    MMM-MyScoreboard
    Scheduled Pinned Locked Moved Sport
    277 Posts 60 Posters 635.7k Views 63 Watching
    • BKeyportB
      BKeyport Module Developer
      Right, and I’m suggesting an optional change to that, so that I can eliminate the blank screens… I’d love to see a simple one line “NCAAF - No games scheduled” item available if selected by the user.
      If I was any good at JS, I’d do it myself, but adulting has kept me away from hobby programming.
      • C
        cyberphox
        This post is deleted!
        • C
          cyberphox
          • BKeyportB
            So, I did end up forking it (Off of VInP’s fork), if for nothing else to try and figure out how to do things.
            https://github.com/BKeyport/MMM-MyScoreboard
            All I’ve changed so far from VinP’s changes is line 454 - “var anyGames = true;” instead of “false”
            This results in the headers showing, which in my config results in no blank screens.
            • V
              vinp Module Developer @BKeyport
              @bkeyport Good! Always neat to try it on your own. I’ve seen and learned a lot from different MM devs. I’ve made changes to mine to show a “No scores to display” message if there are NO sports to display at all. All you need to do, if you use my fork is to add showNoSportsText: true in the config for the module. git pull of course too :) I do agree with @j-e-f-f, to try to keep the module as small as possible.
              cowboysdudeC 1 Reply Last reply Reply Quote 1
              • cowboysdudeC
                cowboysdude Module Developer @vinp
                @vinp But that’s the fun of doing this…you get to build something that you want as a user. Generally speaking most developers don’t mind helping you if you ask…others not so much LOL
                I try to help people with my modules but in all honesty I’m not going to completely rewrite something for one person… doesn’t make sense to do that. BUT yes I have had people do a fork then I help them get what they need for their own personal mirror :)
                That’s the entire reason for the “MagicMirror project”… some people see “MagicMirror” but forget the word ‘project’ LOL I have told people that this is the project you want as it offers so many options, way more than the others.
                • BKeyportB
                  Cool, Thanks, Vince - I’ve merged your updates into my fork, and I’m playing with it now. Thinking about playing around with the other (what I would consider) improvement cases I wanna do, having two or three modules to show scoreboards that are all different does irritate me to no end… :)
                  • BKeyportB
                    FWIW, I seem to have a legit bug - the group “Pac-12” seems to go random on teams in NCAAF. (using my fork of VinP’s fork of the module), I’ve overridden it by putting all the teams in individually for now.
                    • BKeyportB
                      Vince, Your mod works perfectly - once I undo mine.
                      Thanks for the head start to see how it’s modified. Will be fun to learn.
                      • C
                        cyberphox
                        Anyone else missing a few NFL logos lately?
                        • BKeyportB
                          Happens from time to time. I just turned off the logos…
                          • J
                            j.e.f.f Project Sponsor Module Developer @cyberphox
                            @cyberphox Is this on the original codebase or a fork? Mine looks like this:
                            • Jeff
                            • W
                              Wedee @j.e.f.f
                              @j-e-f-f
                              Using your repo - not the fork. Getting this today.
                              • W
                                Wedee @Wedee
                                @j-e-f-f
                                Just double checked…
                                Git Pull “Up to date”
                                And pulling from original repo…
                                • J
                                  j.e.f.f Project Sponsor Module Developer @Wedee
                                  @wedee try deleting the module and reinstalling. Not sure you’re getting the most latest. Something happened with hit on the last update where things got a little out of sync.
                                  Not saying this will solve your issue but will eliminate one factor.
                                  I’m wondering if this is a memory issue…
                                  • C
                                    cyberphox @j.e.f.f
                                    @j-e-f-f I just deleted the whole folder and reinstalled and still missing a few…although i did have a fork installed a few weeks ago…not sure if that did anything
                                    • J
                                      @cyberphox do all of the logos appear of you change your config to just show you NFL? Or if you configure it for just one of the teams that isn’t showing? I’m beginning to think the issue might be video memory.
                                      I remember when I configured my Pi I increased the amount of video memory allocated specifically because this needed to be run in the GUI desktop environment. Not sure how it behaves under the default settings.
                                      • C
                                        cyberphox
                                        Just tested with only NFL showing…I get this:
                                        • V
                                          vinp Module Developer @cyberphox
                                          @cyberphox can you try getting to your MM via URL in a remote browser http://yourPi-IPaddress:8080 ? You can then look at Developer Tools in Chrome/Firefox etc and dig into the image element that should be showing for each team. My fork works fine for images of the NFL. It takes the image URL via the ESPN feed for the logo. The original code, has local images for each team.
                                          • C
                                            cyberphox
                                            Running it in a Docker container on Synology…got it remotely open on Chrome…got the Developer Tools open…
                                            I do have a logos folder with all the Team logos there so not sure why only a few show
                                            Looks like the Was log for example is pointing to a file that does exist:
                                            J 2 Replies Last reply Reply Quote 0
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 9 / 14
