    Current Weather giving wrong time and weather
    13 Posts 8 Posters 11.8k Views 8 Watching
      Arod192
      Hello, I believe I’m using the correct location id. I wasn’t able to go to the website that’s listed in the config, bulk.openweather.org, so I went to http://openweathermap.org/help/city_list.txt. I’m trying to display the weather for El Centro California and the id on there is ‘5345609’ but weather still seems off.
        Shawnsully @Arod192
        @Arod192 I am having the same issue. It shows a forecast, but that forecast doesn’t really match what the news calls for. Its off by like 10 degrees
        • L Offline
          l8kerjuan @Shawnsully
          @Shawnsully did you ever get a fix for this. mine is also currently off about 7-12°
          • I Offline
            in_a_days @l8kerjuan
            @l8kerjuan
            I suspect this is a problem with openweathermap. My temps and wind speeds have been incorrect for the last couple days as well. I didn’t change anything, just getting bad data. Last night the temp data I was getting over api did not match the weather data on their site - and today even the site-based weather info is off:
            http://openweathermap.org/city/5505411
            currently showing 34.9 F when it’s actually about 47 F.
            Try submitting a “Wrong data” report to openweathermap and hopefully it’s something they can straighten out soon.
            What ship would bear me ever back across so wide a Sea?
            • I Offline
              in_a_days
              You can also substitute a different weather module that uses an alternate weather service. I think this one is my fav:
              https://github.com/RedNax67/MMM-WunderGround
              • L Offline
                l8kerjuan @in_a_days
                @in_a_days gotcha… yeah seem to be seeing a lot of people reporting wrong info… will send them a wrong data report. thanks
                • L Offline
                  @in_a_days I am VERY GREEN to this coding and still haven’t figured out how to use github… not sure how to even add something new yet… do you know where is the easiest way to learn or have a video walkthrough… everything i have done so far has just been doing what i see. cant say i have learned what i am actually doing… if that makes sense??
                  • I Offline
                    @l8kerjuan
                    I’m basically a newbie too. I haven’t seen any video tutorials for installing new modules. But this one I’m recommending has some very simple installation instructions. Feel free to send a PM if you want me to walk you through the process.
                    • P Offline
                      pflnpi0305
                      This post is deleted!
                      • F Offline
                        fordi
                        Has anyone found out how to correct the time? Thanks.
                        Mykle1M StoffbeuteluweS 2 Replies Last reply Reply Quote 0
                          Mykle1 Project Sponsor Module Developer @fordi
                          @fordi
                          Are you sure you’re not talking about the sunrise and sunset time in the currentweather module? Is there a little icon pointing up or down next to it?
                          • StoffbeuteluweS Offline
                            Stoffbeuteluwe Project Sponsor @fordi
                            @fordi there is no Time in the weathermodule
                            it is the time for rise and set of the sun :sun_with_face:
                            • F Offline
                              fordi
                              You know what guys, i never realised but i think you’re right its a sunset time. Thank you for pointing this out.
