    MMM-Lunartic
    Scheduled Pinned Locked Moved Education
    266 Posts 30 Posters 543.4k Views 29 Watching
    • Mykle1M
      Oh cool. I never saw my weather module use another language! When I changed my config language to sv (using the copy mentioned in the previous post) I had both MMM-Lunartic and MMM-BMW-DS in nl. :-)
      • J
        Johans @Mykle1
        @mykle1 said in MMM-Lunartic:
        nl translation
        “New Moon - No visible moon”: “Nieuwe Maan - Niet zichtbaar”,
        "The last full moon was ": “Laatste volle Maan was”,
        Thanks for updating this nice module.
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @Johans
          @johans said in MMM-Lunartic:
          You’re welcome, mate. Thanks for helping out. I’ll add these to the nl.json file tonight. Off to work! TGIF!
          • P
            Pr05t3n @Mykle1
            @mykle1
            Partly working actually.
            Månen är nu 2 dagar gammal correct
            Månen är 4% illuminated(belyst) illuminated is wrong
            Waxing crescent moon not ok
            Distance from Earth`s core not ok
            Distance from sun not ok
            Nästa fullmåne är correct
            Nästa nymåne är correct
            “New Moon - No visible moon”: “Nymåne - Ingen synlig måne”,
            and
            "The last full moon was ": “Sista fullmånen var”,
            I Will come back with answer of your request tomorrow
            Thanks for the support
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @Pr05t3n
              @pr05t3n
              You could have done the translation in the time it took you to write that post. ;-)
              • P
                Pr05t3n @Mykle1
                "Distance from Earth’s core = ": "Avstånd från jordens kärna = ",
                "Distance from sun = ": "Avstånd från solen = ",
                "The next full moon is ": "Nästa fullmåne är ",
                "The next new moon is ": "Nästa nymåne är ",
                "The current moon is ": "Månen är nu ",
                "The moon is “: “Månen är “,
                “% illuminated”: " % belyst”,
                " days old”: " dagar gammal”,
                “New Moon Phase”: “Nymåne”,
                “Waxing Crescent Moon”: “Tilltagande skära”,
                “First Quarter Half Moon”: “Halvmåne”,
                “Waxing Gibbous Moon”: “Tilltagande halvmåne”,
                “Full Moon”: “Fullmåne”,
                “Waning Gibbous Moon”: “Avtagande halvmåne”,
                “Third Quarter Half Moon”: “Halvmåne”,
                “Waning Crescent Moon”: “Avtagande skära”,
                “When the Moon hits your eye . . .”: “När månen träffar dina ögon . . .”
                Missunderstood you request, sorry Mykle1
                • Mykle1M
                  @pr05t3n said in MMM-Lunartic:
                  No worries, mate. Thanks for the sv translations! :thumbsup:
                  • Mykle1M
                    Download:
                    [card:mykle1/MMM-Lunartic]
                    Version Update 1.0.4
                    Thanks to @Johans and @Pr05t3n for their translations into nl and sv, respectively. My thanks to you both. :thumbsup:
                    git pull in the MMM-Lunartic directory or install as per the readme
                    qu1queQ 1 Reply Last reply Reply Quote 0
                    • qu1queQ
                      qu1que Project Sponsor @Mykle1
                      @mykle1
                      Hi! I really like this module! It’s so cool!! I’ve just recently updated it to the last version, and I can’t wait for next full moon to hear the wolf audio. I have one doubt about it, when that sound it will be played? Ramdomly or how?
                      Thanks!
                      Mykle1M 2 Replies Last reply Reply Quote 0
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @qu1que
                        @qu1que
                        Thank you for your kind words. :thumbsup:
                        1. Config entry for MMM-Lunartic, sounds must be set to yes. Example -> sounds: "yes",
                        2.For rotating mode, depending on your rotateInterval, the sound will play each time the full moon element is reached. There are 7 elements.
                        Example:
                        My rotateInterval: 30 * 1000, . That’s 30 seconds, times each element to be displayed, because the sound file will only play when the full moon element is displayed. So,
                        The formula will be 7 X your rotateInterval
                        30 X 7 = 3:30 (that’s 3 minutes 30 seconds) in this case.
                        You can substitute your own sound file if you have one you like better.
                        EDIT:
                        If you are using mode: "static", the sound will play each time the config updateInterval: 3 * 60 * 1000, is reached. In this case, 3 minutes.
                        • P
                          Pr05t3n
                          Need some help with moon animation.
                          No moon visible for me.
                          module: 'MMM-Lunartic',
                                  position: 'bottom_center', // Best in left, center, or right regions
                                      mode: "rotating", // rotating or static
                                      image: "current", // animation, current, DayNight or static
                                      distance: "km", // miles or km
                          	    sounds: "yes", // howling wolf, only on a full moon
                                      useHeader: false, // true if you want a header
                                      header: "The Lunartic is in my head", // Any text you want
                                      maxWidth: "300px",
                                      animationSpeed: 0,
                                      rotateInterval: 15000,
                          • Mykle1M
                            @pr05t3n
                            Are you saying the module runs but you get no image of the moon? Or are you saying you are not getting the animated moon?
                            https://forum.magicmirror.builders/topic/4247/how-to-post-code-on-the-forum-for-absolute-beginners
                            Kindly use a code block when you paste code, as such.
                                          image: "animation", // animation, current, DayNight or static
                                          maxWidth: "300px",
                                          animationSpeed: 0,
                            Notice: image: "animation",
                            • P
                              Pr05t3n @Mykle1
                              @mykle1 i do not get any picture of the moon.
                              Only text.
                              I tried, current, animation and daynight.
                              When i choose static i see all pictures of the moon and when i choose animation i see full moon with the animating clouds.
                              Current is the setting i would like to use
                              Sorry for pasting the config part.
                              • Mykle1M
                                @pr05t3n
                                Please try this url in a browser. It’s the url to the current moon image provided by the US NAVY. I suspect that if you live outside the U.S. that it might not work.
                                http://api.usno.navy.mil/imagery/moon.png?date=today&time=now
                                And the url to the Day/Night map
                                http://api.usno.navy.mil/imagery/earth.png?date=today
                                Please report
                                • Mykle1M
                                  No worries. I wanted to see your config. It’s just easier to read when it’s in a code block. Don’t you agree?
                                  • Mykle1M
                                    • rudibaraniR
                                      rudibarani Project Sponsor
                                      @Mykle1: Thank you for this nice module!
                                      • Mykle1M
                                        Mykle1 Project Sponsor Module Developer @rudibarani
                                        @rudibarani said in MMM-Lunartic:
                                        You are quite welcome, sir. I do appreciate your kind words. :thumbsup:
                                        • P
                                          Pr05t3n @Mykle1
                                          @mykle1 Unfortunately you are right. Web pages does not work.
                                          Traceroute tells me that they are firewalled
                                          • Mykle1M
                                            @pr05t3n
                                            Since we are only talking about the image url, perhaps we can work around it. Here’s where you get to do some work. If you can find another url that offers current images of the moon and works for users outside the US, I will incorporate into the module based on the config language.
                                            • 6
                                            • 13
                                            • 14
                                            • 4 / 14
