    Email
    92 Posts 36 Posters 131.3k Views 39 Watching
    • U Offline
      umairshah @Mykle1
      @Mykle1 I have moved it to module but it is not working
      • E Offline
        E3V3A @amanzimdwini
        This post is deleted!
        • U Offline
          umairshah
          When I wrote the command npm install
          it showed error no License and no repository field found
          then I added repository and license
          but it shows that email@0.0.1 is not valid license spdx expression
          “license” : {
          “type” : “MIT”
          • I Offline
            ime90
            I’m still having trouble.
            I believe I setup everything correctly. Added the subjectlength at the end, allowed IMAP in my gmail account, but still, after loading the module won’t connect to my mail and doesn’t show anything. Is anyone else having trouble with this?
            • justjim1220J Offline
              justjim1220 Module Developer @umairshah
              @umairshah
              If you add a module to the default folder, you have to make the necessary changes to the default.js file to include it.
              It’s just better to put it in the modules folder.
              Jim Hallock - 1995
              U 1 Reply Last reply Reply Quote 0
              • U Offline
                umairshah @justjim1220
                @justjim1220 said in Email:
                @justjim
                It is not in default folder, it is in the module folder.
                when I download and tried to install it gave error of no repository and license field in package.json, but when I add those fields in package.json then it showed spdx expression error.
                justjim1220J 1 Reply Last reply Reply Quote 0
                  @umairshah
                  @ime90
                  Can you show your config.js file here?
                  Make sure you hide personal info…
                  Jim Hallock - 1995
                  • I Offline
                    ime90 @justjim1220
                    @justjim1220
                    var config = {
                    address: “localhost”,
                    port: 8080,
                    ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”],
                    language: "en",
                    timeFormat: 24,
                    units: "metric",
                    		module: "alert",
                    		module: 'email',
                                    position: 'bottom_left',
                                    header: 'Email',
                                        accounts: [
                                                user: '**@gmail.com',
                                                password: '**',
                                                host: 'imap.gmail.com',
                                                port: 993,
                                                tls: true,
                                                authTimeout: 10000,
                                                numberOfEmails: 2,
                                        fade: true,
                                        maxCharacters: 30,
                    		    subjectLength: 50
                    		module: "updatenotification",
                    		position: "top_bar"
                    		module: "clock",
                    		position: "top_left"
                    		header: "US Holidays",
                    					symbol: "calendar-check-o ",
                    					url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics"
                    		module: "compliments",
                    		position: "lower_third"
                    		module: "currentweather",
                    			locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
                    			appid: "YOUR_OPENWEATHER_API_KEY"
                    		module: "weatherforecast",
                    		header: "Weather Forecast",
                    			locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
                    		module: "newsfeed",
                    		position: "bottom_bar",
                    			feeds: [
                    					title: "New York Times",
                    			showSourceTitle: true,
                    			showPublishDate: true
                    if (typeof module !== “undefined”) {module.exports = config;}
                    justjim1220J 2 Replies Last reply Reply Quote 0
                      justjim1220 Module Developer @ime90
                      @ime90
                      Try changing the fade to false.
                      Make sure your email address and password are case correct (uppercase and lowercase).
                      Other than that, I don’t see an issue with the syntax.
                      You did change the config.js.sample to config.js, correct?
                      Jim Hallock - 1995
                        @ime90
                        Also…
                        I have found that some modules don’t work as well with the single quotes (’ ').
                        Try changing them all to the double quotes (" ")
                        Jim Hallock - 1995
                        • 6
                        • 7
                        • 8
                        • 9
                        • 10
                        • 8 / 10
