    New and confused.
    55 Posts 5 Posters 39.3k Views 5 Watching
    • mickyasM
      mickyas @Mykle1
      @Mykle1 Thank you (again) mykle, but that link is as clear as mud to me :-)))))))))))))))))))))))))))))))) I have NO knowledge or experience of coding, terminology or anything even closely resembling this (ask anything you want about building work or fibre optic production facility set-ups and i’m your man, but this !!!..) :-))))
      • SexyTroggS
        SexyTrogg @mickyas
        @mickyas Its an example of what options are available. Every module has to be placed into the Magic Mirror config file and inside of that file will be the settings for each module. For example:
        	module: "compliments",
        	position: "lower_third",	// This can be any of the regions.
        								// Best results in one of the middle regions like: lower_third
        		// If no config is set, the default compliments are shown.
        Above is taken from the compliments module. As you can see there is the position:“lower_third” option. The link I gave you gives you all of the other options for where you can place your module.
        As for colors, the link only used colors to help make each region stand out. Modules set their colors through their .css files so you can always go into that and change it to your needs.
        mickyasM 1 Reply Last reply
        • mickyasM
          mickyas @SexyTrogg
          @SexyTrogg Just tried from the link you sent me…didn’t work.
          I opened a terminal put in … sudo nano /boot/config.txt (pressed enter)
          then added …display_rotate=1
          avoid_warnings=1 (it already had the display_rotate=1 as the first line)
          then i pressed ctrl x and saved, then rebooted, No difference still wrong orientation. :-((( I even tried changing the text ‘vertical’ to horizontal’ and still nothing. I’d already altered the screen orientation (playing around) from horizontal to vertical but i’d like to change it back but nowt happening :-(
          Mick
          SexyTroggS Mykle1M 2 Replies Last reply
          • SexyTroggS
            SexyTrogg @mickyas
            @mickyas Id use the advice that @Mykle1 gave. The Xscreensaver is really easy to use and is much easier than editing a file through the terminal
            • mickyasM
              mickyas @SexyTrogg
              @SexyTrogg Just to clarify…every time i’d like to add a module i have to first open a terminal then enter … sudo nano /boot/config.txt … then (copy and paste?) enter the text/code (copy and paste?) for the module…where?..anywhere? Then ctrl x and save then reboot???
              Mick
              SexyTroggS 1 Reply Last reply
              • SexyTroggS
                SexyTrogg @mickyas
                @mickyas That’s the hard way (in my opinion).
                I use Filezilla to connect to my PI though FTP. That lets me easily click and drag new modules into the /modules folder. I also use FTP to download the config file to my PC and make edits there before I upload it back. But yes, every module needs for you to manually add it to the config. All modules on github follow a similar format where the Readme will give an example of the lines of code you need to put into the config.
                • Mykle1M
                  Mykle1 Project Sponsor Module Developer @mickyas
                  @mickyas said in New and confused.:
                  When I said “reverse the directions” I guess I wasn’t clear enough. The directions are telling to you to “add” display_rotate=1. You want to “remove” that line of code because that is telling your system to rotate the screen. If that line of code is there twice then you need to remove both instances for your screen to go back to landscape mode.
                  Mykle1M 1 Reply Last reply
                  • Mykle1M
                    Mykle1 Project Sponsor Module Developer @Mykle1
                    Mick, here’s an easier way to add a module and you only have to use the terminal once. Lets use my MMM-JEOPARDY module as test. Go to this page of modules https://github.com/MichMich/MagicMirror/wiki/MagicMirror²-Modules#3rd-party-modules and scroll down until you see MMM-JEOPARDY by Mykle1 . Click on it.
                    Now you’re at my repo for that module. Click on the green Clone or download button on the right. That shows you the url to get the module. Copy that url.
                    Now open a terminal and type cd MagicMirror/modules. Now you’re in the MagicMirror/modules directory. Now type git clone and one space and paste the url that you copied from my repo for the module. It should look like this:
                    git clone https://github.com/mykle1/MMM-JEOPARDY.git and press your Enter key. This will download the module into the modules folder where it belongs.
                    You’re now done with the terminal! (for now)
                    From your Pi desktop, click the File Manager folder. Double click the MagicMirror folder. Double click the config folder. Double click the config.js file. Your config.js file is now open in a text editor. You have to add an entry for the module you just downloaded so that MM knows to load it. Lets put MMM-JEOPARDY under your calendar module entry so that it appears under the calendar on your mirror. Modules that occupy the same postition load in the order they appear in the config.js file. Scroll down to the calendar entry in the config.js file. The entry “ends” at the last }, before the next module entry that begins with a single {.
                    Copy and paste this “between” the ending of the calendar module entry and the beginning of the next module. (It’s probably compliments)
                    		disabled: false,
                    		module: "MMM-JEOPARDY",
                    			rotateInterval: 25 * 1000,         // New Clue Appears
                    			useHeader: false,                  // true if you want a header
                    			header: "This is Jeopardy!",
                    			maxWidth: "250px",
                    			animationSpeed: 3000,              // Fades to next clue
                    SAVE!
                    Go back to your terminal, or open a new one, and type npm start in the MagicMirror directory.
                    From now on, you’ll find the entry you need to make in the README file of each module that you download. You now have a guide on how to do that.
                    mickyasM C 2 Replies Last reply
                    • mickyasM
                      mickyas @Mykle1
                      @Mykle1 Perfect description of how to carry out an install, i like laymans terms :-))) step by step…perfect, much appreciated. :-))
                      Mick
                      • Mykle1M
                        You’re welcome. Enjoy your mirror.
                          caseyrcoughlin @Mykle1
                          @Mykle1 said in New and confused.:
                          		disabled: false,
                          			maxWidth: "250px",
                          SAVE!
                          Another newbie here but instead of starting my own thread, I’ll just piggyback on this one. This helped me understand things a lot but I think I’m either doing something wrong or the raspberry pi isn’t wanting to work with me.
                          I went in to the File Manager folder and saw everything that was supposed to be there. But when I tried to open the config.js file it didn’t pull up a text editor. Instead I had to choose a program to open it with and when I chose the text editor or anything else for that matter it just closed the program selection window and then nothing else happened. So I was never able to pull anything up to edit or add to it. Any ideas?
                          EDIT - So I came back to it this morning and while I still wasn’t able to get it to work I figured out that I was asking it to open with a program it’s not able to open with, like text editor under accessories in the “Choose Application” menu. So I tried to open it with the Terminal and it acted like it was going to open and gave me a pointer with an hourglass next to it and after about 7 seconds or so nothing happened and the hourglass went away. So I’m still doing something wrong, still not sure what. Any help is appreciated.
                          • Mykle1M
                            Mykle1 Project Sponsor Module Developer @caseyrcoughlin
                            @caseyrcoughlin said in New and confused.:
                            A few questions:
                            Can you create a new document with your text editor? If so, then the problem is NOT your text editor.
                            Is your config.js file named EXACTLY, “config.js”? The icon should look like a “gear”. Text files should look like a page of text. If the file “type” is incorrect then that could make the text editor unable to open the file. Check the properties of the file.
                            Long shot here: Are you sure the file isn’t opening below the visible area of the window? Meaning, make sure you scroll all the way through the entire window as the file may have opened outside of your view.
                            C 1 Reply Last reply
                              A few questions:
                              The file is named config.js exactly with a gear for an icon. It also has a config.js.sample next to it and the icon looks like a page with lines on it so I’m assuming that’s a text file. But as far as the Text Editor, therein may lie the problem. I can’t even find the text editor on my raspberry pi…does it not come with one? It comes up on the “Choose Application” box under “Accessories” but under the Applications Menu under “Accessories” I only have File Manager, Task Manager, and Terminal. Also, another question…when the Magic Mirror is running, how to I get it to stop and get back to the desktop GUI? I’ve just been rebooting it so far.
                              • cowboysdudeC
                                cowboysdude Module Developer @caseyrcoughlin
                                A few questions:
                                Hit the ALT key on the keyboard and a menu will pop up at the top… from there you can exit MM.
                                  caseyrcoughlin @cowboysdude
                                  @cowboysdude said in New and confused.:
                                  That makes life so much easier, can’t believe I didn’t think to hit the ALT key before. So I got into the config menu through the terminal but I messed some stuff up and deleted a few of the modules that I want back to mess around with some more. I’d like to uninstall and reinstall Magic Mirror. How do I uninstall it?
                                  EDIT - Nevermind, figured out how to install it again. At least a workaround anyway. I renamed the old Magic Mirror and I’m reinstalling it again. I’d imagine I’ll have about 25 failed versions of Magic Mirror under various names before I get it to how I want it lol. Is there anyway to delete these files off of the RPi?
                                  Mykle1M cowboysdudeC 2 Replies Last reply
                                  • Mykle1M
                                    @caseyrcoughlin
                                    You can delete the old folders by simply dragging them to the trash, as you would any other file or folder.
                                    It’s odd that you don’t have a text editor. What OS are you installing? Rasbian Jessie certainly has a text editor. Are you using a Pi 3? You could always install a 3rd party text editor if you wanted to. You have options.
                                    I’m curious. Open a terminal and type leafpad and Enter. This would launch the default text editor in Jessie, if that’s what you’re running.
                                    How did you manage to edit your config.js file in the first place to get your MagicMirror running? Or, you haven’t gotten that far?
                                    • cowboysdudeC
                                      DO NOT feel bad…we’ve all been there :) You’re trying and that’s what this project is all about. Feel free to ask questions… it’s how we learn ;)
                                      • mickyasM
                                        mickyas
                                        Well me and my ten thumbs were playing around and i entered the config.js file to alter parts of the weather module ( i managed to get an API key and my location I.D. as the weather in New York doesn’t really interest me at the mo :-))) ) and entered them in to the code, between the speech marks, saved it and then ran MM but the weather module wasn’t present, everything else was …any ideas??? Next will be altering the holidays/calendar etc (i’m trying to work out how to use my google calendar with all of my saved dates etc, so expect more questions) :0. Thanks.
                                        Mick
                                        cowboysdudeC Mykle1M 2 Replies Last reply
                                        • cowboysdudeC
                                          cowboysdude Module Developer @mickyas
                                          Mick
                                          My advice is always the same… if you have a working config.js then copy it to config.bak then you know no matter what you’ll never be down :)
                                          THEN:
                                          It’s easier if you post your config.js minus the api keys just put xx in place of that… then we can peek at it :)
                                          • Mykle1M
                                            You likely made a small mistake somewhere. As @cowboysdude said, it would be easier for us to help you if would copy and paste that portion of your config.js file (minus the API key)
                                            Go to your google calendar. On the LEFT side of the page you’ll see My Calendars, Other Calendars. Hover (don’t click) your mouse over the individual calendar that you want. A down arrow v appears to the RIGHT of the calendar. Click the down arrow v and choose Calendar settings. Click the green ICAL button. This will give you the url you need to enter into the calendar module
                                            • 2 / 3
