    New and confused.
    55 Posts 5 Posters 37.4k Views 5 Watching
    • cowboysdudeC Offline
      cowboysdude Module Developer @caseyrcoughlin
      @caseyrcoughlin said in New and confused.:
      @cowboysdude said in New and confused.:
      That makes life so much easier, can’t believe I didn’t think to hit the ALT key before. So I got into the config menu through the terminal but I messed some stuff up and deleted a few of the modules that I want back to mess around with some more. I’d like to uninstall and reinstall Magic Mirror. How do I uninstall it?
      EDIT - Nevermind, figured out how to install it again. At least a workaround anyway. I renamed the old Magic Mirror and I’m reinstalling it again. I’d imagine I’ll have about 25 failed versions of Magic Mirror under various names before I get it to how I want it lol. Is there anyway to delete these files off of the RPi?
      DO NOT feel bad…we’ve all been there :) You’re trying and that’s what this project is all about. Feel free to ask questions… it’s how we learn ;)
      • mickyasM Offline
        mickyas
        Well me and my ten thumbs were playing around and i entered the config.js file to alter parts of the weather module ( i managed to get an API key and my location I.D. as the weather in New York doesn’t really interest me at the mo :-))) ) and entered them in to the code, between the speech marks, saved it and then ran MM but the weather module wasn’t present, everything else was …any ideas??? Next will be altering the holidays/calendar etc (i’m trying to work out how to use my google calendar with all of my saved dates etc, so expect more questions) :0. Thanks.
        Mick
        cowboysdudeC Mykle1M 2 Replies Last reply Reply Quote 0
          cowboysdude Module Developer @mickyas
          @mickyas said in New and confused.:
          Mick
          My advice is always the same… if you have a working config.js then copy it to config.bak then you know no matter what you’ll never be down :)
          THEN:
          It’s easier if you post your config.js minus the api keys just put xx in place of that… then we can peek at it :)
          mickyasM 1 Reply Last reply Reply Quote 0
            Mykle1 Project Sponsor Module Developer @mickyas
            You likely made a small mistake somewhere. As @cowboysdude said, it would be easier for us to help you if would copy and paste that portion of your config.js file (minus the API key)
            Go to your google calendar. On the LEFT side of the page you’ll see My Calendars, Other Calendars. Hover (don’t click) your mouse over the individual calendar that you want. A down arrow v appears to the RIGHT of the calendar. Click the down arrow v and choose Calendar settings. Click the green ICAL button. This will give you the url you need to enter into the calendar module
            • mickyasM Offline
              mickyas @cowboysdude
              @cowboysdude Sorry but you assume i know what you’re on about :-)))) what’s config.bak??? I have NO knowledge whatsoever of any kind of coding etc, my computer abilities stretch as far as writing a n e-mail and doing the odd letter. :-))).
              Mick
              • mickyasM Offline
                mickyas @Mykle1
                @Mykle1 Damn…you’re a genius :-))))))))))))))))))))))))))
                  What @cowboysdude means is this:
                  When you have a working config.js file and BEFORE you’re going to edit it (ex adding another module) you should make a backup of that config.js file. Then you do your edit. If something goes awry, you have your backup file that you KNOW is working.
                  Simply: Go to your working config.js file. Right click on it. Choose Copy. Right click somewhere else in that same window. Choose Paste. Rename the copy to config.bak as @cowboysdude instructed. Click Rename.
                  So now you’ve have a file named config.bak. If something goes wrong with your working config.js file, you can delete it and rename your backup to config.js. So, make a backup every time you successfully make additions to your config.js so you don’t have to start from square one.
                  I hope you’re writing this down. ;-)
                    Damn…
                    Oh, hey Mick,
                    When you want help with your config.js file you really should copy and paste it here so that we can look at it as @cowboysdude and I have both advised. Surely you know how to copy and paste! :-)
                    mickyasM 1 Reply Last reply Reply Quote 1
                    • mickyasM Offline
                      mickyas @Mykle1
                      @Mykle1 said in New and confused.:
                      Damn…
                      Oh, hey Mick,
                      I do, but since i haven’t worked out how to tether my laptop o my PI…it’s a slow laborious process :-))))))))))))))
                      Well, got my calendar and newsfeed changed and both up and running, just working on my weathermap. I’ll try and sort out copying it here :-))) thanks for the step by step, it worked perfectly first time :-)))
                      Mick
                      • mickyasM Offline
                        mickyas
                        ok here goes…this is what i have for the weathermap…
                        module: “currentweather”,
                        position: “top_right”,
                        locationID: “8224783”, //ID from http://www.openweathermap.org/help/city_list.txt
                        appid: “my api i.d. here”
                        In the location i had written “stanley” but it made no difference. the above is the same for module “weatherforecast”
                        mick
                          Assuming your location ID is correct, and that your API key is valid and that you enter your API key precisely, inside the quotes, this will work for you. The location doesn’t matter as it is overridden by the locationID. Refer to the guide on adding a module. You can copy and paste what I’ve entered below.
                          module: "currentweather",
                             locationID: "8224783", //ID from http://www.openweathermap.org/help/city_list.txt
                             appid: "my api i.d. here"
                          • mickyasM Offline
                            mickyas @Mykle1
                            @Mykle1 MINT…worked a treat, :-)))))))))))))) I don’t know what i had different, as i never changed anything else in the module other than the location i.d. and the api key!!! anyhoo, all up and running…next stop changing the ‘compliments’ :-)))) I owe you a pint :-)) (although i do have some home grown cider on the go ;-))
                            Mick
                              My favorite pint and my favorite pub to drink it in. Unfortunately, it’s 3,459 miles away from where I live, on the other side of the pond.
                              mickyasM 1 Reply Last reply Reply Quote 3
                              • mickyasM Offline
                                mickyas @Mykle1
                                @Mykle1 Just a couple of questions…
                                1. I noticed a previous post from you about the colour weather module you installed, is it available to clone???
                                2. Can i have multiple modules running at once, or do i have to switch between them…i.e the Magic mirror, Alexa, remote control (which i’d really like to try) etc?
                                  Mick
                                This is crazy…the more i search, the more confused i become and the more i get distracted by the umpteen modules i’d like to have :-)))…first off is using my laptop to access the pi3 (its annoying trying to pull up pages etc on the pi).
                                P.S. just done it using VNC all working so far :-)))
                                  I’m pretty sure you mean WunderGround. That’s what I use. Here is the link.
                                  https://github.com/RedNax67/MMM-WunderGround
                                  Also, @j-e-f-f has done some remarkable things with some weather modules. Look around/search for his work.
                                  Not sure what you mean here. Yes, you can have many modules running at the same time. Didn’t you start out with a clock, and a calendar, and a newsfeed, all at the same time?
                                  I think everyone goes through that, including me. I wanted to LOAD UP on as many modules as I could fit on the mirror. Ultimately, I chose the ones that I like the most, with a few of my own. You’ll have to decide what you want at some point. It doesn’t hurt to try them all to decide what you want.
                                  Yes, I use VNC also. I haven’t touched the actual mirror in months. I just sit at my dev machine and work on the mirror from there
                                  mickyasM 2 Replies Last reply Reply Quote 1
                                    Is this the weather you mean? See the link above
                                    • mickyasM Offline
                                      mickyas @Mykle1
                                      • mickyasM Offline
                                        mickyas @Mykle1
                                        Ah, there’s my confusion…i thought the magic mirror (date, weather, calendar etc) was one module. :-))
                                        I was wondering if it is possible to have the magic mirror 2 running on the screen with Alexa ‘asleep’ in the background to be woken with a ‘wake’ word and say, a music app playing etc.
                                        Yes, the WunderGround is the one i was looking at…very nice.
                                        Mick
                                        Heeds battered…how do i use the wunderground module ??? i have opened the magic mirror config js file i have copied and pasted the block of code (using git clone etc) but it comes up with an error telling me to ‘Please create a config file’ ??? (tried the 3 back-tick rule for code, but this is how it came out)
                                        	port: 8080,
                                        	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses.
                                        	language: "en",
                                        	timeFormat: 24,
                                        	units: "metric",
                                            module: 'MMM-WunderGround',
                                            position: 'top_right',
                                                apikey: 'my api i.d. here', // private; don't share!
                                                pws: 'pws:DH9 6PA', //England
                                                hourly: '1',
                                                fctext: '1',
                                                fcdaycount: "5",
                                                fcdaystart: "0",
                                                hourlyinterval: "3",
                                                hourlycount: "2",
                                                alerttime: 10000,
                                                alerttruncatestring: "english:",
                                        	roundTmpDecs: 1,
                                        	UseCardinals: 0,
                                        	layout: "horizontal",
                                        	sysstat: 0
                                        			module: "alert",
                                        			module: "updatenotification",
                                        			position: "top_bar"```
                                          ‘top_right’
                                          Well my guess would be that you copied the config from one place to another … replace all of these ` [backtick] with this ’ [single quote]
                                          Then retry ;)
                                            Well, the instructions should be in the README file that came with the module. At this point, you should be making entries without a problem. :-)
                                            I can tell you that the pws: 'pws:DH9 6PA', you are using is no good. I just tried it in mine, with and without the space, which drew my attention.
                                            So, try this when posting code with back-ticks:
                                            Put 3 backticks on a new line and Enter
                                            Post your code under the backticks and Enter
                                            And, just in case, NO backticks in your config.js file
                                            • 2 / 3
