    NASCAR standings
    17 Posts 4 Posters 9.4k Views 3 Watching
      dwlyles
      I see lots of cool modules, anyway someone can create a top 16 leaderboard for NASCAR?
      MUCH appreciated!
      • cowboysdudeC Offline
        cowboysdude Module Developer
        I have looked and looked but can’t find the data for it. If you can locate an api for it I’d be happy to do it…
        D 2 Replies Last reply Reply Quote 1
          dwlyles @cowboysdude
          @cowboysdude your awesome for even trying! thank you! I’ll see what i can find.
            @cowboysdude https://fantasydata.com/pricing/nascar-data-api.aspx does this look useful at all?
              cowboysdude Module Developer @dwlyles
              @dwlyles Yes but the data is not free. You get a free trial then it gets expensive…
              Mykle1M D 2 Replies Last reply Reply Quote 0
                Mykle1 Project Sponsor Module Developer @cowboysdude
                @cowboysdude said in NASCAR standings:
                Oh hell no!
                  @cowboysdude I just signed in to see what it offers and they alter the data by 20% unless you pay lol what a joke
                  Thanks again for the help.
                  • emloweE Offline
                    emlowe Module Developer
                    http://www.nascar.com/cacher/2017/1/points-feed.json
                    I scraped that out of the nascar page. Seems promising but unclear if it will work long term.
                    -Earle
                    D cowboysdudeC Mykle1M 3 Replies Last reply Reply Quote 0
                      dwlyles @emlowe
                      @emlowe so thinking, may need to update once a year?
                        cowboysdude Module Developer @emlowe
                        @emlowe Like anything else… it’ll work until it doesn’t :)
                        May have to fiddle with but it’s the best that’s out there unless you want to pay for it. ;)
                        Great job! Thank you!
                          @dwlyles said in NASCAR standings:
                          I’ll look at it later today … have to work :)
                          It would need to be in rotating format because a chart would just be too big for the mirror
                          Took a few minutes while having coffee and threw something together real quick… I have the data it seems to work so I’ll make it look pretty when I get home ;)
                            Mykle1 Project Sponsor Module Developer @emlowe
                            @emlowe said in NASCAR standings:
                            Any chance you can scrape the NFL standings from
                            http://www.scoreboard.com/nfl/standings/
                            or somewhere
                              @dwlyles is this what you’re looking for?
                              0_1501948714964_2.png !
                              Mykle1M D 2 Replies Last reply Reply Quote 2
                                @cowboysdude
                                You’re a magician!
                                  Get it here:
                                  https://forum.magicmirror.builders/topic/4609/mmm-nascar
                                  • emloweE Offline
                                    The NFL seems to use scoreboard.com which is much less obvious how to fetch their data. There are using some AJAX calls, but when I try to call them directly I get denied - there is likely some cookie involved. I suspect it would be somewhat complicated to fetch.
                                    -Earle
                                      @cowboysdude this is amazing! you definitely are a magician!!
