weather or trello to work
                  I also found conflicting things on trello where one says for the list you need the ID and the other says you need the url then add .json to the end. Neither of which work
                  • V
                    videogame95 @Gamble
                    @Gamble the weater open maps isn’t working .
                    Use a different module . If you configuration isn’t loading delet use the sample copy its rename it as a copy.
                    Change the sample
                    Config.js
                    Start again .
                    I deleted the weather module
                    Add found a different on the works modules .
                    Reinstall everything.
                    Once you get to a point of things working put an ad card adpter
                    In the pi with a new sd card make a copy.
                    This if you get stuck and can’t fix use your backup copy
                    But remember copy that one.
                    All bracks with a }, have to line up in your code config file.
                    .and try to line up module inline with others.
                    I hope this is some help
                    as in space x test flight go wrong well learn more evey time we fix it.
                    Good luck
