    Cheap as chips.....
    17 Posts 4 Posters 15.3k Views 5 Watching
    • P
      ptbw2000
      I saw this site and thought that looks like a fun project for a Pi Zero W… ( should read the whole wiki really ).
      I hit ebay for a 1" deep A4 frame, a 7" LCD with HDMI driver board and a bit of two way acrylic.
      Unfortunately I then found out that the software is incompatible with the ARM architecture of the Pi Zero, so here is my mirror running with a Pi 3, the only additional components were a power plug for the LCD and a two way micro USB power lead to split the power between Pi and LCD.
      http://www.ebay.co.uk/itm/321293751657
      http://www.ebay.co.uk/itm/171763618052
      http://www.ebay.co.uk/itm/322518978255
      Total ebay spend ~45 quid. (less Pi and PSU).
      Enjoy
      (edit) Just spotted the forum posts about getting this working with the Pi Zero W so will attempt that later.
      P 1 Reply Last reply
      Reply Quote 2
      • cowboysdudeC
        cowboysdude Module Developer
        It’s so funny how many variations are popping up… you’re going smaller and I’m going bigger with a mini itx… I like the power and it runs VERY fast with strawberry’s voice module ;)
        D 1 Reply Last reply
        • P
          ptbw2000 @ptbw2000
          To add to the build information I used the guide published by @rootsudo with what I believe is a better way to get node on the Pi B+ or Zero.
          As pi user on a fresh jessie lite install, this uses “n” to install the latest node build for the architecture you are installing on so in my case ARM6.
          sudo apt-get update
          sudo apt-get install git
          git clone https://github.com/tj/n.git
          cd n
          sudo make install
          cd ~
          sudo n stable
          git clone https://github.com/MichMich/MagicMirror
          Then proceed as per the original guide. https://forum.magicmirror.builders/topic/2075/magicmirror-on-pi-zero-w
          Reply Quote 3
          • D
            Damian @cowboysdude
            @cowboysdude
            hello will you publish how you ggot this with your pc? thank you
            P cowboysdudeC 2 Replies Last reply
            • P
              ptbw2000 @Damian
              @Damian ( edit - The question wasn’t for me was it. Anyway this might help someone. )
              Hi, not sure what you mean hopefully the attached picture will help. ( That’s a Pi B+ with a very fat HDMI cable. I intend to change it to a slimmer one and add a PIR sensor using @cowboysdude code. )
              I was going to use a Pi Zero W then realised I had an old B+ and Wifi dongle so I switched to that instead.
              If you have any specific questions please ask.
              Reply Quote 2
              • D
                Damian @ptbw2000
                @ptbw2000 said in Cheap as chips.....:
                @Damian ( edit - The question wasn’t for me was it )
                hello no it was second time asking how to get this on mini itx pc as said but still get no answer so not sure why no answer
                Mykle1M 1 Reply Last reply
                • Mykle1M
                  Mykle1 Project Sponsor Module Developer @Damian
                  @Damian said in Cheap as chips.....:
                  There can be a million reasons why you didn’t get an answer. Who can say why?
                  With that said, MM can be installed on Pi’s, PC’s, Mac’s. My first mirror is using a Pi3 with the standard Raspbian Jessie out of the box. I have MM installed on a Compaq laptop running uBuntu, a Dell laptop running Windows 7 and my dev machine, also running Windows 7.
                  You have to manually install things but it does work, and it works better than on a Pi. The mini itx that @cowboysdude mentioned is a brilliant idea, really. It’s small form factor allows it to be placed behind a mirror as you would a Pi, and its raw computing power, speed and graphics far exceeds that of any Pi.
                  Reply Quote 1
                  • cowboysdudeC
                    cowboysdude Module Developer @Damian
                    @cowboysdude
                    I"m not making a traditional mirror per say… I"m using an Intel cpu and mini itx board with 8 gig ram and SSD on a 32" TV.
                    I installed Ubuntu and MM … that’s pretty much it :)
                    Is there anything specifically you needed to know?
                    Reply Quote 1
                    • D
                      Damian @cowboysdude
                      @cowboysdude
                      @Mykle1
                      Sorry but I never noticed these replies or would have replied earlier, I managed by following @Mykle1 guide. and it worked as expected. Been so busy with setyting up full Alexa home automation in my home that I manage on here for quick visits only, but now automation is complete, I can come back to MM and continue with it, and hopefully incorporate MM in some way, although I already have alexa power up/down the monitor.
                      Reply Quote 2
                      • Mykle1M
                        No worries, mate. :^)
                        Ahh, excellent! :^)
                        Sounds like you’re having fun and getting things done. I don’t have Alexa. Sounds damn cool though! :^)
                        Reply Quote 1
                        • cowboysdudeC
                          Nice job!
                          Reply Quote 1
                          • D
                            Damian @Mykle1
                            @Mykle1 said in Cheap as chips.....:
                            Cool, but quite a lot of work coding and making macros, using Broadlink RM Pro (IR and RF), with BlackBean in another room to automate there by IR, using a Droid box as a hub, and now controlling every light, every power point switch, lamps,TV’s, all functions of my AV equipment, LED striplights, spot lights, power on/off my PC’s, access any app/file on PC’s, use and control my Plex server to watch movies, listen to music, view pictures, open close my blinds, Volume up/down on TV’s, change source, change channels, full control of droid box, ect, ect, all by voice control only.
                            Now I’m back fully with MM and hope to do more with that.
                            • Mykle1M
                              After all that, I’m thinking, you will NOT have a problem with MM. :^)
                              Reply Quote 1
                              • D
                                Damian @Mykle1
                                :-D If only linux/JS were that easy for me, it is worlds apart from what I am used to ;-)
                                cowboysdudeC 1 Reply Last reply
                                Reply Quote 1
                                • cowboysdudeC
                                  @Damian try it… once you do you’ll love it! :)
                                  Reply Quote 1
                                  • D
                                    Damian @cowboysdude
                                    @cowboysdude
                                    I’m getting there in baby steps, but it’s like trying to learn russian by reading a chinese book :-)
                                    Reply Quote 2
                                    • cowboysdudeC
                                      @Damian That’s how you do it… you’re doing it right… a little at a time :) You’ll get it!
                                      Reply Quote 1
