    Another mirror spec post I am sure
    4 Posts 3 Posters 2.5k Views 3 Watching
      RE_Magic_Mirror
      Hey can someone confirm the specs on this mirror are within what people are using that works?
      Thickness 6mm
      Transmittance Visible 11%
      Exterior Visible Reflectance 38%
      Interior Visible Reflectance 16%
      U-Value (WinterNighttime) 1.02
      Solar Heat Gain Coefficient (SHGC) 0.39
      Light To Solar Gain 0.28
      I have MM working and configured now its just down to getting the actual mirror and mounting. Thank you everyone for all of your help.
        bhepler Module Developer @RE_Magic_Mirror
        @RE_Magic_Mirror That’s a bit more specific than we usually consider around here.
        That 2nd variable, the transmittance visible, is usually about all we consider. I just bought a mirror that was also 11% transparent and it works great. It is maybe a little dim in a brightly lit reception area, but I’m certainly not going to send it back.
        At most, you might want to go up to 20% transmittance, but I would use that only in areas that are in bright sunlight. For your typical household / interior mirror, I think you’re good to go with that mirror.
        cowboysdudeC 1 Reply Last reply Reply Quote 1
        • cowboysdudeC Offline
          cowboysdude Module Developer @bhepler
          @bhepler I’ll second that!
            RE_Magic_Mirror
            Awesome thanks to both of you I am researching other options to see if i can increase the %.
