    Email
    92 Posts 36 Posters 133.3k Views 39 Watching
      ronny3050 Module Developer @amanzimdwini
      @amanzimdwini I am working on it. Also, I am finishing up with another module that works in a very similar fashion, where your requests would be required as well. I’ll add them together :D
      • N Offline
        Neokamikaze
        Thanks for this job.
        It’s possible to add number of email don’t read in the header module ?
          ronny3050 Module Developer @Neokamikaze
          @Neokamikaze Thanks for your kind words!
          It is definitely possible. Unfortunately, I am traveling and don’t have my mirror with me. I will add it in a week and update you.
          Thanks once more :D
          • P Offline
            pietrodona
            Thank you very much for this amazing module. Unfortunately, I was not able to make it work properly. Without giving any error (at least that I am aware of) it freezes on the loading screen.
            I managed the security and everything, it is a Gmail account.
            Any idea of what’s going on?
            • P Offline
              pietrodona
              Sorry for double posting. Now it works, but I did nothing but rebooting.
                ronny3050 Module Developer @pietrodona
                @pietrodona rebooting helps. The issue could’ve been some IMAP error. This happens because IMAP is super sensitive and errors without reason.
                Hopefully, all is well now.
                • KirAsh4K Offline
                  KirAsh4 Moderator
                  When in doubt, pull the plug.
                  • E Offline
                    eugenelai
                    Is it possible to add two email addresses? Kindly please advice @ronny3050
                    • strawberry 3.141S Offline
                      multiple adresses are currently not possible
                      • N Offline
                        Neokamikaze
                        Hi @ronny3050,
                        I have a problem, same problem that @pietrodona. My emails are double on my mirror same after reboot. After a few day, my emails are double on my mirror. And after delete my emails on Gmail these emails aren’t deleted on my mirror.
                        • cowboysdudeC Offline
                          cowboysdude Module Developer @ronny3050
                          @ronny3050 said in Email:
                          @amanzimdwini Also, if you’re using Gmail, you need to ‘set lower security for apps’ https://www.google.com/settings/security/lesssecureapps.
                          @ronny3050 I did that and still no emails ;( Everything is set up correctly … login/password …
                          Suggestions?
                            samydp
                            Hello,
                            you can adjust the size of the email?
                            at too long email that goes module over the entire screen
                            • H Offline
                              Hacksaw @samydp
                              @samydp
                              email.js
                              search line 59:
                              var subject = mailObj.subject.replace(/[['“]]+/g,”");
                              among them include:
                              var subject = subject.substring(0,30); //This limit of 30 characters
                                robertdempsey
                                So far it’s working like a charm! Thanks for creating this module.
                                  robertdempsey @pietrodona
                                  @pietrodona be sure to install the dependencies per the README. I skipped that part and MM stopped at a white screen. Once the deps were installed everything worked well.
                                    samydp
                                    thx, but dont have the line :/
                                    this is in the email.js file :
                                    defaults : {
                                        user: 'a@b.com',
                                        password: 'xxx',
                                        host: 'jjj.kkk.com',
                                        port: 993,
                                        tls: true,
                                        authTimeout: 10000,
                                        numberOfEmails: 5,
                                        fade: true
                                    payload: [],
                                    start : function(){
                                        console.log("Email module started!");
                                        this.sendSocketNotification('LISTEN_EMAIL',{config: this.config, payload: this.payload, loaded: this.loaded});
                                        this.loaded = false;
                                    socketNotificationReceived: function(notification, payload){
                                        if (notification === 'EMAIL_RESPONSE'){
                                            if(payload){
                                                this.loaded = true;
                                                var that = this;
                                                console.log("NEW PAYLOAD: ", payload);
                                                payload.forEach(function(m){
                                                    if(that.payload.indexOf(m.id) == -1)
                                                        that.payload.push(m);
                                                this.payload.sort(function(a,b) {return b.id - a.id; });
                                                this.updateDom(2000);
                                    // Define required scripts.
                                    getStyles: function() {
                                        return ["email.css", "font-awesome.css"];
                                    getDom: function(){
                                        var wrapper = document.createElement("table");
                                        wrapper.className = "small";
                                        var that =this;
                                        if(this.payload.length > 0)
                                            var count = 0;
                                            this.payload.slice(0,this.config.numberOfEmails).forEach(function (mailObj) {
                                                var name = mailObj.sender[0].name.replace(/['"]+/g,"");
                                                var subject = mailObj.subject.replace(/[\['"\]]+/g,"");
                                                var emailWrapper = document.createElement("tr");
                                                emailWrapper.className = "normal";
                                                var senderWrapper = document.createElement("tr");
                                                senderWrapper.className = "normal";
                                                var nameWrapper = document.createElement("td");
                                                nameWrapper.className = "bright";
                                                nameWrapper.innerHTML = name;
                                                senderWrapper.appendChild(nameWrapper);
                                                var addressWrapper = document.createElement("td");
                                                addressWrapper.className = "address xsmall thin dimmed";
                                                addressWrapper.innerHTML = mailObj.sender[0].address;
                                                senderWrapper.appendChild(addressWrapper);
                                                emailWrapper.appendChild(senderWrapper);
                                                var subjectWrapper = document.createElement("tr");
                                                subjectWrapper.className = "light";
                                                subjectWrapper.innerHTML = subject;
                                                emailWrapper.appendChild(subjectWrapper);
                                                wrapper.appendChild(emailWrapper);
                                                // Create fade effect.
                                                if (that.config.fade) {
                                                    var startingPoint = that.payload.slice(0,that.config.numberOfEmails).length * 0.25;
                                                    var steps = that.payload.slice(0,that.config.numberOfEmails).length - startingPoint;
                                                    if (count >= startingPoint) {
                                                        var currentStep = count - startingPoint;
                                                        emailWrapper.style.opacity = 1 - (1 / steps * currentStep);
                                                count++;
                                        else{
                                            wrapper.innerHTML = (this.loaded) ? "No new mails" : this.translate("LOADING");
                                            wrapper.className = "small dimmed";
                                            return wrapper;
                                        return wrapper;
                                    • H Offline
                                      Hacksaw
                                              var subject = mailObj.subject.replace(/[\['"\]]+/g,"");    <----- **Here this line**
                                              var subject = subject.substring(0,30);  <----- **New Line**
                                        samydp
                                        perfekt it works !!
                                        but I’d love that is hidden, the email address and the mail before each a symbol appears is that possible?
                                          samydp
                                          hello, thank you to help me by the email module !!
                                          but I have a question
                                          you can insert a symbol in front of the email?
                                          so i have think tis symbol
                                          • ? Offline
                                            A Former User
                                            said in Email:
                                            Link to module
                                            Just getting : Loading
                                            Any tips on resolving? Thx
                                            • 2 / 5
