    MMM-OlympicGames
    Scheduled Pinned Locked Moved Sport
    olympic games2022olympic winter gamesolympiabeijing
    41 Posts 15 Posters 31.0k Views 15 Watching
    • strawberry 3.141S
      strawberry 3.141 Project Sponsor Module Developer @mlhote
      @mlhote I had the same issue initially, but after telling the API that I’m not a server but actually using the latest version of the Google Chrome browser here it worked for me and I didn’t experience the same issue again.
      Maybe you changed the reload interval to something that is too frequent.
      Can you please show your config of the module?
      • M
        mlhote
        Great it’s work
        Thk at everybody
        • M
          mlhote
          Great it’s work 1 time !!!
          When i reboot MM, i have to click again on the url…
          see my config
          module: ‘MMM-OlympicGames’,
          position: ‘top_right’,
          disabled: false,
          // all your config options, which are different than their default values
          So the trouble is not fix
          • J
            justdreambig @strawberry 3.141
            @strawberry-3-141
            Hello,
            I hope you can help me… This is my first time posting in the message board so please excuse any formatting mistakes.
            the module is on my MM but just says loading…
            Here is the error
            [03.02.2022 12:44.24.245] [ERROR] Error getting olympic game medals FetchError: invalid json response body at https://www.bloomberg.com/tosv2.html?vid=&uuid=12216a4d-8532-11ec-99d5-6f52634e6775&url=L2dyYXBoaWNzL2JlaWppbmctMjAyMi1vbHltcGljcy1kYXRhL2N1cnJlbnQuanNvbg== reason: Unexpected token < in JSON at position 0
            I have clicked on the link and it takes you to a page that if you hold on the button it unlocks the data. I know someone else was dealing with that so I hope they found and answer
            Here is some info about what I have done so far
            MM version MagicMirror: v2.15.0
            Synology Docker v20.10.3-1239
            First I cloned the MMM-OlympicGames to my modules folder
            then added to my config file (see below)
            ]MM-Olympics.png )
                    module: 'MMM-OlympicGames',
                    position: 'bottom_left',
            then I ran npm install --production in ~/MagicMirror/modules/MMM-OlympicGames directory.
            added Locale to the default settings
            locale: "en-US",
            then I restarted the MM and it still says loading…
            I even tried removing it and staring over step by step this morning and still have loading…
            Any ideas to point me in the right direction would be most helpful. I really like this module and would like to use it
            • KristjanESPERANTOK
              KristjanESPERANTO Module Developer @justdreambig
              I also had the “invalid json response” problem. After I upgraded node-fetch to 3.x, it works fine.
              • strawberry 3.141S
                In the beginning, I had the same issues with the invalid response. But I never had to click the link in order to fix it, I just started using the fake user agent in the module. Every time I restart the mirror it’s loading the data for me.
                The module is not using an official API. Everything else I found is charging money for it or does not return data.
                I was hoping once the games are starting that some other APIs start spitting out some data, so I could potentially switch.
                I’m open to links from free JSON APIs that would solve your issues.
                • strawberry 3.141S
                  Most sport news sites including the official olympic games website still show 0 medals.
                  • M
                    mlhote @KristjanESPERANTO
                    @kristjanesperanto Couldyou explain how to upgrade ?
                      KristjanESPERANTO Module Developer @mlhote
                      @mlhote In the meantime it works also with node-fetch v2 for me, so an upgrade seems not to be necessary.
                      One assumption is that this occurs when you restart the mirror several times. Then the API is often queried in a short time and therefore you are blocked.
                      • strawberry 3.141S
                        Link to module https://github.com/fewieden/MMM-OlympicGames
                        [1.2.0]
                        Added
                        • Added another data source, see new config option provider.
                        Changed
                        • Countries with same medals share the same rank
                        [card:fewieden/MMM-OlympicGames]
                          SirFM
                          I’ve specified the en-US locale but the country names seem to be in Catalan.
                          Here is my config file
                                                  module: "MMM-OlympicGames",
                                                          // all your config options, which are different$
                                                          locale: "en_US",
                                                          highlight: "CA",
                                                          maxRows: "10",
                                                          reloadInterval: "3600000",
                                                          provider: "nbc"
                          ```Edited to fix locale typo
                            sdetweil @SirFM
                            @sirfm I think the option is locale
                            u have local
                            computers are picky
                              SirFM @sdetweil
                              @sdetweil Just saw that after posting and made the correction. Unfortunaly I get the same result with the typo corrected.
                                KristjanESPERANTO Module Developer @SirFM
                                @sirfm locale has to be direcly under config not in the module config: https://github.com/fewieden/MMM-OlympicGames/blob/master/.github/global.png
                                  sdetweil @KristjanESPERANTO
                                  @kristjanesperanto yes, but that impacts system wide.
                                  but looking at the code, you are correct
                                    SirFM @sdetweil
                                    @sdetweil @KristjanESPERANTO
                                    My default locale is “ca-FR”. I don’t mind contributing to a transaltion file if needed.
                                    • strawberry 3.141S
                                      strawberry 3.141 Project Sponsor Module Developer @SirFM
                                      @sirfm the locale ca-FR represents Catalan (France) in your case it should be fr-CA for French (Canada).
                                      In general, the locale format is mostly language code - region code.
                                      There are some labels that could also be translated to french https://github.com/fewieden/MMM-OlympicGames/blob/master/translations/en.json
                                      • strawberry 3.141S
                                        Added
                                        • Added option for user to input list of countries to display, see config option countryList.
                                        • Added French language translations.
                                        Changed
                                        • Uniform spelling for MagicMirror²
                                        • Upgraded development dependencies
                                        • Updated preview images
                                          SirFM @strawberry 3.141
                                          Is there any way that the module could be used for the Paralympics games?
                                          strawberry 3.141S 1 Reply Last reply Reply Quote 1
                                          • strawberry 3.141S
                                            @sirfm @KristjanESPERANTO I found an API
                                            1.4.0
                                            Added
                                            • Data provider: paralympic
                                            Changed
                                            • Default provider: paralympic
                                            • Default title: Paralympic Winter Games 2022
                                            Link to module: https://github.com/fewieden/MMM-OlympicGames
                                            • 2 / 3
