    Email
    92 Posts 36 Posters 149.1k Views 39 Watching
    • M
      MSimonart @davidrq7
      @davidrq7 Do you remember what you did to solve this? cause I have the same problem
      • M
        MSimonart
        Hi, when starting up the Mirror, email shows loading…
        in my terminal i see the following:
        NEW MAIL
        NEW MAIL
        NEW MAIL
        Email notifier error: { Error: Timed out while autenticating with server at Timeout._onTimeout (/home/pi/MagicMirror/modules/email/node_modules/imap/lib/Connection
        my config looks good,
        Accounts: [
        user: ‘XX@hotmail.com’,
        password: ‘’,
        host: ‘imap-mail.outlook.com’,
        port: 993,
        tls: true,
        authTimeout: 10000,
        numberOfEmails: 5
        fade: true,
        maxCharacters: 30
        • M
          MSimonart
          ok, it works, now for the css of the .address text, the text is not well readable on the mirror, there is like some sort of gradient or something effect on the font/text. How do I disable this?
          • strawberry 3.141S
            strawberry 3.141 Project Sponsor Module Developer @MSimonart
            @MSimonart here is no gradient effect, probably you mean the default magicmirror class dimmed, you can overwrite it for that module in the custom css
            .email .dimmed {
              color: #aaa;
            • G
              Gxnfr Ali @apm1007
              @apm1007 hello
              • M
                MSimonart @strawberry 3.141
                @strawberry-3.141 Ok i’ll try, thanks
                • G
                  Gxnfr Ali @MSimonart
                  @MSimonart
                  no new email show
                    secblizz
                    Same problem here. The module recieves the Mails but they weren’t shown in the mirror
                    //edit: fixed my problem. Fade has to be false…
                    • U
                      umairshah
                      I have added the module in Default folder named it email
                      and added the module in config.js from the Github link followed here
                      https://github.com/ronny3050/email-mirror
                      but nothing is shown on screen.
                      Mykle1M justjim1220J 2 Replies Last reply Reply Quote 0
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @umairshah
                        @umairshah
                        The email module folder goes in the modules folder but not inside the default folder
                        U 1 Reply Last reply Reply Quote 0
                        • U
                          umairshah @Mykle1
                          @Mykle1 I have moved it to module but it is not working
                          • E
                            E3V3A @amanzimdwini
                            This post is deleted!
                            • U
                              umairshah
                              When I wrote the command npm install
                              it showed error no License and no repository field found
                              then I added repository and license
                              but it shows that email@0.0.1 is not valid license spdx expression
                              “license” : {
                              “type” : “MIT”
                              • I
                                ime90
                                I’m still having trouble.
                                I believe I setup everything correctly. Added the subjectlength at the end, allowed IMAP in my gmail account, but still, after loading the module won’t connect to my mail and doesn’t show anything. Is anyone else having trouble with this?
                                • justjim1220J
                                  justjim1220 Module Developer @umairshah
                                  @umairshah
                                  If you add a module to the default folder, you have to make the necessary changes to the default.js file to include it.
                                  It’s just better to put it in the modules folder.
                                  “Life’s Too Short To Dance With Ugly People”
                                  Jim Hallock - 1995
                                  • U
                                    umairshah @justjim1220
                                    @justjim1220 said in Email:
                                    @justjim
                                    It is not in default folder, it is in the module folder.
                                    when I download and tried to install it gave error of no repository and license field in package.json, but when I add those fields in package.json then it showed spdx expression error.
                                    justjim1220J 1 Reply Last reply Reply Quote 0
                                    • justjim1220J
                                      @umairshah
                                      @ime90
                                      Can you show your config.js file here?
                                      Make sure you hide personal info…
                                      Jim Hallock - 1995
                                      • I
                                        ime90 @justjim1220
                                        @justjim1220
                                        var config = {
                                        address: “localhost”,
                                        port: 8080,
                                        ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”],
                                        language: "en",
                                        timeFormat: 24,
                                        units: "metric",
                                        		module: "alert",
                                        		module: 'email',
                                                        position: 'bottom_left',
                                                        header: 'Email',
                                                            accounts: [
        user: '**@gmail.com',
        password: '**',
        host: 'imap.gmail.com',
        port: 993,
        tls: true,
        authTimeout: 10000,
        numberOfEmails: 2,
                                                            fade: true,
                                                            maxCharacters: 30,
                                        		    subjectLength: 50
                                        		module: "updatenotification",
                                        		position: "top_bar"
                                        		module: "clock",
                                        		position: "top_left"
                                        		header: "US Holidays",
                                        					symbol: "calendar-check-o ",
                                        					url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics"
                                        		module: "compliments",
                                        		position: "lower_third"
                                        		module: "currentweather",
                                        			locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
                                        			appid: "YOUR_OPENWEATHER_API_KEY"
                                        		module: "weatherforecast",
                                        		header: "Weather Forecast",
                                        			locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
                                        		module: "newsfeed",
                                        		position: "bottom_bar",
                                        			feeds: [
                                        					title: "New York Times",
                                        			showSourceTitle: true,
                                        			showPublishDate: true
                                        if (typeof module !== “undefined”) {module.exports = config;}
                                        • justjim1220J
                                          justjim1220 Module Developer @ime90
                                          @ime90
                                          Try changing the fade to false.
                                          Make sure your email address and password are case correct (uppercase and lowercase).
                                          Other than that, I don’t see an issue with the syntax.
                                          You did change the config.js.sample to config.js, correct?
                                          Jim Hallock - 1995
                                          • justjim1220J
                                            @ime90
                                            Also…
                                            I have found that some modules don’t work as well with the single quotes (’ ').
                                            Try changing them all to the double quotes (" ")
                                            Jim Hallock - 1995
                                            • 4 / 5
