MM 2.1.2 and Node 4.3
Hello,
Can I run Mm 2.1.2 with Node 4.3? Or have I to update Mm?
I want to run MM and Pimatic on one Pi. Pimatic need Node 4.3. -
You can try but MM will likely want a newer version of node.
Have you tried Pimatic with a newer version of node? Perhaps it works with node 4.3 or higher.
There’s only one way to find out. Good luck!
