    Electron CPU usage
    247 Posts 46 Posters 629.8k Views 42 Watching
      Mr.Sponti @Mykle1
      @Mykle1 Yes, I downgraded due to high CPU usage with MM2.1.1 & electron1.4.17. Top showed a usage between 100 and 200% and my own written moduls had a really bad performance.
        Mykle1 Project Sponsor Module Developer @Mr.Sponti
        @Mr.Sponti said in Electron CPU usage:
        Ok, thank you. I’m glad that you’re seeing the benefit of this workaround. Let’s hope that it gets addressed and corrected sometime in the future.
        • K Offline
          Kugelfang @Mr.Sponti
          @Mr.Sponti
          I tried your precise instructions but my system still installed electron 1.7.9
          i started with a fresh jessy install on my raspberry pi 3. i then installed the latest version of node.js and copied the MM 2.10 folder to my pi. I then modified the dependancy for electron to 1.4.15 in the package.json and run the installation. However i still ended up with electron 1.7.9 which runns really bad…
          it would be great if someone could help me
            Mykle1 Project Sponsor Module Developer @Kugelfang
            @Kugelfang said in Electron CPU usage:
            npm install electron@1.4.15
              Mr.Sponti
              cd $HOME/MagicMirror
              npm uninstall -g electron
              npm uninstall electron
              • K Offline
                Kugelfang
                @Mykle1: that seems to have worked. I just entered the MagicMirror folder and ran the command! thanks a lot! the animations are a lot better now!
                However, now i have another problem: it seems that the weather forecast module does not work. All other modules work as expected but the forecast does not show up. I double checked all the settings in the config.js and they seem ok.
                @Mr-Sponti: thanks for the input but it seems that simply installing 1.4.15 over the 1.7.9 seems to have already working
                Could it be that the weatherforecast plugin comming with MM 2.10 is the problem?
                  I don’t think so. It’s more of an API key issue. The newer API keys are being rejected by the API source. You can search this forum. I don’t know if there is a fix. Or, try another weather module in the meantime
                  • K Offline
                    Kugelfang
                    That is odd, my current config.js was working with my API keys for both actual weather and weather forecast modules brilliantly with the most recent mm version (the slow one)
                    With 2.10/1.4.15 the actual weather module still works but the weather forecast modules simply does not show up on the screen although it’s fully setup in the config file including the proper API key
                      @Kugelfang
                      This is just one result of searching the forum for “Weather Not Showing”
                      https://forum.magicmirror.builders/topic/4822/no-weather-showing
                      • K Offline
                        Kugelfang
                        ok, thanks a lot, this was quite helpfull!
                        • C Offline
                          CGabo
                          Hi
                          This is with an clean install from scratch:
                          Version: raspbian stretch and current updates
                          Linux mmbs 4.9.61-v7+ #1049 SMP Fri Nov 10 15:32:51 GMT 2017 armv7l GNU/Linux
                          MagicMirror/node_modules/electron/dist/version
                          v1.7.9
                          and MM default config.js
                          -> Issue stille here
                          Increased default GPU Memory 64mb to 128mb
                          No cpu problem with
                          Linux mmbs 4.9.57-v7+ #1045 SMP Fri Oct 20 11:44:49 BST 2017 armv7l GNU/Linux
                          and electron v1.6.2
                            astrakid
                            i am running magicmirror only as client (via webbrowser) on a raspberry pi zero. have only a few modules installed (newsfeed, calendar, currentwheather, 2 wheather forecasts, bergfex, mmm-syslog), and don’t have any performance issues while displaying (resolution 1080x1920).
                            can’t tell you the main difference in cpu load between electron and midori (which i am using), but i guess there must be something else causing this trouble.
                              It’s all pretty much discussed in this topic
                              • C Offline
                                CGabo
                                Yes, I know. Just wanted to clarify that the topic is still current with:
                                stretch img. with update to 4.9.61-v7+ #1049 and electron v1.7.9
                                and no issue with:
                                jessie img. with update to 4.9.57-v7+ #1045 and electron v1.6.2
                                -> There are some combination of OS / MM / electron which cause a high CPU load.
                                  austin
                                  I have been doing a lot of testing on this. I started using the latest Pixel and MM and had temperature and lockup issues. I then noticed that CPU usage was very high. I started doing lots of tests. I finally found that the best CPU usage and temperature was when using Electron 1.6.15. You can see the results in the screenshots.
                                  If you need/want to use Pixel do not use Electron greater than 1.6.15. I tried many combinations along with matching the version of node the electron recommends. Nothing 1.7.x worked that well. As you can see in CGabo’s image on Pixel Electron 1.7.9 uses 100% cpu at time. In my screenshot on Jessie it used 70-80% only. Not sure why this is.
                                  My recommendation would be to have Magic Mirror pin the Electron version to 1.6.15 at this time.
                                  1_1510598970148_2017-11-11 10_05_56-pi@magicmirror_ ~.png 0_1510598970148_2017-11-11 09_43_05-pi@magicmirror_ ~.png
                                    Mykle1 Project Sponsor Module Developer @austin
                                    @austin said in Electron CPU usage:
                                    Perhaps, but without a doubt, and confirmed months ago by numerous users (including myself) the combination that works best, and with the least amount of CPU load on a Pi, is Raspian Jessie, MM v2.1.0 and Electron v1.4.15. All the results are in the topic above which started 3 months ago. It was a hell of a ride! :-)
                                      schlachtkreuzer6
                                      FYI:
                                      with the latest system update (yesterday) and upgrade (yesterday) and latest update of MM its better than before ^^ but still running way to high. My pi is not showing up the overheating symbol (: animations still are crap,…
                                        Mykle1 Project Sponsor Module Developer @schlachtkreuzer6
                                        @schlachtkreuzer6
                                        I’m not using the Pi anymore. The one Pi mirror I have will stay using Jessie, MM v2.1.0 and electron v1.4.15. It doesn’t make any sense to change it. It runs flawlessly.
                                        My other boards can handle the newest MM and electron so I use those there.
                                          schlachtkreuzer6 @Mykle1
                                          @Mykle1 okay, which alternatives do you use? (:
                                            @schlachtkreuzer6 said in Electron CPU usage:
                                            Me, personally? I’ve taken to old laptop boards. Basically, a 10-12 year old laptop will outperform any Pi, in all categories. ubuntu installed turns a POS laptop into a killer MM macine and the laptops that old are as inexpensive as a new Pi, or free in some cases.
                                            Here are some things that others are using
                                            https://forum.magicmirror.builders/topic/4513/stronger-raspberry-pi-3-alternatives.
                                            Laptop mirror
                                            https://forum.magicmirror.builders/topic/4930/vanity-mirror-thy-name-is-woman-using-laptop
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 10 / 13
