    TypeError: curr.start.toISOString is not a function
    34 Posts 7 Posters 36.4k Views 6 Watching
    • B
      Bangee Module Developer
      i’ve sent you the working on. i don’t know why, but most of the time, the calendar is working find.
      And sometimes there is this bug. I’ve sent you a diff file, with the differences between the files.
      • B
        @MichMich I still have these problems with office365 calender :-(
        Did you found a solution for this issue?
        • MichMichM
          MichMich
          Did you tryout the develop branch yet? It might include some changes that could help you.
          • E
            eugenelai
            Any update on this? I’m also using office365 calendar and my Calendar randomly stopped working. I’ve tried the node debug.js and just get the below. @MichMich @KirAsh4
            pi@rpi3:~/MagicMirror/modules/default/calendar $ sudo node debug.js
            Create fetcher ...
            Create fetcher done!
            [ { title: 'Max',
                startDate: '1493568000000',
                endDate: '1493654400000',
                fullDayEvent: true,
                firstYear: 1990 },
              { title: 'Someone',
                startDate: '1493740800000',
                endDate: '1493827200000',
                fullDayEvent: true,
                firstYear: 2010 },
              { title: 'Another',
                startDate: '1493913600000',
                endDate: '1494000000000',
                fullDayEvent: true,
                firstYear: 2000 },
              { title: 'Event',
                startDate: '1494086400000',
                endDate: '1494172800000',
                fullDayEvent: true,
                firstYear: 1980 } ]
            • B
              nope, still same here… :-(
              • C
                clumsy_ninja
                I’m just starting with my MagicMirror today and am also having this issue.
                I have two calendars,
                1. Office 365 - gives this issue
                2. google - loads, but doesn’t display all events in my calendar
                • B
                  so now I found something new:
                  in my Calendar the DTSTART is set to:
                  DTSTART;TZID="(UTC+00:00) Monrovia, Reykjavik":20161028T200000
                  when I remove (UTC+00:00) everything works fine.
                  Then it looks like this:
                  DTSTART;TZID="Monrovia, Reykjavik":20161028T200000
                  I’ve used a PHP Script to do this.
                  @MichMich can you implement this in the js script? or what will I need to replace for testing?
                          $ch = curl_init();
                          // set url
                          curl_setopt($ch, CURLOPT_URL, "https://ical.url/calendar.ics");
                          curl_setopt($ch, CURLOPT_USERAGENT, "Mozilla/4.0 (compatible; MSIE 5.01; Windows NT 5.0)");
                          curl_setopt($ch, CURLOPT_HEADER, false);
                          curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
                          curl_setopt($ch, CURLOPT_FOLLOWLOCATION, true);
                          curl_setopt($ch, CURLOPT_COOKIEJAR, "blabla");
                              // $output contains the output string
                          $output = curl_exec($ch);
                          // close curl resource to free up system resources
                          curl_close($ch);
                          $response = new Response();
                          $output = str_replace('(UTC+00:00) ', '', $output);
                          $response->setContent($output);
                          $response->setStatusCode(Response::HTTP_OK);
                          $response->headers->set('Content-type', 'text/calendar');
                          return $response;
                  • MichMichM
                    MichMich
                    I suggest you fork the project, implement the fix that works for you and send me a PR. That way you can test it and others can benefit from your solution. :)
                    • B
                      Ok, :-) but actually I don’t no where to implement this in js :-)
                      Can someone give me a hint where to place my str_replace (UTC+00:00) in DTSTART variable?
                      Thanks ;-)
                      • C
                        chadderwick
                        So I ran into this problem and have a fix. I have uploaded the files to drop box for know. If this fixes others, i’ll look into updating the project.
                        There are 2 files that need updated:
                        /home/pi/MagicMirror/modules/default/calendar/vendor/node-ical.js
                        line 33
                        https://dl.dropboxusercontent.com/u/1184191/node-ical.js
                        /home/pi/MagicMirror/modules/default/calendar/vendor/ical.js
                        line 97
                        https://dl.dropboxusercontent.com/u/1184191/ical.js
                        • B
                          can you maybe post your solution? that would be great
                          thanks bangee
                          • C
                            chadderwick
                            Apologies…my dropbox links dropped out.
                            Here are the updated files:
                            https://www.dropbox.com/sh/xvlusz1po4tvq24/AABF9ZuCL5j-ok4xfnYA5JsHa?dl=0
                            This has not been tested with the latest version. I bought 6 different types of mirrors (glass and acrylic) and couldn’t find what i was looking for so gave up the dream for now…
                            • M
                              moshinh
                              Does this work? Confirmed? I tried someone elses .js and it didnt :-(
                              • M
                                moshinh
                                it does not :-(
