    Space between 2 modules
    6 Posts 5 Posters 4.6k Views 3 Watching
    • PointPubMediaP Offline
      PointPubMedia
      I trying to reduce the space between 2 modules at the same location!
      Bottom right!
      I’m using MMM-ip and mmm-systemtemperature… I would like to be able to have no free space between these 2!
      • O Offline
        onetwankyfive
        +1 for this… I toyed with the css and even tried to combine the modules into one, but no such luck
        • MichMichM Offline
          MichMich
          This should be possible with some custom css, but it might require some fiddling.
          • strawberry 3.141S Offline
            you can just put .module { margin-top: 10px;} in the custom.css this should work
            • KirAsh4K Offline
              KirAsh4 Moderator
              That would affect all modules though. Just keep that in mind.
              • MichMichM Offline
                MichMich
                Using the classes property in the config you can add custom classes to a module. After that you can use:
                .custom-class {
                    margin-top: 10px;
