    npm start error?
    13 Posts 5 Posters 12.5k Views 5 Watching
    • L
      longod
      I’m using a RPi 0 wireless, I have followed this tutorial step by step: https://forum.magicmirror.builders/topic/2075/magicmirror-on-pi-zero-w/2. However, when I put in “npm start” I’m getting this message:
      npm ERR! Linux 4.4.50+
      npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "start"
      npm ERR! node v4.2.1
      npm ERR! npm v2.14.7
      npm ERR! file sh
      npm ERR! code ELIFECYCLE
      npm ERR! errno ENOENT
      npm ERR! syscall spawn
      npm ERR! magicmirror@2.1.1 start: 'sh run-start.sh'
      npm ERR! spawn ENOENT
      npm ERR!
      npm ERR! Failed at the magicmirror@2.1.1 start script 'sh run-start.sh'.
      npm ERR! This is most likely a problem with the magicmirror package,
      npm ERR! not with npm itself.
      npm ERR!       sh run-start.sh
      npm ERR! You can get their info via:
      npm ERR!       npm owner ls magicmirror
      npm ERR!        /home/pi/MagicMirror/npm-debug.log```
      Here is the /home/pi/MagicMirror/npm-debug.log:
      1 verbose cli ['/usr/local/bin/node', '/usr/local/bin/npm', 'start' ]
      2 info using npm@2.14.7
      3 info using node@v4.2.1
      5 info prestart magicmirror@2.1.1
      6 info start magicmirror@2.1.1
      7 verbose unsafe-perm in lifecycle true
      8 info magicmirror@2.1.1 Failed to exec start script
      9 verbose stack Error: magicmirror@2.1.1 start: 'sh run-start.sh'
      9 verbose stack spawn ENOENT
      9 verbose stack          at ChildProcess. (/usr/local/lib/node_modules/npm/lib/utils/spawn.js:17:16)
      9 verbose stack          at emitTwo (events.js:87:13)
      9 verbose stack          at ChildProcess.emit (events.js:172:7)
      9 verbose stack          at maybeClose (internal/child_process.js:818:16)
      9 verbose stack          at Process.ChildProcess._handle.onexit (internal/child_process.js:211:5)
      10 verbose pkgid magicmirror@2.1.1
      11 verbose cwd /home/pi/MagicMirror
      12 error Linux 4.4.50+
      16 error argv "/usr/local/bin/node" "/usr/local/bin/npm" "start"
      14 error node v4.2.1
      15 error npm v2.14.7
      16 error file sh
      17 error code ELIFECYCLE
      18 error errno ENOENT
      19 error syscall spawn
      20 error magicmirror@2.1.1 start: 'sh run-start.sh'
      20 error spawn ENOENT
      21 error Failed at the magicmirror@2.1.1 start script 'sh run-start.sh'.
      21 error This is most likely a problem with the magicmirror package,
      21 error not with npm itself.
      21 error Tell the author that this fails on your system:
      21 error       sh run-start.sh
      21 error You can get their info via:
      21 error         npm owner ls magicmirror
      21 error There is likely additional logging output above.
      22 verbose exit [ 1, true ]
      Any help on how to solve this issue would be greatly appreciated! Thanks in advanced!
      romainR Mykle1M 2 Replies Last reply
      • romainR
        romain @longod
        @longod I don’t own a pi zero but I have few question.
        1. Were you on the MagicMirror folder when you did the npm start ?
        2. Were you directly on the pi using a usb keyboard (or equivalent) or were you on ssh ?
        If you were on the MagicMirror folder and you were directly on the pi I don’t know what the issue could be.
        If you wasn’t on the MagicMirror folder npm start won’t work.
        If you accessed your pi by ssh you need to use DISPLAY=:0 npm start command instead of npm start because graphical application need to know where they should be open. DISPLAY:0 mean the host machine (your pi)
        L 1 Reply Last reply
        Reply Quote 1
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @longod
          @longod
          Try updating your versions of node and npm as well
          • L
            longod @romain
            @romain
            1. Yea I was on the MagicMirror folder when I used npm start
            2. I’ve tried npm start on the pi using a keyboard, and I’ve tried through SSH. Got the same error message :/
            @Mykle1
            Just tried npm install and it gave out:
            npm WARN cannot run in wd @magicmirror2.1.1 cd vendor && npm install (wd=/home/pi/MagicMirror)
            npm WARN cannot run in wd @magicmirror2.1.1 sh installers/postinstall/postinstall.sh (wd=/home/pi/MagicMirror)
            I then did npm update and that gave out:
            > electron@1.6.7 postinstall /home/pi/MagicMirror/node_modules/electron
            > node install.js
            electron@1.6.7 node _modules/electron
            >extract-zip@1.6.0 (debug@0.7.4, yauz1@2.4.1, mkdirp@0.5.0, concat-stream@1.5.0)
            >electron-download@3.3.0 (semver@5.3.0, home-path@1.0.5, minimist@1.2.0, rc@1.2.1, debug@2.6.4, path-exists@2.1.0, sumchecker@1.3.1, fs-extra@0.30.0, nugget@2.0.1)
            afterwards I ran npm start on the pi, and DISPLAY=0: npm start on SHH, and got the same original error messages.
            romainR strawberry 3.141S 2 Replies Last reply
            • romainR
              romain @longod
              @longod what is your version of node ? node --version
              • L
                longod @romain
                @romain v4.2.1
                romainR 1 Reply Last reply
                • romainR
                  romain @longod
                  @longod I’m using the v7.9.0 . try to install an higher version of node
                  • strawberry 3.141S
                    strawberry 3.141 Project Sponsor Module Developer @longod
                    @longod try npm install --unsafe-perm
                    • L
                      longod @romain
                      @romain Okay I’ve updated to v7.7.1. I then tried DISPLAY=0: npm start and I got a similar message as before, however there is no longer a ERR! node v4.2.1 message, it skips over that part. Some progress!
                      • L
                        longod @strawberry 3.141
                        @strawberry-3.141 I gave that a go and checked npm -v, now its at 4.5.0 and is in the same boat as the node message that I was getting when I try to do DISPLAY=0: npm start. There still is the rest of the npm ERR! messages, just not the npm ERR! node v4.2.1 and npm ERR! npm v2.14.7
                        • L
                          longod
                          I realized that it is telling me to go to a different log now when I do npm start, which is npm ERR! /home/pi/.npm/_logs/2017-04-27T15_23_04_547Z-debug.log. In there it gives me this message:
                          1 verbose cli [ '/opt/nodejs/bin/node', '/usr/local/bin/npm', 'start' ]
                          2 info using npm@4.5.0
                          3 info using node@v7.7.1
                          5 info lifecycle magicmirror@2.1.1~prestart: magicmirror@2.1.1
                          6 silly lifecycle magicmirror@2.1.1~prestart: no script for prestart, continuing
                          7 info lifecycle magicmirror@2.1.1~start: magicmirror@2.1.1
                          8 verbose lifecycle magicmirror@2.1.1~start: unsafe-perm in lifecycle true
                          9 verbose lifecycle magicmirror@2.1.1~start: PATH: /opt/nodejs/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/$
                          10 verbose lifecycle magicmirror@2.1.1~start: CWD: /home/pi/MagicMirror
                          11 silly lifecycle magicmirror@2.1.1~start: Args: [ '-c', 'sh run-start.sh' ]
                          12 info lifecycle magicmirror@2.1.1~start: Failed to exec start script
                          13 verbose stack Error: magicmirror@2.1.1 start: `sh run-start.sh`
                          13 verbose stack spawn ENOENT
                          13 verbose stack     at ChildProcess. (/opt/nodejs/lib/node_modules/npm/lib/utils/spawn.js:33:16)
                          13 verbose stack     at emitTwo (events.js:106:13)
                          13 verbose stack     at ChildProcess.emit (events.js:194:7)
                          13 verbose stack     at maybeClose (internal/child_process.js:899:16)
                          13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
                          14 verbose pkgid magicmirror@2.1.1
                          15 verbose cwd /home/pi/MagicMirror
                          16 verbose Linux 4.4.50+
                          17 verbose argv "/opt/nodejs/bin/node" "/usr/local/bin/npm" "start"
                          18 verbose node v7.7.1
                          19 verbose npm  v4.5.0
                          20 error file sh
                          21 error code ELIFECYCLE
                          22 error errno ENOENT
                          23 error syscall spawn
                          24 error magicmirror@2.1.1 start: `sh run-start.sh`
                          24 error spawn ENOENT
                          25 error Failed at the magicmirror@2.1.1 start script 'sh run-start.sh'.
                          25 error Make sure you have the latest version of node.js and npm installed.
                          25 error If you do, this is most likely a problem with the magicmirror package,
                          25 error not with npm itself.
                          25 error Tell the author that this fails on your system:
                          25 error     sh run-start.sh
                          25 error You can get information on how to open an issue for this project with:
                          I’m lost on what to do next…
                          • A
                            adil
                            Hi @longod, I have just installed MM on my Rpi 0 and I’m facing the exact same issue as you. Did you finally find the solution ??
                            Thanks!
                            A 1 Reply Last reply
                            • A
                              adil @adil
                              @adil It looks like the issue was linked to missing modules like clock.
                              After I went to the vendor folder and installed using npm (see command below), I was able to launch MM successfully.
                              cd ~/MagicMirror/vendor
                              npm install
                              Reply Quote 1
