    MMM-MyWastePickup (Toronto waste collection schedule)
    69 Posts 16 Posters 56.3k Views 17 Watching
    • O Offline
      onetwankyfive
      I was able to change the quotes, but it still doesn’t want to load for me. I even started with the default config so no other modules were being called, and still no luck. I am running the latest update of Magic Mirror.
        j.e.f.f Project Sponsor Module Developer @onetwankyfive
        @onetwankyfive Ugh… this is what happens when I don’t test my own install instructions…
        the instructions said to clone a repository named MMM-MyWasteCollection, which is is what I originally named this module. Then I went and changed it to MMM-MyWastePickup but I didn’t update the README to match.
        Blow away your MMM-MyWasteCollection directory and try the install again. The README now has the right repository to clone, and it should work for you.
        • O Offline
          onetwankyfive
          Its Awesome that its just a csv file that I can edit to match my recycle / trash in my city…
          I have wanted this for a while now!
            @onetwankyfive glad to hear you got it working!
            You know, you make an interesting point about it just being a CSV… how difficult did you find it to modify for your schedule? Maybe I’ll write a tutorial in the Readme for anyone who wants to do this.
            • O Offline
              onetwankyfive
              It was pretty easy… Just imported into google sheets and Download as a CSV in google sheets… It automatically put everything in the correct fields. You could prob make a template in google sheets that people could make copy of and then edit and export. Thanks again!
              • SexyTroggS Offline
                SexyTrogg
                I just moved to Toronto so I am trying out this module and so far it works great except one kink. The icons are never on the right hand side of the module so they always overlap the text on the left hand side. I’ve checked everything I can think of (made sure the module has plenty of space, checked the code, reinstalled, etc) but I still cant get it to properly fill its container. Has anyone run into this before?
                J 2 Replies Last reply Reply Quote 1
                  j.e.f.f Project Sponsor Module Developer @SexyTrogg
                  @SexyTrogg hey can you post your config? I’ll try it out. I suspect I might know what’s going on.
                    @SexyTrogg Try doing a git pull in the MMM-MyWastePickup directory. I think I fixed your problem. Let me know if it works.
                    SexyTroggS 1 Reply Last reply Reply Quote 0
                      SexyTrogg @j.e.f.f
                      @j.e.f.f Sorry for the delay. My config is just the simple:
                        module: 'MMM-MyWastePickup',
                        position: 'top_left',
                        header: 'My Waste Collection',
                          collectionCalendar: 'Tuesday2'
                      I’ll do a pull once I get back home and let you know if it works. Thanks for looking at this!
                      • MedoM Offline
                        Medo
                        @J.e.f.f: Can you explain, how to add more than one day the calender is then displaying? If i understand your module correctly, when adding a collectionCalender (lets say “Tuesday2”) - only the dates from Tuesday2 (from the CSV file) are displayed. Right?
                        My waste is collected on three different days a week. Is this possible to configure with your addon?
                        • 6
                        • 7
                        • 6 / 7
