    Webcam with microphone setup
    4 Posts 3 Posters 3.6k Views 3 Watching
      adityaanandmc
      Just started experimenting with the pi - MagicMirror.
      Had few doubts regarding the camera and microphone setup I would be able to use with the pi.
      I know that the pi doesn’t have microphone support in the 3.55mm jack cause (after googling and testing
      Model: Pi 3 Model B
      I thought I’d get a webcam with built in microphones like :
      http://www.amazon.in/Logitech-C525-HD-Webcam-Black/dp/B008QS9MRA?_encoding=UTF8&ref_=cm_sw_r_cp_api_i_diTBzbE7S381Y
      Any suggestions on what to do here ?
        Mykle1 Project Sponsor Module Developer @adityaanandmc
        @adityaanandmc said in Webcam with microphone setup:
        http://www.amazon.in/Logitech-C525-HD-Webcam-Black/dp/B008QS9MRA?encoding=UTF8&ref=cm_sw_r_cp_api_i_diTBzbE7S381Y
        I don’t have any suggestions for you but I did look at this page before I made my decision on what webcam to buy so that I could be relatively sure that it would work with the Pi3 B that I have. I chose the Kodak S101 for one reason. It looked like I could dismantle it. I don’t want the casing. I’m going the drill a hole in the frame of my mirror and insert the lens and microphone. I haven’t gotten around to it yet.
        Anyway, your webcam choice should work for you. It clearly states on this page that it will, as it did mine.
        http://elinux.org/RPi_USB_Webcams
          adityaanandmc @Mykle1
          @Mykle1 said in Webcam with microphone setup:
          Thanks @Mykle1 ! You make a valid point. Thanks a ton.
          • foxF Offline
            fox
            Some recommendations for a good cheap outdoor cam?
