    MMM-MyWastePickup (Toronto waste collection schedule)
    69 Posts 16 Posters 65.4k Views 17 Watching
    • twosquirrelsT Offline
      twosquirrels @WayneRigley
      @waynerigley Remove the double quotes from your entire file. For example, it should look like this:
      Calendar,WeekStarting,GreenBin,Garbage,Recycling,YardWaste,ChristmasTree
      Not this:
      "Calendar,WeekStarting,GreenBin,Garbage,Recycling,YardWaste,ChristmasTree"
      Also, remove them from the beginning and end of all following lines.
      WayneRigleyW 1 Reply Last reply Reply Quote 1
      • WayneRigleyW Offline
        WayneRigley @twosquirrels
        @twosquirrels HA guess what ! IT WORKED ! omg thank you so much ! Thank you Thank You Thank You.
        Wayne R
        twosquirrelsT 1 Reply Last reply Reply Quote 0
          @waynerigley Great! As tiny as this module is, it’s one of the things I appreciate most about the magic mirror. There’s no API to depend on… just a plain old text file that I update once a year.
          WayneRigleyW 2 Replies Last reply Reply Quote 0
            @twosquirrels Yes, size dont matter its the quality and this is %100 Quality. its always a battle to check and get things out on time here being so busy. but now its in place its perfect ! Thank you so Much for your time. now to configure my timelines as our local dept just has a cal. no worries tho it will give me something to do now till the end of the day
            Wayne R
              @twosquirrels One question for you is; if Gargabe is being picked up on the 14th at am we put the garbage out on the 13th before bed. so should i put the date on the custom as 13th. only reason is i notice the text string showing “today” on the screen.
              Wayne R
                @waynerigley The way the module is written, it wants to tell you the day that garbage is picked up. For me, I put the trash out the same morning as it’s picked up a couple hours later. So in my situation, it makes sense. For you, indeed setting all dates back one day would work. However, you might also want to clarify the header of the module for others reading it. For example, the default is:
                  header: 'Waste & Recycling',
                If you set all dates back, you may want to change it to:
                  header: 'When to put out Waste & Recycling',
                • I Offline
                  imchrisrein
                  Thanks for writing this one, it will be a big help for my girlfriend who just moved in. It took quite some time trying to figure out the code and then tailor it to my local schedule but it works and looks great. Toronto published their 2019 schedule online but the titles had spaces and the year format was wrong for some days.
                  Wednesday = Paper recycling and big household pickup
                  Thursday = Garbage pickup
                  Monday = Garbage and glass/plastic recycling
                  Such a neat module - thanks again.
                  • W Offline
                    wizz
                    Question about this module.
                    Is it any way to change the icons as i got two trash bin that are in the same color and size the only difference is that one is marked with number 1 and the other number 2 and the collections is every
                    Thursday and garbage can 1 on uneven week and garbage can 2 on even week so can these dates be entered manually? since in my area there is nothing for pickup published on the internet.
                    Or is it some other modules like this that can do this ?
                      twosquirrels
                      This has always been my most reliable and dead simple module. However, I reinstalled my raspberry pi yesterday and MMM-MyWastePickup no longer works. It sits at “Loading…” forever. I know how to edit the schedule.csv file as I’ve been doing it for over a year. It just refuses to work and I have no idea why.
                        module: 'MMM-MyWastePickup',
                        position: 'top_left',
                        header: 'My Waste Collection',
                          collectionCalendar: 'Custom'
                      J StoffbeuteluweS 2 Replies Last reply Reply Quote 0
                        j.e.f.f Project Sponsor Module Developer @twosquirrels
                        @twosquirrels any errors show up either in the log or in Electron’s console?
                          MYLE-01
                          Thanks alsum
                          BUT took me 3 hours to get it going
                          and it was me
                          weeksToDisplay: 4
                           to
                          weeksToDisplay: "4"
                          THANKS GUYS :clinking_beer_mugs:
                          • U Offline
                            uppynz
                            I’m loving this simple little module! I’m just trying to work out how I show only collections and not the blank days in between. I’ve tried adjusting the config variables but don’t seem to be getting the desired results. Ideally I only want to see the next two upcoming collections (what ever they may be)
                            		header: 'Wheelie Bin Collections',
                            • StoffbeuteluweS Offline
                              Stoffbeuteluwe Project Sponsor @twosquirrels
                              @twosquirrels for me it works …
                              • KamiSchamiK Offline
                                KamiSchami
                                Hi, how can i change the date format? I live in Germany. Thank you.
                                Real programmers never work 9 to 5. If they are around at 9 AM, it’s because they were up all night.
                                  j.e.f.f Project Sponsor Module Developer @KamiSchami
                                  @KamiSchami My module doesn’t support this. But if you want to modify it for your needs, the lines in particular are 116 and 118:
                                        //determine how close pickup day is and formats accordingly.
                                        var today = moment().startOf("day");
                                        var pickUpDate = moment(pickup.pickupDate);
                                        if (today.isSame(pickUpDate)) {
                                          dateContainer.innerHTML = this.translate("TODAY");
                                        } else if (moment(today).add(1, "days").isSame(pickUpDate)) {
                                          dateContainer.innerHTML = this.translate("TOMORROW");
                                        } else if (moment(today).add(7, "days").isAfter(pickUpDate)) {
                                          dateContainer.innerHTML = pickUpDate.format("dddd");     // here...
                                        } else {
                                          dateContainer.innerHTML = pickUpDate.format("MMMM D");     //...and here
                                  This will help figure out your formatting options:
                                  https://momentjs.com/docs/#/displaying/
                                  • Jeff
                                  KamiSchamiK 1 Reply Last reply Reply Quote 0
                                    KamiSchami @j.e.f.f
                                    @j-e-f-f Thank you, it works. Great Modul. Nice Icons.
                                      Stoffbeuteluwe Project Sponsor @KamiSchami
                                      @KamiSchami Can you show how to change that successfuly …I’m from Germany too
                                        KamiSchami @Stoffbeuteluwe
                                        @Stoffbeuteluwe
                                        Zeile 116 dateContainer.innerHTML = pickUpDate.format(“dddd”);
                                        Zeile 118 dateContainer.innerHTML = pickUpDate.format(“DD. MMM YYYY”);
                                          @KamiSchami Ok Danke
                                            mike2323
                                            I had this working fine on my Magic Mirror with a custom schedule, but now that I’ve started from scratch and created a new Magic Mirror install - MMM-MyWastePickup shows ‘No Schedule’ on the main page.
                                            Here’s my config:
                                            		position: 'upper_third',
                                            		header: 'Bin Schedule',
                                            		  collectionCalendar: 'Custom',
                                            And my schedule:
                                            Custom,02/07/21,0,0,1,0,0
                                            Custom,02/14/21,1,0,0,0,0
                                            Custom,02/21/21,0,0,1,0,0
                                            Custom,02/28/21,1,0,0,0,0
                                            And a pic of how it looks on the Magic Mirror
                                            alt text
                                            StoffbeuteluweS JerryPJ 3 Replies Last reply Reply Quote 0
                                            • 3 / 4
