    MMM-Lunartic
    Scheduled Pinned Locked Moved Education
    266 Posts 30 Posters 553.7k Views 29 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @Pr05t3n
      @pr05t3n
      You could have done the translation in the time it took you to write that post. ;-)
        Pr05t3n @Mykle1
        @mykle1 said in MMM-Lunartic:
        "Distance from Earth’s core = ": "Avstånd från jordens kärna = ",
        "Distance from sun = ": "Avstånd från solen = ",
        "The next full moon is ": "Nästa fullmåne är ",
        "The next new moon is ": "Nästa nymåne är ",
        "The current moon is ": "Månen är nu ",
        "The moon is “: “Månen är “,
        “% illuminated”: " % belyst”,
        " days old”: " dagar gammal”,
        “New Moon Phase”: “Nymåne”,
        “Waxing Crescent Moon”: “Tilltagande skära”,
        “First Quarter Half Moon”: “Halvmåne”,
        “Waxing Gibbous Moon”: “Tilltagande halvmåne”,
        “Full Moon”: “Fullmåne”,
        “Waning Gibbous Moon”: “Avtagande halvmåne”,
        “Third Quarter Half Moon”: “Halvmåne”,
        “Waning Crescent Moon”: “Avtagande skära”,
        “When the Moon hits your eye . . .”: “När månen träffar dina ögon . . .”
        Missunderstood you request, sorry Mykle1
        Mykle1M 1 Reply Last reply
        • Mykle1M
          @pr05t3n said in MMM-Lunartic:
          No worries, mate. Thanks for the sv translations! :thumbsup:
          • Mykle1M
            Download:
            [card:mykle1/MMM-Lunartic]
            Version Update 1.0.4
            Thanks to @Johans and @Pr05t3n for their translations into nl and sv, respectively. My thanks to you both. :thumbsup:
            git pull in the MMM-Lunartic directory or install as per the readme
            qu1queQ 1 Reply Last reply
            • qu1queQ
              qu1que Project Sponsor @Mykle1
              @mykle1
              Hi! I really like this module! It’s so cool!! I’ve just recently updated it to the last version, and I can’t wait for next full moon to hear the wolf audio. I have one doubt about it, when that sound it will be played? Ramdomly or how?
              Thanks!
              Mykle1M 2 Replies Last reply
              • Mykle1M
                Mykle1 Project Sponsor Module Developer @qu1que
                @qu1que
                Thank you for your kind words. :thumbsup:
                1. Config entry for MMM-Lunartic, sounds must be set to yes. Example -> sounds: "yes",
                2.For rotating mode, depending on your rotateInterval, the sound will play each time the full moon element is reached. There are 7 elements.
                Example:
                My rotateInterval: 30 * 1000, . That’s 30 seconds, times each element to be displayed, because the sound file will only play when the full moon element is displayed. So,
                The formula will be 7 X your rotateInterval
                30 X 7 = 3:30 (that’s 3 minutes 30 seconds) in this case.
                You can substitute your own sound file if you have one you like better.
                EDIT:
                If you are using mode: "static", the sound will play each time the config updateInterval: 3 * 60 * 1000, is reached. In this case, 3 minutes.
                  Pr05t3n
                  Need some help with moon animation.
                  No moon visible for me.
                  module: 'MMM-Lunartic',
                          position: 'bottom_center', // Best in left, center, or right regions
                              mode: "rotating", // rotating or static
                              image: "current", // animation, current, DayNight or static
                              distance: "km", // miles or km
                  	    sounds: "yes", // howling wolf, only on a full moon
                              useHeader: false, // true if you want a header
                              header: "The Lunartic is in my head", // Any text you want
                              maxWidth: "300px",
                              animationSpeed: 0,
                              rotateInterval: 15000,
                  • Mykle1M
                    @pr05t3n
                    Are you saying the module runs but you get no image of the moon? Or are you saying you are not getting the animated moon?
                    https://forum.magicmirror.builders/topic/4247/how-to-post-code-on-the-forum-for-absolute-beginners
                    Kindly use a code block when you paste code, as such.
                                  image: "animation", // animation, current, DayNight or static
                                  maxWidth: "300px",
                                  animationSpeed: 0,
                    Notice: image: "animation",
                    P 1 Reply Last reply
                      Pr05t3n @Mykle1
                      @mykle1 i do not get any picture of the moon.
                      Only text.
                      I tried, current, animation and daynight.
                      When i choose static i see all pictures of the moon and when i choose animation i see full moon with the animating clouds.
                      Current is the setting i would like to use
                      Sorry for pasting the config part.
                      • Mykle1M
                        @pr05t3n
                        Please try this url in a browser. It’s the url to the current moon image provided by the US NAVY. I suspect that if you live outside the U.S. that it might not work.
                        http://api.usno.navy.mil/imagery/moon.png?date=today&time=now
                        And the url to the Day/Night map
                        http://api.usno.navy.mil/imagery/earth.png?date=today
                        Please report
                        • Mykle1M
                          No worries. I wanted to see your config. It’s just easier to read when it’s in a code block. Don’t you agree?
                          • Mykle1M
                            • rudibaraniR
                              rudibarani Project Sponsor
                              @Mykle1: Thank you for this nice module!
                              • Mykle1M
                                Mykle1 Project Sponsor Module Developer @rudibarani
                                @rudibarani said in MMM-Lunartic:
                                You are quite welcome, sir. I do appreciate your kind words. :thumbsup:
                                  Pr05t3n @Mykle1
                                  @mykle1 Unfortunately you are right. Web pages does not work.
                                  Traceroute tells me that they are firewalled
                                  • Mykle1M
                                    @pr05t3n
                                    Since we are only talking about the image url, perhaps we can work around it. Here’s where you get to do some work. If you can find another url that offers current images of the moon and works for users outside the US, I will incorporate into the module based on the config language.
                                    • Mykle1M
                                      Fun Moon Fact
                                      We all know there was a man on the moon, but did you know that there is one who stayed there? Dr. Eugene Shoemaker, a Geological Surveyor, who educated the Apollo mission astronauts about craters, never made it into space himself, but it had always been one of his dreams. He was rejected as an astronaut because of medical problems. After he died, his ashes were placed on board the Lunar Prospector spacecraft on January 6, 1999, which was crashed into a crater on the moon on July 31, 1999. The mission was to discover if there was water on the moon at the time, but it also served to fulfill Dr Shoemaker’s last wish.
                                      • cowboysdudeC
                                        @mykle1 You must be bored tonight…LOL
                                        • Mykle1M
                                          @cowboysdude
                                          True, but I did find it interesting.
                                            Pr05t3n
                                            https://www.moongiant.com/phase/today/
                                            http://lunaf.com/lunar-calendar/
                                            https://www.calendar-365.com/moon/current-moon-phase.html
                                            https://moonphases.co.uk/
                                            https://www.die.net/moon/
                                            https://www.starmessagesoftware.com/moonscreensaver/moon-phase-tonight.html
                                            Something like this?
                                            • 13
                                            • 14
                                            • 4 / 14
