    Email
    92 Posts 36 Posters 130.2k Views 39 Watching
      davidrq7
      Hi guys can any 1 help me? Email module shows all the time no new emails, and the console looks like this: 0_1491837734246_17857461_1549238255109393_1377519403_n.jpg
      Edit: Solved. Just added “subjectlength: 50” at the end of script and works fine :)
      • G Offline
        Gungnir83
        I refer to the possibility of a multiaccount module.
        I tried to make 2 directories email_a and email_b, uninstalled the module, customized the mail.js und installed it again.
        In the “global” config I added both modules into the array with their new names (email_a email_b) with all the other neccessary information like the auth…
        But when I start the mirror app, nothing happens. I see, that the helpers start, but no tries to fetch mails.
        And no errors.
        Any suggestions?
          apm1007 @ronny3050
          @ronny3050 i would like to display only unread emails. thank you.
          • G Offline
            gismo2006
            I use this modul for a long time. but now I have a little question,
            is it possible to set a intervall to check new emails?? Like every 10 Minutes for example.
            And if it isn´t possible can I easy put this option in any way?
            I have to say my coding experencie isn´t very good, so because there is a easy way. :-)
            greets gismo
              ronny3050 Module Developer
              Updated email module.
              Now supports:
              • Multiple email accounts
              • Will not crash on too many unread emails
              • Better fetching of recent and unread emails
                ronny3050 Module Developer @eugenelai
                @eugenelai @apm1007 @Gungnir83 Please update. :)
                • P Offline
                  Preve
                  Done the update and now email is “Loading”. Nothing more than this.
                  Anyone knows why?
                  The bottom error I got after the “npm install”.
                    ronny3050 Module Developer @Preve
                    @Preve Thanks for the heads up. The bottom parts are warnings and have nothing to do with the module not working. Loading for a long time indicates problem with communicating with your email service.
                      rodofrn @ronny3050
                      @ronny3050 I have the same problem as Preve, I have tried multiple email accts, and nothing. Happened after I updated MM. Any ideas?
                        stephenmelody
                        Hey @ronny3050, is there a way to only show the sender’s name and not their email address?
                        • 6
                        • 7
                        • 8
                        • 9
                        • 10
                        • 6 / 10
