    Magic Mirror with actiontiles (smarthome)
    14 Posts 7 Posters 23.5k Views 9 Watching
      stevenang88
      Hello everyone,
      Being a big fan of smartthings and actiontiles, I have embedded the URL into the MM. Here is my MM :) Hope to get more interesting modules to add in future! Thanks.
      • Steven from Singapore
      1 Reply Last reply Reply Quote 7
      • Y
        yawns Moderator
        Do you have touch functionalities? I like action tiles (like Windows mobile has) but without touch I don’t see the benefit :)
        • T
          tritran
          Looks great. Are you using home-assistant for your Smart Home? And is it also on the same raspberry pi?
          • R
            Ruricu
            Since OP seems to have disappeared, I thought I’d add a little context. Action Tiles is a web-based tile-based UI-builder for the SmartThings home-automation platform. It works great within an iFrame with MagicMirror. You can build a panel for just informational purposes (door/lock status, camera feeds), or if you have touch/input capabilities, device controls.
            • cowboysdudeC
              cowboysdude Module Developer
              Perhaps you should share your ‘module’ … ;)
              • A
                AJax2012
                Yes, can you please post your code or something? I would like to use action tiles with my MM project.
                • R
                  Ruricu
                  Sorry, I think there’s a misunderstanding about integrating ActionTiles here. There’s not any additional code required; ActionTiles generates a panel that is accessible at a web address, so you just use the iFrame module with that URL and play around with the sizing.
                  A 1 Reply Last reply Reply Quote 2
                  • A
                    AJax2012 @Ruricu
                    @Ruricu Thanks! Working on my first MM project and wasn’t sure how you could get them to work together.
                      A Former User
                      I think Action tiles Is something similiar with Apple HomeKit
                      • R
                        Ruricu @Guest
                        @Sean said in Magic Mirror with actiontiles (smarthome):
                        ActionTiles (see my link above) is a panel-based UI builder for the SmartThings HomeAutomation platform. HomeKit is Apple’s HomeAutomation platform. You could say that HomeKit is similar to SmartThings, but ActionTiles is a third-party SmartThings add-on. I don’t follow your logic.
                          A Former User @Ruricu
                          @Ruricu you are right. I just meant the similiarity between both about ui for simple action and showing status.
                          • A
                            AJax2012
                            This post is deleted!
                            • A
                              AJax2012
                              Has anyone had any luck with customizing the CSS with ActionTiles? I have a blue “MagicMirror background” and I would love to be able to get rid of the default iFrame background and the ActionTiles built-in header…Eventually, I’d love to be able to change the buttons.
                              • R
                                Ruricu @AJax2012
                                @AJax2012 Customising the CSS is not currently possible unfortunately, as far as I know
                                Source
