    What do you need for trying to make a module?
    11 Posts 5 Posters 6.1k Views 6 Watching
    • F Offline
      Fonfon
      hi all is in the title !
      • cowboysdudeC Offline
        cowboysdude Module Developer
        There is a guide to help with that :)
        https://github.com/MichMich/MagicMirror/tree/master/modules
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @Fonfon
          @Fonfon also take a look here https://github.com/roramirez/MagicMirror-Module-Template
          • F Offline
            Fonfon
            thanks for your help
              Plus if you have questions on something you’re trying to do please ask… someone will be happy to help you!
              • F Offline
                Fonfon @cowboysdude
                @cowboysdude oh yes i try to make a module for my ipcamera (dahua)
                but it’s hard ! i start from 0 !
                E 1 Reply Last reply Reply Quote 1
                • E Offline
                  Eunanibus Module Developer @Fonfon
                  @Fonfon
                  It’s good to have some basic knowledge of JavaScript. I’d recommend Code Academy or something similar if you’re starting from absolute zero!
                    aimanyusof94 @Eunanibus
                    @Eunanibus I want to literally understand all of the codings in the MagicMirror. So, what language do I need to learn? Because I can see that some files are CSS and HTML. Note to you, I have nearly zero in coding language. Or do I only need to learn Javascript.
                    I can see that this project as a learning tool for me. Thanks mate.
                    • E Offline
                      Eunanibus Module Developer @aimanyusof94
                      @aimanyusof94
                      CSS, HTML and JavaScript go hand in hand. You need to know a little about one, to know what you can do to it (or with it) with the other. In this case, you’ll need a little knowledge of all three, and a little programming knowledge to boot.
                      If you’re just looking for a beginner project, I really wouldn’t recommend this to start, as you’ll run into problems, get disheartened and maybe quit (and nobody wants that!).
                      If you’re just starting, visit a website like Code Academy which will allow you to see your results interactively. This is a great place to start learning the basics, and it’s free. I wouldn’t jump straight into a bespoke module development project until you have a bit of experience making other things a little less specialised.
                      A 1 Reply Last reply Reply Quote 2
                        @Eunanibus Okay, thanks mate. I certainly will visit the Code Academy soon. Your reply is just the answer I need.
