    MMM-Button white screen
    23 Posts 9 Posters 19.4k Views 8 Watching
    • F
      FlorianRD
      He guys. Another error log after raspberry startup. Maybe helps?
      pi@raspberrypi:~ $ npm start dev
      npm ERR! Linux 4.4.26-v7+
      npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start" "dev"
      npm ERR! node v6.9.1
      npm ERR! npm  v3.10.8
      npm ERR! path /home/pi/package.json
      npm ERR! code ENOENT
      npm ERR! errno -2
      npm ERR! syscall open
      npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
      npm ERR! enoent This is most likely not a problem with npm itself
      npm ERR! enoent and is related to npm not being able to find a file.
      npm ERR! enoent
      npm ERR!     /home/pi/npm-debug.log
      Y 1 Reply Last reply
      • Y
        yawns Moderator @FlorianRD
        @FlorianRD
        you are in the wrong directory.
        cd MagicMirror
        npm start dev
        • F
          FlorianRD
          Okay, next try…
          npm ERR! node v7.4.0
          npm ERR! npm  v4.0.5
          npm ERR! code ELIFECYCLE
          npm ERR! magicmirror@2.0.0 start: `electron js/electron.js "dev"`
          npm ERR! Exit status 1
          npm ERR!
          npm ERR! Failed at the magicmirror@2.0.0 start script 'electron js/electron.js "dev"'.
          npm ERR! If you do, this is most likely a problem with the magicmirror package,
          npm ERR! not with npm itself.
          npm ERR!     electron js/electron.js "dev"
          npm ERR!     npm bugs magicmirror
          npm ERR! Or if that isn't available, you can get their info via:
          npm ERR!     npm owner ls magicmirror
