    http request
    53 Posts 7 Posters 52.2k Views 6 Watching
      acdacd2
      is that correct ?
      		module: 'MMM-HTTPRequestDisplay',
      		position: 'bottom_bar',	// This can be any of the regions. Best results in left or right regions.
      		header: 'MMM-HTTPRequestDisplay', // This is optional
      			accessToken: 'http://api.openweathermap.org/data/2.5/weather?q=London,uk&mode=xml',
      Note from Moderator: Please use Markdown on code snippets for easier reading.
      • E Offline
        Eunanibus Module Developer
        Sorry, I made a lot of mistakes on the README it seems.
        Instead of
        accessToken : "http://etc"
        use
        httpRequestURL: "http://etc"
        apologies
          acdacd2
          no problemo,
          with this config, black screen
          			httpRequestURL: 'http://192.168.1.248:8889/status.xml',
          • E Offline
            Make sure that you’re not just copy and pasting blindly into your config file.
            After each
            etc
            Note the comma , after the module. That comma should only be there if there are more modules.
            Likewise, if you’re pasting it last, you need to make sure the module before it has one, to let the script know there are more modules after the previous one.
            So the pattern is
               module: ‘firstModule’,
               option : ""
            }, <<< COMMA HERE
               module: ‘middleModule’,
               option : ""
            }, <<< COMMA HERE
               module: ‘last module’,
               option : ""
            } <<<<< NO COMMA
            hope that makes sense. hopefully that’s the problem.
              acdacd2
              This post is deleted!
                acdacd2
                • E Offline
                  Can you Zip up and upload your config file somewhere I can download it and I’ll take a look? Somewhere like pastebin.
                  • K Offline
                    KirAsh4 Moderator
                    Hey @acdacd2, please use proper Markdown when posting code. It really isn’t that hard to do and it makes it so much easier and pleasant for others to read, and possibly find errors quicker. Specifically you need to use back ticks before and after your code:
                         like so. Note that a back tick is not the same as the normal apostrophe, ` versus ' .
                    • E Offline
                      @KirAsh4 can you confirm MM startup with my module with this config file?
                      The module won’t show any results but MM should boot?
                      • K Offline
                        KirAsh4 Moderator
                        The file ‘status.xml’ doesn’t exist on my system, so it gets a 404 returned, however it does load up, and it does work.
                          acdacd2
                          I have the same message with my environment.
                          In a browse it’s ok
                          • K Offline
                            KirAsh4 Moderator
                            Right, I have not tested this on an actual rpi … I’m at the office, so I’m running a serveronly setup. I can do an rpi test later, although I suspect it will still work, as opposed to resulting in a blank screen. It returns the error as expected when it can’t find the file.
                              acdacd2
                              with a browser on the pi, it’s also ok
                              • E Offline
                                @KirAsh4 I’ve isolated the issue as a Cross-Domain Access issue. Do you know of any particular way to make XMLHTTPRequests to external domains?
                                I wasn’t aware this would be an issue but apparently anybody who wants to use this and map to an external domain will have this issue unless they have a running PHP server that can store the XML results locally (or if they can access a server, they can add the line Access-Control-Allow-Origin: * to their HTML headers.
                                Any ideas?
                                • K Offline
                                  KirAsh4 Moderator
                                  XMLHTTPRequest. Look at how the 'currentweather' module does it in the 'updateWeather()' function.
                                  • E Offline
                                    Yeah that’s what I based my original request functionality on. The OpenWeather API response is CORS compatible due to the response header - this is why the example response works well. Outside of this domain though (say on http://www.w3schools.com/xml/cd_catalog.xml (or any other external server). This unfortunately makes problems - I’m still looking for a work-around.
                                    • K Offline
                                      KirAsh4 Moderator
                                      Welcome to Javascript security issues.
                                        acdacd2 @KirAsh4
                                          acdacd2
                                            acdacd2
                                            • 2 / 3
