    MMM-GoogleMapsTraffic
    87 Posts 27 Posters 95.4k Views 28 Watching
    • E
      Egnos
      Hello to all.
      Many thanks to the developer for the brilliant idea!
      I describe my environment:
      I’m testing the various modules on a virtual machine (Virtual Box) that runs on a Windows 10 PC.
      For now all modules work perfectly except MMM-GoogleMapsTraffic.
      Description of the problem:
      I successfully installed the module but when I launch MM I only see the classic purple Google Maps pointer and nothing else…
      The configuration of the .JSON seems ok, and the API has been entered correctly.
      Can you help me…?
      Thank you all!
        sdetweil @Egnos
        @Egnos see back a couple posts to get my updated version.
        • E
          Egnos @sdetweil
          I installed the module this afternoon, I believe it is already the updated version.
          I have used this
          guide
            sdetweil @Egnos
            @Egnos from here, right?
            https://github.com/sdetweil/MMM-GoogleMapsTraffic
            E 3 Replies Last reply Reply Quote 0
            • E
              Egnos @sdetweil
              Yes, of course.
              • E
                Egnos @sdetweil
                @sdetweil said in MMM-GoogleMapsTraffic:
                sorry @sdetweil, I have seen now that there are two modules with the same name!
                *vicmora module not updated
                • sdetweil module updated
                Correct?
                Thanks.
                  sdetweil @Egnos
                  @Egnos correct
                  • E
                    Egnos @sdetweil
                    Hi @sdetweil ,
                    using the second link the module starts but I see this message:
                    “This page didn’t load Google Maps correctly”
                    The screen shot
                    https://ibb.co/bm6BqJ6
                    Can you help me?
                    Thanks.
                      sdetweil @Egnos
                      @Egnos are u doing this over vnc? I don’t see that problem using the display connected to the pi
                      • E
                        Egnos @sdetweil
                        Virtualize Raspbian with Virtualbox…
                          sdetweil @Egnos
                          @Egnos running on Intel?
                          I use VMware Workstation mostly.
                          But virtual box for a couple systems
                          • E
                            Egnos @sdetweil
                            @sdetweil are there problems with Magic Mirror if using VirtualBox?
                              sdetweil @Egnos
                              @Egnos I don’t know. Haven’t tried that
                              • E
                                Egnos @sdetweil
                                What does it mean when this message appears:
                                  sdetweil @Egnos
                                  @Egnos I do not know
                                    sdetweil @Egnos
                                    @Egnos sounds like u didn’t setup the API key
                                    https://www.google.com/amp/s/www.liontreegroup.com/tips-and-tricks/fixing-the-this-page-cant-load-google-maps-correctly-error/amp/
                                    • E
                                      Egnos
                                      Hi @sdetweil
                                      It would seem that to have a valid API Key you need to “Enabling billing on Google Cloud Platform …”.
                                      To receive the API Key, you need to enter a valid credit card number.
                                      Did you do this too?
                                      Do you agree?
                                      Thanks.
                                        sdetweil @Egnos
                                        @Egnos yes. The apis are not free, altho our usage is typically below the 1st tier charge level
                                        • E
                                          Egnos @sdetweil
                                          @sdetweil so you also entered your credit card?
                                          How many accesses does this module make per day?
                                            sdetweil @Egnos
                                            @Egnos yes, credit card. I don’t know number of accesses. U can control that I think. Not my module.
                                            Readme says default is once every 15 minutes
                                            updateInterval
                                            So, 96 times per day
                                            • 4 / 5
