New and confused.
55 Posts 5 Posters 29.5k Views 5 Watching
  • C Offline
    cowboysdude Module Developer @mickyas
    @mickyas said in New and confused.:
    Well me and my ten thumbs were playing around and i entered the config.js file to alter parts of the weather module ( i managed to get an API key and my location I.D. as the weather in New York doesn’t really interest me at the mo :-))) ) and entered them in to the code, between the speech marks, saved it and then ran MM but the weather module wasn’t present, everything else was …any ideas??? Next will be altering the holidays/calendar etc (i’m trying to work out how to use my google calendar with all of my saved dates etc, so expect more questions) :0. Thanks.
    Mick
    My advice is always the same… if you have a working config.js then copy it to config.bak then you know no matter what you’ll never be down :)
    THEN:
    It’s easier if you post your config.js minus the api keys just put xx in place of that… then we can peek at it :)
    M 1 Reply Last reply Jun 26, 2017, 5:53 PM Reply Quote 0
      Mykle1 Project Sponsor Module Developer @mickyas
      You likely made a small mistake somewhere. As @cowboysdude said, it would be easier for us to help you if would copy and paste that portion of your config.js file (minus the API key)
      Go to your google calendar. On the LEFT side of the page you’ll see My Calendars, Other Calendars. Hover (don’t click) your mouse over the individual calendar that you want. A down arrow v appears to the RIGHT of the calendar. Click the down arrow v and choose Calendar settings. Click the green ICAL button. This will give you the url you need to enter into the calendar module
      M 1 Reply Last reply Jun 26, 2017, 5:56 PM Reply Quote 0
        mickyas @cowboysdude
        @cowboysdude Sorry but you assume i know what you’re on about :-)))) what’s config.bak??? I have NO knowledge whatsoever of any kind of coding etc, my computer abilities stretch as far as writing a n e-mail and doing the odd letter. :-))).
        Mick
        M 1 Reply Last reply Jun 26, 2017, 6:57 PM Reply Quote 0
          mickyas @Mykle1
          @Mykle1 Damn…you’re a genius :-))))))))))))))))))))))))))
          M 1 Reply Last reply Jun 26, 2017, 7:03 PM Reply Quote 1
            What @cowboysdude means is this:
            When you have a working config.js file and BEFORE you’re going to edit it (ex adding another module) you should make a backup of that config.js file. Then you do your edit. If something goes awry, you have your backup file that you KNOW is working.
            Simply: Go to your working config.js file. Right click on it. Choose Copy. Right click somewhere else in that same window. Choose Paste. Rename the copy to config.bak as @cowboysdude instructed. Click Rename.
            So now you’ve have a file named config.bak. If something goes wrong with your working config.js file, you can delete it and rename your backup to config.js. So, make a backup every time you successfully make additions to your config.js so you don’t have to start from square one.
            I hope you’re writing this down. ;-)
              Damn…
              Oh, hey Mick,
              When you want help with your config.js file you really should copy and paste it here so that we can look at it as @cowboysdude and I have both advised. Surely you know how to copy and paste! :-)
              M 1 Reply Last reply Jun 26, 2017, 7:28 PM Reply Quote 1
                mickyas @Mykle1
                @Mykle1 said in New and confused.:
                Damn…
                Oh, hey Mick,
                I do, but since i haven’t worked out how to tether my laptop o my PI…it’s a slow laborious process :-))))))))))))))
                Well, got my calendar and newsfeed changed and both up and running, just working on my weathermap. I’ll try and sort out copying it here :-))) thanks for the step by step, it worked perfectly first time :-)))
                Mick
                  mickyas
                  ok here goes…this is what i have for the weathermap…
                  module: “currentweather”,
                  position: “top_right”,
                  locationID: “8224783”, //ID from http://www.openweathermap.org/help/city_list.txt
                  appid: “my api i.d. here”
                  In the location i had written “stanley” but it made no difference. the above is the same for module “weatherforecast”
                  mick
                    Assuming your location ID is correct, and that your API key is valid and that you enter your API key precisely, inside the quotes, this will work for you. The location doesn’t matter as it is overridden by the locationID. Refer to the guide on adding a module. You can copy and paste what I’ve entered below.
                    module: "currentweather",
                       locationID: "8224783", //ID from http://www.openweathermap.org/help/city_list.txt
                       appid: "my api i.d. here"
                    M 1 Reply Last reply Jun 26, 2017, 8:25 PM Reply Quote 0
                      mickyas @Mykle1
                      @Mykle1 MINT…worked a treat, :-)))))))))))))) I don’t know what i had different, as i never changed anything else in the module other than the location i.d. and the api key!!! anyhoo, all up and running…next stop changing the ‘compliments’ :-)))) I owe you a pint :-)) (although i do have some home grown cider on the go ;-))
                      Mick
                      M 1 Reply Last reply Jun 26, 2017, 8:38 PM Reply Quote 2
                      • 6
                      • 4 / 6
                      4 / 6
