    MMM-Hive
    39 Posts 7 Posters 24.0k Views 6 Watching
      rick @mongo116
      @mongo116 Hi - Looks like Hive have changed the login details and so the inside temp has stopped working. This can be fixed by changing the following line (#62) in node_helper.js from
      url: lUrl + '/global/login',
      to
      url: lUrl + '/cognito/login',
        DarrenG
        Ah thank you, came here to research this issue and have just implemented your fix and all working again.
          mongo116 Module Developer @rick
          @rick Cheers for the details. I’ve updated and added some config options in case this changes again, so you only then need to update the config.
            rick
            Looks like Hive have been changing login details yet again!. This time you need to change line(#67) in node_helper.js from
            headers: { 'Content-Type': 'application/json'},
            to
            headers: { 'Content-Type': 'application/json', 'User-Agent': 'HiveRNApp/10.16.2' },
              @rick Thanks for that. Github has been updated :thumbs_up_light_skin_tone:
                Not sure whether many are using this module but figured I’d provide an update on the changes I made today. I’ve now updated the module so that it works again! I have updated to include the new login process and from testing it all appears to work - would welcome any feedback though :)
                • N Offline
                  np27np27
                  My Hive module is giving a login error all of a sudden. Has Hive changed its user authentication method?
                  Can the module author update this?
                  • N Offline
                    np27np27 @np27np27
                    @mongo116 ?
                    • N Offline
                      np27np27 @np27np27
                      I think its to do with Hive’s 2-factor authentication
                      Does anyone have a workaround for it?
                      • 4 / 4
