    Email
    92 Posts 36 Posters 130.2k Views 39 Watching
    • I Offline
      ime90 @justjim1220
      @justjim1220
      Yeah, I changed it of course. I’ll try out the double quotation marks and all you recommended.
      Can you just tell me, does this module work for you at this time for Gmail or any other mail?
      justjim1220J 1 Reply Last reply Reply Quote 0
      • justjim1220J Offline
        justjim1220 Module Developer @ime90
        @ime90
        Yes, it works for me with my Gmail, my Hotmail, and my Yahoo mail. But I have since decided to link all three to my Gmail so I use just the one to receive all of them. But, I have tested it with all three and it does work.
        Jim Hallock - 1995
        I 1 Reply Last reply Reply Quote 1
        • I Offline
          ime90 @justjim1220
          @justjim1220
          Tried it all but still getting “No new Mail” text. I dunno where I’m going wrong. Could you please copy your module text (or send me on private) so I can compare them. Also, did you do anything on your own gmail account that could help? I changed the imap settings.
          I get this error:
          Email notifier error:  { Error: Web login required: https://support.google.com/mail/answer/78754 (Failure)
              at Connection._resTagged (/home/pi/MagicMirror/modules/email/node_modules/imap/lib/Connection.js:1502:11)
          at emitOne (events.js:96:13)
              at Parser.emit (events.js:191:7)
              at Parser._resTagged (/home/pi/MagicMirror/modules/email/node_modules/imap/lib/Parser.js:175:10)
              at Parser._parse (/home/pi/MagicMirror/modules/email/node_modules/imap/lib/Parser.js:139:16)
              at Parser._tryread (/home/pi/MagicMirror/modules/email/node_modules/imap/lib/Parser.js:82:15)
              at TLSSocket.Parser._cbReadable (/home/pi/MagicMirror/modules/email/node_modules/imap/lib/Parser.js:53:12)
              at emitNone (events.js:86:13)
              at TLSSocket.emit (events.js:188:7) type: 'no', textCode: 'ALERT', source: 'authentication' }
            @ime90
            Follow the link given in your error…
            Then follow the instructions to set your account to use less secure apps with your account…
            I’m pretty sure that I had to do that to get mine to work.
            There are other things to try as well.
            Jim Hallock - 1995
            I 1 Reply Last reply Reply Quote 2
            • I Offline
              ime90 @justjim1220
              @justjim1220
              Yeah, I did.
              Sorry for bugging you and thanks for the help. I dunno what the error is but it does seem to be connected to the mirrors inability to connect to the gmail servers. I’ll keep on trucking. If anybody has a clue what to do, I’m open for suggestions :D
              justjim1220J 2 Replies Last reply Reply Quote 0
                @ime90
                Do you have your Gmail account set up with any 2-step verification?
                If so, that would be a problem as well.
                Jim Hallock - 1995
                  @ime90
                  Another thing to try is to rebuild the mirror…
                  npm rebuild
                  Another option is to make sure you have all the latest updates for everything… Computer OS, RasPi, The mirror, node, electron, etc.
                  After a full updating, reboot, rebuild. Try again.
                  I have found that most of the problems relating to ‘no new emails’ is because you have your email open on another device, so it appears to the mirror module that they have been read and nothing new is coming up for it to retrieve.
                  Jim Hallock - 1995
                  • L Offline
                    letshin
                    Hi, would it be possible to modify the frequency at which the module checks for new emails please, so as to minimise processor load?
                    G 1 Reply Last reply Reply Quote 1
                      Seratio
                      Hi Guys,
                      while creating the configuration for my magicmirror, i experienced that showing emails isn’t working, if fade is set to true… So i debugged this nearly two hours without any knowledge of javascript :D
                      The problem is, that the variable “count” isnt working as desired. Its not increasing. So i created a patch for your:
                      58d57
                      <         var e = 0;
                      125,127c124,126
                      <                       var steps = that.payload.slice(0, that.config.numberOfEmails).length - startingPoint;
                      <                       if (e >= startingPoint) {
                      <                             var currentStep = e - startingPoint;
                      >                         if (count >= startingPoint) {
                      >                             var currentStep = count - startingPoint;
                      130d128
                      <                       e++;
                      Hopefuly this will fix your problems with the fade option.
                      Regards
                      Alex
                      • G Offline
                        gismo2006 @letshin
                        @letshin said in Email:
                        Good Morning, are they any news?
                        greets gismo2006a
                        • 6
                        • 7
                        • 8
                        • 9
                        • 10
                        • 9 / 10
