    Blank screen when Running Magic Mirror on Raspian and RP3.
    8 Posts 3 Posters 3.7k Views 3 Watching
    • L Offline
      lagoon7
      Installed the latest Magic Mirror on a new RP3 with the latest Raspian OS. I used the manual install, since there was something not right with the raspberry pi that’s on the github. I copied the config.js.sample to config.js due to the warning screen. I should see at least 5 modules running? I have a blank screen and nothing in the console nor in the terminal when I close the app, that indicates an error. Is there a directory of somesorts that has logging information?
      What diags can I provide to help?
        Mykle1 Project Sponsor Module Developer @lagoon7
        @lagoon7
        First thing you should do is post your config.js file here. More often than not the problem lies there. With the default config.js you should see clock, calendar, compliments and newsfeed. You won’t see the weather modules until you get your API key. This is what your config.js should look like, unless you’ve made changes.
        /* Magic Mirror Config Sample
         * MIT Licensed.
        var config = {
        	port: 8080,
        	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses.
        	language: "en",
        	timeFormat: 24,
        	units: "metric",
        			module: "alert",
        			module: "updatenotification",
        			position: "top_bar"
        			module: "clock",
        			position: "top_left"
        			header: "US Holidays",
        						symbol: "calendar-check-o ",
        						url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics"
        			module: "compliments",
        			position: "lower_third"
        			module: "currentweather",
        				locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
        				appid: "YOUR_OPENWEATHER_API_KEY"
        			module: "weatherforecast",
        			header: "Weather Forecast",
        				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
        			module: "newsfeed",
        			position: "bottom_bar",
        				feeds: [
        						title: "New York Times",
        				showSourceTitle: true,
        				showPublishDate: true
        • L Offline
          lagoon7 @Mykle1
          @Mykle1 Yeah I realize that, however I do not get any “modules” to load. Here is the output from the command and I ran the install of electron as sudo and checked to see if any of the permissions changed. However I didn’t get any errors when I ran it under “sudo”
          pi@pi314159:~/MagicMirror $ sudo npm install electron
          npm WARN engine deep-extend@0.4.2: wanted: {“node”:“>=0.12.0”,“iojs”:“>=1.0.0”} (current: {“node”:“0.10.29”,“npm”:“1.4.21”})
          electron@1.6.7 postinstall /home/pi/MagicMirror/node_modules/electron
          node install.js
          electron@1.6.7 node_modules/electron
          ├── extract-zip@1.6.5 (debug@2.2.0, mkdirp@0.5.0, yauzl@2.4.1, concat-stream@1.6.0)
          └── electron-download@3.3.0 (home-path@1.0.5, semver@5.3.0, minimist@1.2.0, rc@1.2.1, debug@2.6.6, path-exists@2.1.0, sumchecker@1.3.1, fs-extra@0.30.0, nugget@2.0.1)
          pi@matrix314159:~/MagicMirror $ npm start
          magicmirror@2.1.1 start /home/pi/MagicMirror
          sh run-start.sh
          Starting MagicMirror: v2.1.1
          Loading config …
          Loading module helpers …
          Initializing new module helper …
          All module helpers loaded.
          Starting server on port 8080 …
          Starting server op port 8080 …
          Server started …
          Starting module: newsfeed
          Sockets connected & modules started …
          Launching application.
          • Magic Mirror Config Sample
          • By Michael Teeuw http://michaelteeuw.nl
          • MIT Licensed.
          var config = {
          port: 8080,
          ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses.
          language: "en",
          timeFormat: 24,
          units: "metric",
          		module: "alert",
          		position: "top_bar"
          		module: "clock",
          		module: "newsfeed",
          			feeds: [
          if (typeof module !== “undefined”) {module.exports = config;}
          • cowboysdudeC Offline
            cowboysdude Module Developer
            @lagoon7 said in Blank screen when Running Magic Mirror on Raspian and RP3.:
            module: “calendar”,
            header: “US Holidays”,
            position: “top_left”,
            url: “webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics”
            module: “compliments”,
            position: “lower_third”
            module: “currentweather”,
            position: “top_right”,
            locationID: “”, //ID from http://www.openweathermap.org/help/city_list.txt
            appid: “YOUR_OPENWEATHER_API_KEY”
            module: “weatherforecast”,
            header: “Weather Forecast”,
            locationID: “5128581”, //ID from http://www.openweathermap.org/help/city_list.txt
            module: “newsfeed”,
            position: “bottom_bar”,
            feeds: [
            title: “New York Times”,
            url: “http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml”
            Stupid question here but did you do this---->
            in terminal window in the
            ~MagicMirror/config
            cp config.js.sample config.js
              You’ll certainly have to update node and npm. I had similar problems when I did a manual install on a laptop and updating those cleared things up for me.
              Mine:
              `Mykle@Mykle-Desktop MINGW32 ~/MagicMirror
              $ node --version
              v6.10.2
              $ npm --version
              3.10.10
              • L Offline
                lagoon7 @cowboysdude
                @cowboysdude yes I did.
                • L Offline
                  lagoon7 @Mykle1
                  @Mykle1 Ok after that, I went to update node which updated npm.
                  Using this script for raspberry pi:
                  curl -sL https://deb.nodesource.com/setup_7.x | sudo -E bash -
                  I then deleted the magicmirror home directory, downloaded the installer script from the GIT repo, checked it again for versions and installs.
                  1. I ran the script as a normal user. It completed successfully.
                  2. Then ran the npm start command.
                  3. Now magic Mirror is working.
                  Thanks!
                    Thanks!
                    Great! Enjoy your mirror.
