    Config.js file Syntax
    26 Posts 7 Posters 30.1k Views 6 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @jade
      @jade said in Config.js file Syntax:
      When I first started using Linux I was taught the very bad habit of switching to the root user and doing everything as root, so I moved the file into where it needs to be in /home/pi but I still have the same problem
      Again, I hate to refer to the Complete Setup Tutorial but item #7 of Notes at the very beginning of the tutorial states:
      "DO NOT INSTALL MagicMirror² as the root user! Always do it as the regular, non privileged pi user"
      With that said, your config is not the problem. I just tested it and it fired right up.
      Unless, it’s not named correctly (config.js) or MM can’t find it at its proper path
      jadeJ 1 Reply Last reply Reply Quote 0
      • jadeJ
        jade @Mykle1
        @Mykle1 I’m wondering if the problem was actually that I was using a Pi 0, I’m testing now on a Pi 2 and I’ve run the automatic installer, though it is now just sitting doing absolutely nothing, the last thing it said is:
        >node-gyp rebuild > build_log.txt 2>&1 || exit 0
        And now it’s just sitting there. It hasn’t bought the prompt back up yet so maybe I’m being impatient.
        • A
          Anhalter42 @jade
          @jade several people were struggling with PI0 IIRC. Search the forum (for example start here).
          jadeJ 2 Replies Last reply Reply Quote 0
          • jadeJ
            jade @Anhalter42
            @Anhalter42 I’ve got it mostly up and running on Pi 2 now, my only issue now is it’s loading a black screen with no info, the terminal says launching application and then access denied to IP address 0.0.0.0/0 I have no idea what’s going on now!
            • jadeJ
              jade @Anhalter42
              @Anhalter42 Ok, it’s all good, I just took the ipWhitelist section from the sample pasted it in and now I have a working mirror that sporadically gives me game of thrones quotes! My office at work is now much brighter!
              • B
                bhepler Module Developer @jade
                Well, you do until he kills off another Stark child.
