    http request
    53 Posts 7 Posters 48.1k Views 6 Watching
      acdacd2
      I have the same message with my environment.
      In a browse it’s ok
      • KirAsh4K Offline
        KirAsh4 Moderator
        Right, I have not tested this on an actual rpi … I’m at the office, so I’m running a serveronly setup. I can do an rpi test later, although I suspect it will still work, as opposed to resulting in a blank screen. It returns the error as expected when it can’t find the file.
          acdacd2
          with a browser on the pi, it’s also ok
          • E Offline
            Eunanibus Module Developer
            @KirAsh4 I’ve isolated the issue as a Cross-Domain Access issue. Do you know of any particular way to make XMLHTTPRequests to external domains?
            I wasn’t aware this would be an issue but apparently anybody who wants to use this and map to an external domain will have this issue unless they have a running PHP server that can store the XML results locally (or if they can access a server, they can add the line Access-Control-Allow-Origin: * to their HTML headers.
            Any ideas?
            • KirAsh4K Offline
              KirAsh4 Moderator
              XMLHTTPRequest. Look at how the 'currentweather' module does it in the 'updateWeather()' function.
              • E Offline
                Yeah that’s what I based my original request functionality on. The OpenWeather API response is CORS compatible due to the response header - this is why the example response works well. Outside of this domain though (say on http://www.w3schools.com/xml/cd_catalog.xml (or any other external server). This unfortunately makes problems - I’m still looking for a work-around.
                • KirAsh4K Offline
                  KirAsh4 Moderator
                  Welcome to Javascript security issues.
                    acdacd2 @KirAsh4
                    This post is deleted!
                      acdacd2
                        acdacd2
                        • 6
                        • 4 / 6
