    What Monitor did you use?
    34 Posts 22 Posters 52.4k Views 20 Watching
    • K Offline
      Kobie
      I think it’s quite normal for them to bleed light in darkness - the one-way-mirror needs light on the ‘outside’ in order to overpower the light from the monitor.
      If you’re not seeing much when the lights are on, then you can try moving the mirror into a different position - the angle of teh light can make a difference.
      Also, have you tried playing around with the backlight settings, contrast etc on the monitor?
      • C Offline
        cpramhofer @Kobie
        @Kobie
        you are absoluty right, the bleeding in the dark is not the thing which worries me most.
        currently the position is not optimal, i´m still waiting for the hanging pads. if i go down a bit to improve the angel things get better.
        has anyone ever tried both: TN and IPS Panel? I will switch over to IPS and hope that things will improve once more.
          broberg Project Sponsor
          I have a three screen setup in front of me right now, one IPS in the middle and two TN besides it.
          the TN panels are crap in comparison (yes they where cheaper ofc) the viewing angle and colors are the most obvious things that stands out.
          If adjusted to extremes the contrast on the ips is much higher.
          And if you planning on using the screen on it’s side I would pretty much exclude tn panels, it just looks weird and the viewing angles from the side usually aren’t good enough.
            sakuwa
            Hey :)
            i am searching for a monitor and my favorite in the moment is this one: https://www.amazon.de/HP-T3M86AA-Monitor-Reaktionszeit-schwarz/dp/B01G1M5B2C/ref=sr_1_3?s=computers&ie=UTF8&qid=1480673385&sr=1-3
            What do you think about this one?
            • L Offline
              lolobyte
              15" Panel from an old laptop found in the trash with a separate Controller.
              HDMI+DVI+VGA+Audio LCD Controller Kit for 15.6" B156XW02 V.2 LED Panel 1366x768
              • C Offline
                cpramhofer @sakuwa
                @sakuwa i would not recommend this monitor! IPS Panel is good but the brightness is just 250cd/m2 - better go for one with 300cd/m2
                price sounds good but resolution is not that fine for 27", also the connections are upright what makes it hard to build a slim mirror
                • h0schiH Offline
                  h0schi
                  I will use an old HP2448hc.
                  This monitor got a glossy panel.
                  Is that a problem ?
                    Mykle1 Project Sponsor Module Developer @h0schi
                    @h0schi said in What Monitor did you use?:
                    Is that a problem ?
                    That’ll do. Virtually any display will work.
                    h0schiH 1 Reply Last reply Reply Quote 0
                    • h0schiH Offline
                      h0schi @Mykle1
                      @Mykle1
                      Thank you ! :)
                        JSBhopal
                        Anybody gone 55"+ ?
                        I want to do this install in my bathroom but my OCD won’t allow the modules not to be perfectly lined up in each corner!
                        • kusselinK Offline
                          kusselin
                          how did you do that with the display panel? I have the DELL 19 "1905FPV and would like to use it as a mirror. Do I need an extra panel for the connection …?
                          • L Offline
                            lolobyte @kusselin
                            @kusselin : Hello freiend.
                            Like i wrote in this post here “15” Panel from an old laptop found in the trash with a separate Controller (from Amazon).
                            HDMI+DVI+VGA+Audio LCD Controller Kit for 15.6" B156XW02 V.2 LED Panel 1366x768"
                            1. Disassemble your laptop.
                            2. Search for Panel manufacturer (like this one)
                              and
                            1. search on ebay, amazon or other supplier for a LCD drive controller board of your panel manufacturerer. In my case i has found this for the lenovo…
                              and this one for the packard bell
                              packard bell driver board for panel B156xw02
                            hope you have some helpfull informations for your search.
                            at least it looks like this
                            or this
                            • kusselinK Offline
                              kusselin
                              Thank You for your manual :-)
                              Greetings
                              Markus
                              • T Offline
                                tomy
                                I think you can consider kiperlline, which is moderate in size and cheap, which is perfect for you.
                                [https://jp.kiperline.com/](link url)
