    MMM-CalendarExt
    198 Posts 45 Posters 246.8k Views 45 Watching
    • ? Offline
      A Former User @Frek
      @frek
      Add this into your css/custom.css;
      .CALEXT .tableStyle .eventTime {
      display: none;
      • F Offline
        Frek @Guest
        @sean
        Thx for the reply.
        I already have this in my css to display time, that I want:
        div.CALEXT .tableStyle .eventTime {
        display:block;
        font-weight:normal;
        font-size:70%;
        But I was wondering if on full day events its possible to only show title, not the time
        • ? Offline
          A Former User @Frek
          @frek
          div.CALEXT .tableStyle .fulldayevent .eventTime {
            display:none;
          Try this.
          • F Offline
            Frek @Guest
            @sean
            tried adding i to my custom.css and no change. my .css looks like:
             * Magic Mirror                                      *
             * Custom CSS                                        *
             * By Michael Teeuw http://michaelteeuw.nl           *
             * MIT Licensed.                                     *
             * Add any custom CSS below.                         *
             * Changes to this files will be ignored by GIT. *
             body {
              margin: 10px;
              height: calc(100% - 20px);
              width: calc(100% - 20px);
              display:none;
              display:block;
              font-weight:normal;
              font-size:70%;
             .CALEXT .tableStyle td.slot {
              max-height:200px;
              height:200px;
             .CALEXT .tableStyle {
              margin:0;
              max-width: 100%;
            • ? Offline
              A Former User @Frek
              @frek said in MMM-CalendarExt:
              display:none;
              display:block;
              font-weight:normal;
              font-size:70%;
              max-height:200px;
              height:200px;
              margin:0;
              max-width: 100%;
              I tested with your CSS but it works as expectation.
              • F Offline
                Frek @Guest
                @sean ah suck… my test calendar didnt have a full day event… just a long normal event. Google calandar tricked me by showing me it as a fullday event in their app…No wonder why it didnt work… thx for the help =)
                • G Offline
                  goalie2k
                  Is it possible to make the event time display on the SAME line as the event title?
                  • ? Offline
                    A Former User @goalie2k
                    @goalie2k
                    Of course possible by adjusting CSS
                    .CALEXT .event .eventContainer {
                      display: flex;
                      flex-direction: row;
                      flex-wrap: wrap;
                    .CALEXT .eventTime {
                      order: 2;
                      width: 30%;
                    .CALEXT .eventContent {
                      order: 1;
                      width: 70%;
                    It will show like this.
                    G 1 Reply Last reply Reply Quote 1
                    • G Offline
                      goalie2k @Guest
                      @Sean said in MMM-CalendarExt:
                      order: 2;
                      width: 30%;
                      YOU ROCK! Thank you!
                        Subintro
                        Hey does anyone know how to change text on the calendars?
                        I’m using the ‘Current’ event, but it looks kind of confusing as it says ‘In 50 minutes’, which makes it seem like the event is in 50 minutes, but really ends in 50 minutes
                        • ? Offline
                          A Former User @Subintro
                          @Subintro
                          With MMM-CalendarExt, it’s not so easy. You just use useRelative:0 to display normal time. Anyway “CURRENT” event will not be thing of “START IN FUTURE”, It is already started and be a kind of “END IN FUTURE” things. “CURRENT” means that.
                          How about using MMM-CalendarExt2? That is new build-up and the feature can be configurable and customizable by configuration.
                          https://github.com/eouia/MMM-CalendarExt2/wiki/Event-Time#2-relative
                            Subintro @Guest
                            @Sean
                            Oh nice, I’ll check it out. Hopefully wont have to change too much with my config
                              Smotx
                              Little help please,
                              how to reduce the height of the module?
                              It adapts automatically to the content, but suddenly exceeds the top one
                              alt text
                              Thx a lot.
                              • ? Offline
                                A Former User @Smotx
                                @Smotx
                                See this;
                                https://github.com/eouia/MMM-CalendarExt/wiki/Manipulation-of-looks#viewlimit--viewoverflow
                                  Smotx @Guest
                                  @Sean
                                  Thx for help, with your indication, i have finally used
                                  overflowHeight: 200,
                                    redink
                                    Is there a way to show the event start time in the same space as the even name?
                                    Like 6p Swim Lesson
                                    • ? Offline
                                      A Former User @redink
                                      @redink
                                      More detailed adjusting might be needed, but commonly see this.
                                      https://forum.magicmirror.builders/topic/4624/mmm-calendarext/148
                                      And, add onlyStartingTime: 1, in your view configuration
                                      • I Offline
                                        isaac2004
                                        Seems I cannot get the module to load. tried a few things, but it is just blank. I have the latest version of MM
                                        • ? Offline
                                          A Former User @isaac2004
                                          @isaac2004 I need log or more detailed info to catch what happened.
                                            mmmmh Project Sponsor
                                            I successfully use the module on two other screens. I just set up a new one without tweaks and I run into the following error in the console (nothing gets loaded, server-side there are no errors being logged):
                                            Uncaught (in promise) TypeError: hookDom.appendChild is not a function
                                                at Render.js:590
                                                at Array.forEach (<anonymous>)
                                                at Render.drawViews (Render.js:581)
                                                at Class.getDom (MMM-CalendarExt.js:209)
                                                at main.js:110
                                                at new Promise (<anonymous>)
                                                at updateDom (main.js:109)
                                                at Object.updateDom (main.js:518)
                                                at Class.updateDom (module.js:358)
                                                at Class.draw (MMM-CalendarExt.js:680)
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 8 / 10
